Question about Refrigerators
Water dispenser not working
I Have a GE sise by side frig model # GSL25JFPD and the water dispenser just stop working. Replaced filter in August of 08. Can I remove items from freezer and turn freezer side off and see if water line has become frozen. Any ideas? Thanks
  • 161 Answers
This water line does not run through the freezer. You have a switch in the door where you get water that activates the water valve in the back of the Ref.
One or both of these are bad and needs to be replaced.
Posted on Dec 21, 2008
MY GE GSF25KGW Sise by side water dispenser will not stop. It is stuck open. Had to turn water off to house
Replace the water valve (part number WR57X10070) which should run $40 to $50 or so. It is the part the water line connects to at the back of the refrigerator.
May 22, 2011 | GE GSF25KGW Side by Side Refrigerator
I have a GE side by side model #GSH25JSTA SS. It is 4 years old. The Water disenser stopped working about 6 months ago. We have replaced water filter and that did not seem to work. When we press the...
hey Jun, I have the same problem,, especially in the winter.. I just unplug mine for about 20 minutes,,,(DON'T open the frig while doing this!!!) .. seems to get the water flowing for me.....
Jun 14, 2017 | GE GSH25JSTSS Stainless Steel Side by Side...
Water dispenser keeps freezing GE Refrigerator
If this is a newer model GE side by side refrigerator, this is not uncommon. what you can do to check to see what is going wrong, remove the toe plate at the bottom front of the unit. Under the freezer door, you will see a white plastic water line, with an inline connector about 4-5" from where the line comes out the bottom of the door. this is normally a blue push-in type connector. On this connector, you will see two white sleeves on either side, push in on this sleeve while pulling the corresponding water line section out of the connector, if you squeeze the sleeve enough, the water line will slip right out. Place a towel on the floor, make sure both ends are on top of towel. Now, breifly actuate your water dispenser trigger, see if water comes out the exposed water line. If water comes out, your entire water dispenser system is OK, but, the water line in the freezer door is frozen, in which case the only way to melt it, is to turn the unit off, open the freezer door, and blow a fan for a few hours, to melt the ice INSIDE the door. You could also buy a new door, but that is very costly.
If no water comes out the exposed water line, then either your water filter is clogged, or you have a bad water valve solenoid
Feb 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No water is coming from the water dispenser and ice cube are hollow water is coming out the bottom of frig on the floor could it just be a stopped up filter?
You definitely have a water flow problem. Plugged filter, broken line, low water pressure will all create these symptoms.
Feb 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Refridgerator Not Dispensing Water
did the water work before you changed the filter . water when chilled may have frozen in line. . i would before major work adjust tempt of both freezer and frig . if too cold / forzen line .. are you freezing any thing in crispers. this is a good clue.. hope this might help .. mm
Dec 07, 2009 | Kitchen Ranges
Model#a4425gd2aww;water dispenser stays on witout pushing cradle even when ice selection is on. This is an americana refridgerator made by GE.
Disconnect the wires on the water valve.(or unplug the frig) If the water stops the dispenser control is defective. If the water continues the valve is stuck and needs replacing.
Oct 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
The water dispenser in my frig stopped working but it still makes lots of ice. I replaced the filter on 29 Dec 2007. I normally get 6 months out of a filter.
We had same problem! The water line gets frozen in the door, and there is no way to get to it. But, I took some 14 gauge electrical wire and would get one end hot by putting it under hot water, then put that end up the water line in the door. This might take several attempts, but it will work. A little piece of ice about 2 inches long will come out.
Mar 05, 2008 | GE CleanSteel GSL25JFTBS
Water does not dispense from the door but there is water to the filter fitting
connect the water line in to the solenoid [with out the filter] to see if u dispensing water
Dec 01, 2007 | GE Monogram ZISx420DR 42-inch Side by Side...
Refrigerators Logo
237 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
