Question about Refrigerators
Too much ice
We have a kenmore, older, but has a fairly new ice maker (whirlpool, I think) that won't stop making ice. There is a metal bar that will no longer rise with the level of the ice to turn itself off when full. When the bucket gets too full, we raise the bar manually to get the icemaker to stop making ice.
  • tcx4 Dec 21, 2008
    What do you mean by opposite bar? I think the bar that we have is the one that came with the icemaker, so I'm not sure that's it. Do they sometimes come with the wrong bar?
  • tcx4 Dec 21, 2008
    Thanks Tborn. I'll ask my husband about it, but I'm pretty sure it must be something else because the ice maker had worked beautifully for several months after we installed it new, and the problem just happened all of a sudden. The bar lifts up and down by hand just fine, but it used to ride the ice up as it filled up in the bucket. Now we have to dig down through the very full bucket, feel for the bar and pull it up. That works great, but I know there's gonna come a time when maybe we're out of the house for a few days and the ice will fill that whole freezer, maybe even push the door open! Any other ideas on what it could be?
  • 700 Answers
Is the bar the correct one or is it too short? I woulds go to a Parts house and get the opposit bar that you have and replace it first.
Posted on Dec 21, 2008
  • Todd Born
    Todd Born Dec 21, 2008
    ye sthere is two different types. there is a longe rone and there's a shorter one.
Kenmore 106.55242400 ice maker knocking noise
most likely you need a new ice maker,one thing that could do this is the white arms that spin around when dumping the ice,sometimes one of the arms bend and jam the ice maker and you'll hear that knocking soundthe arm gets bent,the ice cube gets stuck because the arm can't push it out,,it stops the motor from spinning through it's full cycle and damages it but this is just a guess from something i've seen happen but most likely you need a new ice maker,one other i've seen is the metal arm that you can lift up to shut off the ice maker gets knocked out of the hole it slides into.if you pop off the white cover and get a jumper wire and stick it into the h and t holes you can jump start the ice maker.http://appliantology.org/gallery/image/659-manual-harvest-on-a-whirlpool-modular-ice-maker/
Jan 02, 2014 | Whirlpool Refrigerators
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
How do I turn off the ice maker
Many refrigerators will have Ice Makers with an on off switch. These are usually found on the machine. The other option is to lift the little metal bar that tells the ice maker that tray is full and it will stop.
Jul 09, 2012 | Kenmore Side by Side Refrigerator
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
Ice cube maker just stopped working. Ice cube arm has no tension to it.
If you can find someone that will take yours apart and rebuild the components inside the front of the ice maker would be good. The problem is with older ice makers you may over look the next part to fail. Your model has a tricky spring that helps the arm lock into place. You can visit our site or call the toll free number and get free help and advice. If you can locate your refrigerator model number that will also be helpful Their numbers always look like this for example 213.54698
Click link below and give us a visit, Sea Breeze
http://servicepartstec.blogspot.com/
May 23, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice maker has stoped making ice. The bar that cuts it off when enough ice is made moves a little while in the up position.
lifting the bar to the full up position is how you stop the ice maker from making ice. move the bar back down and ice making will resume.
Mar 08, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker won't stop making ice
it's time to replace the ice maker, it will not stop, the you can feel the small bar when it looks in to the of position.
Dec 10, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Whirlpool side by side icemaker won't stop... lol
no you shouldnt have to replace the ice maker, the stop arm probably is not in place. pull the ice maker out and check where the arm goes into the motor head. I think that will solve it for you. Good Luck.
Sep 28, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
