Question about Hitachi 50VG825 50 in. LCD HDTV
Picture getting dark
My picture is getting dark and i cannot seem to be able to adjust out the problem. i had a new lamp installed about a year ago.
  • 1 more comment
  • joebourff63 Dec 22, 2008
    it does not seem to be turning red.it is just dimming and is not crisp and clear. i had to turn up brightness to watch it. my son tried to play a video game and could hardly see where he was going.
  • joebourff63 Dec 23, 2008
    i took the lamp out to clean in that area to eliminate a possible dust problem and i saw a whiteish burn look on the glass just above the element and the lamp looked a little hazy.
  • Kelvin Neufeld
    Kelvin Neufeld May 11, 2010
    Is the picture becoming redish? If it becomes redish, then its the bulb. If not, it could be something else.
  • 34 Answers
Ok, so it could be both then. Um if u open up the monitor, then u should see a small chip at the bottom of the lcd. This is called the Inverter. You might have to replace that. I would take it down to any local computer shop, they usually have tools to test it, and see if its broken. unles u just wana replace it, i think they average around 40$ u can simply unplug the old one, and plug a new one in, but it wont be 100% guarantied that. could be a bad installation of your new lamp aswel.
Posted on Dec 22, 2008
Why is my picture
Since you do not supply information (type, brand, model, age)
about your set, it is difficult to guess at your problem. The settings are there (contrast, brightness, color) for you to readjust the set as it ages and are not often used past the setup stage when you get a new set.
Gamma is the base level to set the black part of the signal.
I do not know what lamp you would have in a TV set.
Dave
Jul 04, 2017 | Televison & Video
Our picture seems very dark, We got a new lamp installed about 8 months ago and have played with the colors etc but after awhile the picture just goes darker. any sugestions?
There should be a setting for the dynamic contrast ratio(or backlite setting on some tvs). Turning the dynamic contrast ratio off should make the screen brighter. This is usually called the DCR setting, turn it to off.
Feb 28, 2011 | Televison & Video
Tv brightness/vibrant
Most of the projection lamps are recommended to be replaced after 2 years. The older they get the more dim they will become. I would suggest replacing the lamp again. Some of the aftermarket lamps do not work as well as the factory replacement. I always spend the extra money and get one from Samsung.
Dec 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Dark picture!
The Lamp it self, the Ballast, or the Power Supply that powers the Ballast. Even a combination of the Lamp and Power Supply is a common problem. If you have not replaced the Lamp since you have owned the set I would replace that first. The Lamp has about a 3000 to 5000 hour life span.
Hope this helps,
Skyassoc
Jul 16, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Dark picture on 62" lcd
how old is the lamp , if is about a year old need a newone
May 12, 2009 | JVC HD-61Z575 61" Rear Projection...
Tv will not turn on
For dark picture I need to ask one question, How long ago you replaced its lamp? one year, two years?
Picture brightness is depends on lamp in LCD rear projection (DLP) TVs and if lamp got weak in generating light, you will see dark picture.
I would recommend to replace lamp and buy Sony original lamp from Sony Accessories Store.
Required lamp part number is as follows..
F93087500 LAMP BLOCK ASSY XL-2400
and price is $200
Good luck.
Apr 29, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Dark Picture
If the Lamp condition is okay then check the FE lens just next to the lamp in the projector after removing the lamp out of prj. replace if that is burnt.otherwise replace Lamp.
Viren
Nov 13, 2006 | NEC VT460 Multimedia Projector
Hitachi 50VG825 50 in. LCD HDTV Logo
224 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
