Question about Sharper Image Deluxe Spire SI788SNX Tower Fan
Fan wont work
Except for the fan not running (no apparent cause) remote is working ,blue lights come on for different functions but fan wouldnt. Can you help? kindly respond
  • 1 more comment
  • Anonymous Mar 15, 2008
    nothing. It does not work. same problem as person above
  • Anonymous Jul 12, 2008
    Greetings, I have a Sharper Image Spire fan model S1868. The fan runs when the power button is pushed, but it stops running when you push the rotate button. It will rotate one direction, start cycling back and stop when it reaches to turn back like it was hitting an end stop switch or something. The 2 trip switches on the covers work ok. I removed the main retaining nut on the rotation assy and checked for any rubbed wires or unusual wear. Nothing seems out of place. Any help would be appreciated! DM
  • Anonymous Oct 02, 2008
    same issue as the others ... the warranty on this fan is only 90 days
I have the same problem, warranty on this fan is only 90 days...
Posted on Oct 02, 2008
Why does fan no longer respond to remote?
Remote controlled ceiling fans do not respond favorably to wall switches. To restore order, you will have to start over. Shut down fan power at the source. Set the wall switch to ON and promise to never, ever use it again. Turn on power at the source. Try remote fan and light control functions. If either does not work, there could be pull-chain switches on the fixture that are interfering. Troubleshoot to get both fan and lights controlled only by the remote.
Mar 30, 2016 | Dryers
Remote wont work for fan.
http://www.ehow.com/how_6104129_instructions-hampton-bay-fan-remote.html You may need to reprogram the remote
May 15, 2013 | Televison & Video
I have a hunter fan model 20754 i need to know how i can control the light and fan separately with a two wire switch
there should be a pull chain somewhere that you can turn off the light with. There is no way except a remote unit that a 2 wire switch can control 2 different functions(fan & light)
Mar 10, 2012 | Dryers
We just bought a house that has 3 of the same fans. THey are hunter with remote and no pull cords. The master bedroom fan doesnt work. We tried to rewire it and the only way we could get anything to...
Hi Leanne,
Most fans have green, white, black and blue wires. Green is earth or safety ground, white is neutral, black is for the fan and blue is for the light fixture. Some fans may deviate from these commonly used colors in which case you should consult the instructions. Below are links to instructions for different Hunter remote fans, additional instructions for Hunter remote fans or you can look up your fan by model number or use. It appears that the built-in remote Hunter fans have no provision for controlling a light when the fan is wired from a traditional switch instead of using the included remote, as they have only a green, white and a single black that remains powered constantly to supply the remote receiver. The hand held remote transmitter tells the receiver to switch power to the fan motor and light bulbs as needed.
It is possible that the transmitter or receiver you're using in this room is not working. Try using one of the other remotes with the non-working fan by matching the code of the remote to the fan. If it doesn't work, try selecting a different code on the fan and match it on the remote (in case there's a problem with that particular code in this location). Try all (or as many as you care) codes to see if any codes work with this remote.
By this time, you should have either found a working code with this remote and are all done, or still have a non-working fan. Since you have tried more than one remote - and know that one of them worked in the other room, suspicion falls on a faulty fan or integrated remote receiver. You can replace the fan if you like with a traditional fan and light and purchase an after market or third party RF remote control if you no longer wish to get an integrated remote receiver.
I hope this helps and good luck. Please rate my reply - thanks!
Apr 19, 2011 | Dryers
I have a Hampton Bay ceiling fan. It stopped working. all the wires appear to be attached except the green wire (ground), it is attached to the mounting bracket, but no where on the other end. Could this...
The green wire is a safety ground. Leaving it unconnected is not good from a safety standpoint, but it would not keep the fan from running.
If this Hampton Bay fan has a remote control, and if you have good batteries in the remote, then you most likely have a failed receiver in the fan. I had one of those to fail at my house, so I replaced the receiver and it failed again in less than a year. Then I got a different fan.
Be sure to turn off the breaker before you poke around in the fan; don't rely on the wall switch alone for safety. Good luck!
Feb 28, 2010 | Hunter Ceiling Fan Light Remote Control
Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Aug 21, 2009 | Hunter 52" Ceiling Fan With Light And...
The Hampton Bay Altura Ceiling fan functions only with remote.
I contacted the manufacturer (kingofffans.com) after my Altura fan would run on high speed only and the remote would not control any thing. They said their was a manufacturing defect with a capacitor that affected many of the Altura fans. We are now on a waiting list for a new capacitor and housing, because they did not have enough replacement parts.
Nov 26, 2008 | Hampton Bay 52 In. White Redington...
Remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Jun 05, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
May 30, 2008 | Hampton Bay 52 In. White Redington...
Remote control fan hampton bay
Just insalled a hamptonbay fan and everything works except the dimmer. Light comes on on wall switch but remote won't dimm lights
Apr 04, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Sharper Image Deluxe Spire SI788SNX Tower Fan Logo
600 people viewed this question
Top Sharper Image Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Sharper Image Dryer Expert? Answer questions, earn points and help others
