Question about Panasonic KX-TG4321B Cordless Phone
Phone getting switched off when speaker is turned on
Hi,  Everytime the speaker is turned on my phone, the phone gets switched off.When I try to switch it on, it says 'Not connected to base adapter'. However, the phone is constantly charged using the base adapter, and there is no reason why it should give me this message on the phone's dial. And it is only after another 2-3 mins that the phone starts working again.
Experts, would really appreciate it if you could help me solve this one!
Thanks! Aradhana
  • 1 more comment
  • ff2wkupp Sep 22, 2010
    I also own a Panasonic 5.8 Ghz KX-TG 4321B and have the same problem!!! Plus the handset will reset halfway into a call
  • anna2682 Sep 22, 2010
    If you have a warranty active on the phone, then you can exchange it (which is what I did). However the problem really never goes away. The only solace would be that you got a new piece in exchange :-)
    Buyer beware regarding Panasonic KX-TG4321B! Panasonic should offer a solution, a replacement or an upgrade if there isn't an easy fix!
  • 3 Answers
(Just received this from Panasonic Support...Thanks Panasonic!) The following might be worth a try.... Resetting Handsets & Base Unit: 1) Unplug AC adaptor from base unit for 30 seconds. 2) Reset handsets by removing/reinstalling all batteries.
Re-register each handset to the base unit by following the steps below:
1. Press MENU, #, 1, 3, 0 on the handset. 2. On the base unit, press and hold the LOCATOR button for 4 seconds until the registration tone sounds. 3. On the handset, press the soft key below OK and then wait until a long beep sounds. 4. Press the OFF button to exit. Situate the base unit in a different location. Change the line mode from A to B or vice-versa by following the steps below:
1. Press MENU on the handset. 2. Press #, 1, 2, 2. 3. Press the up or down arrow key to select the desired setting. 4. Press the soft key below SAVE. 5. Press the OFF button to exit. If the problems persist, your unit is malfunctioning and is in need of repair or replacement.
Posted on Sep 23, 2010
How do you turn the speakerphone on LG S310
Remove earphones/adapter from phone >switch the phone off > plug in earphones or adapter > switch phone back on again. Should do the trick.
Apr 15, 2012 | LG Cell Phones
How to connect multiple phones to voip adapter? Only line 1 is available for connection.
Have you tried using a 5 or 8 port switch to see if this will allow u to have 8 or 5 more phones available ...they do make a 25 switch if you want to add 25 phones
Sep 18, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Everytime when i switch it on, it will starts for only 6 seconds.
hi,your phone battery is not connected to connectors or ur battery is dead.i give two options
1.try to connect the battery & connectors.
2.replace new orginal battery.
thank you.
May 07, 2009 | Nokia 2600
Don't know how to hook them up
What a lovely daughter, how very nice of her,
here goes....straight for Mr. Koss
To Operate with AC Adapter
  1. Open battery compartment located at the back of both speakers and remove wires.
  2. Replace battery covers.
  3. Connect DUAL PLUG CONNECTOR on left speaker to right speaker at connection marked "TO LEFT SPEAKER."
  4. Connect remaining wire with 3.5mm plug to headphone jack on your audio source.
  5. Connect AC adapter (not included) to back of left speaker at connector marked "DC 6V." Plug remaining end of AC adapter into wall outlet. Be sure your AC adapter is built with the center pin as ("-") negative. Connect remaining wire with 3.5mm plug to the headphone jack on your audio source.
  6. Turn ON/OFF switch at back of right speaker to "ON."
  7. Set "INPUT SELECTOR" switch to audio source.
  8. Turn on audio source
  9. Adjust sound in the following ways: Turn volume control to desired level; push Bass Boost button located on right speaker to "ON" for added bass; push Treble Boost button on right speaker to "ON" for added treble
  10. Operating a microphone through your speakers require an additional 3.5mm plug to 3.5mm plug cable (included). Connect cable with 3.5mm straight plug to right speaker at input marked "MIC" on back of speaker. Plug the remaining 3.5mm L--plug into the mic input on audio source. Connect your microphone to the front of your speakers at "MIC" input (microphone not included)
Hope you have all of the skinny you need, good luck,
please leave a rating, thank you kindly
Apr 27, 2009 | Computers & Internet
Cordless phone not connecting to base. no dial tone.
switch the A/C mains off 5 minutes
or
Re-register them to the base,
This resolves the problem
Regards
Richard.
Apr 26, 2009 | Panasonic KX-TG5673 Trio Cordless Phone
Hi there:)
TRY THIS:
call in your provider to change the ssid and the network key
[all computers will be disconnected]
and then try to reconnect them one by one to the new ssid or network name
this should resolve the issue
always make sure that the wireless properties are okay and the same as the router
also check the device manager: network adapters if they are properly installed and no errors on the icon for the adapters. for windows OS[]
Dec 18, 2008 | Hawking (hfs5t-eu) Networking Switch
My laptopwant switch on? its charging but everytime I try switchinbg on it switches off straight away and the charging light flashes orange
I am giving you a step which you should try once and see if it makes any difference.
Method (Power cycle)
You need to remove the battery, adapter and any other device connected to the computer (May be any additional cards or any wires as for Ethernet or speakers or external mouse/keyboard).
Nothing should be connected at all.
Now Press and hold the power button for 25 seconds (It wont show anything). This is a step to release any static charges developed, which may surely caused the kind of issue you are facing.
Now connect the battery and the adapter and check whether it works or not.
Hope this should help
Regards
Sammy
Aug 28, 2008 | Acer Computers & Internet
Bluetooth
my bluetooth device not working. if i try to start it laptop say NO BLUETOOTH DIVICE.so what can i do?
Dec 12, 2007 | Acer Aspire 5100 Notebook
Connecting............
I checked the official vtechphones.com website - they said - unplug the base for 15 secs .. re-seat the battery in the phones - check the power to all bases and once checked wait for 1 min. - I did all this and my phones are currently working again .. if you are still having a problem - you may need a new battery for your phone ..
Dec 09, 2007 | Vtech 5.8 Ghz Handset Cordless Phone...
Panasonic KX-TG4321B Cordless Phone Logo
253 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
