Question about Zanussi ZWD1470W Front Load Washer / Dryer
Machine won' spin
I have a Zanussi and it won't spin. (It got very noisy first) The drum appears to be loose when I turn it.
  • Zanussi Master
  • 3,463 Answers
It sounds as though the main drum bearings have failed.
If you turn the drum by hand and it feels rough or you can feel it grating or rumbling, then the main bearings have gone.
Quite a major and expensive job to put right, you may find it more econonomical to purchase a new one.
Plz rate my comments.
thanks and a merry xmas.
Posted on Dec 21, 2008
I have a similar problem
My drum on my ZWD14270W has stuck solid half way through a wash. i have checked the belt and that was off and hanging on the drive motor but the drum would not budge manually its like the bearings have seized up but there is no leakage of grease from the bearing cage and the bearings look fine to me but i could be wrong. can anyone help me?
Posted on Aug 19, 2010
Spin - loud noise - switched off - drum wont turn
I'm just hazarding a guess here, but it sounds like the bearings have gone (if you try to turn the drum by hand and it sounds noisy and grinding/crunchy then I think it would be the bearings). I'm certainly no expert though.
Feb 02, 2014 | Zanussi Washing Machines
Heavy mechanical knocking on final spin yet drum rotates freely when turned by hand and at low end drum speeds. Doesn't point towards the bearings. I have noticed that drum appears to be rotating slightly...
The knocking is the drum running out of balance due to the drum shaft being worn or corroded, or a worn bearing, a bearing can fail even though it may not sound noisy
Either way it is assoiated with the drum and entails a complete strip down, trust me on this, I do know what I am talking about.
Dec 03, 2010 | Zanussi FC1200W Front Load Washer
Cause of noisy spinning
your drum bearings have gotten water into them from a defective inner drum lip seal,now you need to tear down the machine and replace the lip seal and also replace both inner and outer drum bearings
Apr 18, 2010 | Zanussi ZWF1430W Front Load Washer
Hi there my machine has gone very loud when spinning,washes perfect,any advice
Sounds like the main drum bearings have failed.
Spin the drum by hand from the front of the washer, if it feels rough, or is noisy or rumbling, then the the main bearings have failed.
A major repair!!!.
Jan 15, 2010 | Zanussi Washing Machines
Spinning cycle has become very noisy on fast spin
Hi
The most common cause of this is the main drum bearing seal has failed and water has washed all the grease out of the drum bearing and knackered it. You will hear a loud roaring noise on the fast spin when this has happened. As it's certainly not a 5-minute-job, it's not economic to have this fault repaired on an older machine if you are paying for the repairs yourself. Get a new machine.
It is fairly unusual for balance weights to come loose as they are usually held tight by locking nuts. I've seen it happen but not very often. Sometimes they break off the drum completely. Symptoms of this are loud knocking noises, the machine attempting to leave the building while on a fast spin and a heavy piece of metal/concrete on the floor under the machine!
Thanks for contacting Fixya.com
Oct 11, 2009 | Zanussi FLA1201W Front Load Washer
When my zanussi aquacycle 1200xc is on the fast spin cycle the spinning drum seems to be getting noisier of late.
Probably the main bearings are going, spin the drum by hand, there should be little or no noise at all, if it feels rough, or noisy, then bearings are failing.
Please rate my solution.
Thanks.
Oct 10, 2009 | Zanussi F1245W Front Load Washer
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Aug 28, 2009 | Zanussi ZWF1430W Front Load Washer
    Ariston Margarita 2000 NOISY spin cycle....
    Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
    If it is o/k then check motor for worn or noisy bearings,
    Thanks.
    Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
    Noisy spin cycle
    Hello your problem is the the drum.. To be more precise its the drum bearing.. theses wear out and can be replaced on the zanussi id suggest that you get an engineer out.. its about £100 to get it done
    Dec 15, 2007 | Zanussi F1045W Front Load Washer
    Drum noisy when spinning
    main wash bearing fail parts for this £48 if you are mechanicaly minded then its a 3hr job if you have all the tools appliance doctor
    Jan 28, 2007 | Zanussi ZJD1219 Front Load Washer / Dryer
    Zanussi ZWD1470W Front Load Washer / Dryer Logo
    250 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
