Question about Logitech Wave Cordless Desktop
Damaged connection for wireless usb receiver
My usb receiver was stepped on and now does not give a good connection. can i get a new receiver/thumbdrive?
greg cook
item is cordless desktop wave
Not sure if my problem is solved yet, i did find a receiver that can be purchased for the desktop wave on logitech.com. i have ordered the item and will see if that cures the problem. part is supposed to be here in 2 - 3 days
Posted on Dec 22, 2008
I bought a gateway zx series computer 3 weeks ago. the wireless keyboard and mouse that came with it has stopped working for no apparent reason. the computer says that it doesn't recognize the device. i...
hi Karnarc.
How do I troubleshoot my Gateway wireless keyboard and mouse? How do I troubleshoot my wireless keyboard and mouse?
If you are experiencing issues with your wireless keyboard and mouse not working properly, perform the following steps to troubleshoot the wireless keyboard and mouse.
  1. Make sure the USB connector from the receiver is properly plugged into a USB port on the computer. Some systems ship with the receiver already preinstalled in the unit itself. Please check your mouse to see if there is a receiver inside of the battery compartment door.
  2. Make sure wireless keyboard is not on a metallic surface.
  3. Ensure that the receiver is 8-inches from other electrical devices.
  4. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
  5. Check the batteries in the keyboard and mouse to make sure they are installed correctly.
  6. Test the batteries to ensure that they still have a charge.
  7. Verify the On/Off switch on the keyboard and mouse are switched to On.
  8. Some receivers, keyboards, and mice may have a connect button. If so, follow the steps below:
    1. Plug the USB receiver into a USB port on your computer.
    2. Press the connect button on top of the receiver and the button will blink.
    3. Press the connect button on the bottom of the keyboard to activate the wireless connection.
    4. Press the connect button on top of the receiver and the button will blink.
    5. Press the connect button on the bottom of the mouse to activate the wireless connection.
Dec 03, 2017 | Gateway Computers & Internet
Hello my GE ergonomic wireless mini mouse #98564, connects with my computer sometimes and not others. Currently it will not connect, it has new batteries, dings when the card is inserted into port, but...
I have been fighting with several of these GE Wireless Mice. Pressing the connect buttons on the mouse and USB receiver would not re-connect the mouse. As some ohere posting have pointed out, that little white circle on the usb plug shows where to squeeze to trigger the receiver to re-connect. When you've squeezed correctly, the red LED in the USB pug starts flashing brightly - not a dim flicker. You are supposed to then press the connect buttom under the mouse. Immediately the flashing LED on the receiver should go off, and your mouse should be ready to go. Each time you move the mouse, the same LED in the USB plug should flicker to show activity.
I have tried all this so many times without luck. Even replaced the mouse batteries several times - from the same pack.
Here is my 'FIX'. I think this mouse is very tight on the voltage it needs from the batteries. You need absolutely brand new, full power, good shape batteries. Bateries that look OK in another device, might not work in this mouse.
If you have a test meter and know how to use it, find a couple of batteries that are giving at least 1.6v each - more if possible. Pop these in, do the connect process above, and there is a good chance it will connect up fine.
Good luck.
Oct 20, 2010 | GE Wireless Optical Mouse
How connect a wireless mouse
Typically a wireless mouse will have 2 parts to it: the mouse and a receiver unit. The receiver unit will plug into your PC with a USB cable. On your mouse there's usually a connect button (or called something else that's usually intuitive), and sometimes on the receiver unit as well.
Plug your receiver unit into your PC using the USB connector.
Make sure you have a good battery in the mouse. Press the connect button on the mouse and you should be good to go.
If this helps please give me the appropriate thumbs up rating. Thanks and good luck!
Aug 13, 2010 | Computers & Internet
Unable to connect wireless deskset to my computer.Is there a specific USB receiver required
1st Step: Have you inserted the USB dongle which is came along with the product. Also check and install drivers for the same.
2nd Step: Go to device manager and check the USB status, Also install drivers for USB if required.
3rd Step: Synchronize the USB dongle by pressing the button which is on the Dongle.
Revert back for more assistance. Also give your valuable feddback and rating on the solution.
Feb 07, 2010 | Computers & Internet
Wireless USB works, but mouse itself doesn't
Sir/Mam good day,
Is your mouse device also wireless? you need to resync it with it's receiver,
you may follow the methods below to make your wireless usb mouse works.
You need to press the button on your wireless mouse receiver, and make sure that the light on your wireless mouse
receiver blinks. But you need take note that some newer model of microsoft devices are permanently fixed to their receiver
and can't be reset. If your devices don't have a button, here's what to do:
If a dialog box appears on the screen in how many seconds, you need to follow the instructions from it. Or else, you need
to do this:
press and release the connect channel button on your wireless mouse, and make sure that the light from your receiver works
and the status on it's light is steady. If this happens then the synchronization is successfu. But if the problem is still
the same you need to repeat the previous steps once again.
As for the wireless mouse for notebook, this problem come out when the micro switch on the underneath of the mouse was not
released. You can use a pencil or anything with a sharp point to released it.
There are a lot of options why your wireless mouse receiver won't work, and a lot of solutions. Here's some of them:
*Try different ports on your computer, if the connection to some usb ports are not working you can connect to other ports
and see if it will work.
*And also the cables that are included with the wireless receiver, try to use another cables if the
device is still not working.
*If you're device is connected to a usb hub, disconnect it from the usb hub and directly connect it to
the available ports on your pc and see if it will work.
*When fixing this type of problem you need to have only one usb device
connected to your computer, which is in this case, your usb wireless mouse.
*When you have other usb devices, you need to
plug it out.
*If the methods mentioned previously still won't work, you need to reinsert your
wireless mouse batteries or install a new one.
*Another possible remedy to this problem is checking the interference, your wireless
usb mouse together with its receiver should be a distance away from anything that
transmits signals such as cellphones, radios or other similar devices. And also
any metal objects. because such things might interfere with the signal of your
wireless mouse.
* If the problem persists after doing all of the above steps, maybe it's time to update
your wireless mouse drivers, For installing latest driver update with your wireless
mouse, see the documentation that is included in your wireless mouse.
* If all of the methods above did not solve your wireless mouse problem. You can
connect your wireless mouse to another working computer to see whether the problem
lies with your wireless mouse or to the computer which your wireless mouse is
connected.
Final instruction:
If all of these methods fail, you better have your wireless usb mouse be check
by a professional computer technician in order not to further damage your device.
Hope this helps. Good luck and God bless
http://online-pcrepair.blogspot.com/
Jan 11, 2010 | Silver Jeans 1660-13SL Mouse
We have a wireless keyboard and mouse and it seems that something between them and the computer is slow or off. we type and only a few letters appear..the mouse seems to be ok just kinda slow ofrom when...
Most likely you need to re-sync the device
  1. Resynchronizing the keyboard and/or mouse causes the devices to reconnect to the receiver using new identification numbers. Use the following steps to resync the devices:
    NOTE: The following connection sequence must be completed within 60 seconds. If the sequence is not done in 60 seconds, start over.
    1. With the receiver plugged in, press and hold the Connect button on the receiver until the activity LED flashes.
      NOTE: Some HP computers have receivers built into the front of the computer; such as TouchSmart 700 Series PCs and Digital Entertainment Centers. Look for a small connect button built into the case. If you have a TouchSmart 500 or 800 Series PC, the receiver plugs into a USB port on the underside of the case and does not have a connect button - skip this step. Figure 4: An example of a receiver c01065862.jpg 1 - Connect button and LED activity light Figure 5: Another example of a receiver c00526313.jpg 1 - Connect button 2 - Num Lock LED 3 - Alpha Lock LED 4 - Scroll Lock LED 5 - Activity LED
    2. Press and hold the recessed connect button on the underside of the keyboard until the activity light on the receiver stops flashing. When you release the button, make sure it does not stick in the depressed position.
      NOTE: If problems persist after resetting AND there is another wireless keyboard or mouse near, use these steps again, holding down the keyboard or mouse button for ten seconds. Doing so may give the keyboard or mouse a new ID number in case the other keyboard or mouse was using the same number.
    3. Press the Connect button on the receiver again until the activity light flashes.
    4. Press and hold the recessed button on the underside of the mouse until the activity light on the receiver stops flashing. Make sure the connect button does not stick in the depressed position.
  2. If your mouse and keyboard have a USB receiver, unplug the USB receiver, wait 10 seconds, and then insert into another USB port - preferably into a USB port that is closer to the mouse and keyboard. For example, if the USB receiver was plugged into a USB port on the back of the computer, unplug it and plug it into a front USB port.
Hope this helps!! Good luck!!
Sep 17, 2009 | HP Wireless Optical Mouse
Ps3 will not reconize intec in any way wireed or wireless. just invisible
CONNECTION A:
DO NOT INSERT BATTERIES INTO THE CONTROLLER; THE USB CABLE USED WILL SUPPLY THE POWER TO THE CONTROLLER.
STEPS # 1 – TURN THE POWER ON TO THE PS3 CONSOLE.
STEP # 2 – CONNECT THE USB CABLE TO YOUR PS3 CONSOLE AND CONTROLLER.
STEP # 3 – NEXT PRESSE THE SYNC BUTTON ON THE CONTROLLER, THE CONTROLLERS LED INDICATOR’S LOCATED ON THE FRONT OF THE CONTROLLER WILL START TO FLASH RAPIDLY.
STEP # 4 – CONNECT THE USB RECEIVER TO THE USB PORT ON THE PS3 CONSOLE.
STEP # 5 – WHEN THW CONTROLLERS LED INDICATOR’S LOACTED ON THE FRONT OF THE CONTROLLER START FLASHING SLOW PRESS THE HOME BUTTON.
WHEN THE CONTROLLER HAS ESTABLISHED A CONNECTION BETWEEN THE CONTROLLER AND THE USB RECEIVER ONE OF THE CONTROLLER’S LED INDICATOR’S WILL BECOME SOLID RED.
Jul 12, 2009 | Intec PlayStation 3 Turbo Shock III...
Usb mouse not working on new laptop, was then all of sudden just quit
Is this a wireless mouse? If yes, you need to isolate the problem. Please follow the steps below:
1. Use fresh batteries.
2. Connect the wireless receiver/dongle into different USB ports of the computer.
3. Make sure that the mouse is turned on and then try to reconnect the mouse to the receiver by briefly pressing the connect button on the receiver and then hold down the connect button on the mouse.
Hope this helps and have a great day!
Jun 29, 2009 | Microsoft Wireless Notebook Optical Mouse...
Wireless keyboard not working
well,the problem is small,,first check with a different set of batteries on the keyboard,after tats done,press the connect button the wireless receiver and after 5 sec on the connect button on the keyboard,if the connection to the mouse gets disrupted then press the connect button on the mouse.the last step u can try changigng the usb port of the receiver,,,i beleive there is no other troubleshooting steps to this issue,,if still no go,,call up tech support and replace the whole set
best of luck,,keep me posted ,giv a good rating
May 19, 2009 | Computers & Internet
GM323AA HP Optical 3 Button Wireless Mice I got from somebody is not coming on. Can someone give me step by step instruction on how to wt up mouse after putting batteries
I have the same mouse. Make sure batteries are good. Then plug in the usb receiver. On the receiver, press the green led light, then press the connect button on the underside of the mouse. they should connect.
Apr 03, 2009 | HP GM323AA Mouse
Logitech Wave Cordless Desktop Logo
300 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
