Question about LG LW1200ER Air Conditioner
Ruud achiever 90 plus gas furnace not blowing any heat
Any ideas? There is air blowing through the vents, but it isn't hot!! Please help!!
  • kim_wilborn2 Mar 20, 2009
    My furnace pilet light is lite, but will not kick on for heat to come out. Fan works and everything else. What can be wrong? Please help im a single mother of 4 kids and very low income.
  • 69 Answers
These new furnaces are trouble. Ive been in the htg trade for 25 yrs. The fan is running because they are now controlled by a timer instead of a temperature control. Rather than sensing a preset temperature and turning on the fan, it comes on by a preset time. Couple of things, does either of the doors have an inspection window? most newer furnaces have what is called a smart board. The board will flash a trouble code. ie: 1 long 2 short etc. #1 turn your thermostat to off, youll need 2 people for this! Go to the furnace, If it has the above mentioned inspection window ( usually about 2" round) while peering through the window have someone turn the thermostat to about 80 degrees. Let the furnace cycle and see if it flashes a code. If it does the codes are usually on the bottom door, May be on the inside. The most common cause is either a bad transformer, bad hot surface ignitor or pressure switch failure. Further questions feel free to ask. Steve
Posted on Dec 21, 2008
I have a 2003 Tahoe and when I put the heater on only the driver side get warm passenger side blow cold air
2004 Chevy Tahoe. Hot air out of vents on driver's side, cool ...
answers.edmunds.com > Edmunds Answers
Jun 25, 2009 - Hot air from vents-driver side and cool air from vents on passenger side. ... The driver's side vents were blowing out hot air, and everything else wasblowing cold. ... you'll literally have to restart your tahoe/yukon at every traffic light to keep cold air coming ... I was also getting air only out of the defrost vents.
Hot air out front drivers side vents 05 escalade - YouTube
? 3:14
https://www.youtube.com/watch?v=5lnd8UNcx6M
Aug 3, 2013 - Uploaded by South FL Mud Club
Suddenly hot air started blowing out the air vents only on the drivers... ... is a very helpful video ,I wondering if this part number apply for my 04 chevy tahoe? .... I have cold air out of thepassenger side, but warmer air out of the driver's side. .... 2003 Tahoe No Rear Heat Fix, Suburban, Yukon XL Repair!
Heating and AC Temperature and Air Delivery Mode Door ...
repairpal.com > Problems > Chevrolet > Tahoe
Driver/passenger air vents blow hot then cold when using A/C. Back to cold when you restart the vehicle. Upvote (35) ... 2003 Chevrolet Tahoe ... I have a 02 Tahoe ,and the heat system is working only on the ceiling side of the car when turn.
2004 Chevrolet Tahoe Blows Hot Air - Sparky's Answers
Jan 21, 2016 | Cars & Trucks
How to clean clogged condensate drain of ruud furnace achiever 90 plus
You can easily blow through the drain with pressurized air through the p trap. There could be a number of reasons the furnace side is not working. In the case of windy conditions there is a possibility that your pilot will need to be adjusted or the flame sensing rod might need to be cleaned. If the pilot wavers off of the sensing rod it could cut off the heating cycle because the system could not verify a flame yo bring on the main gas valve to continue with the cycle
Mar 01, 2015 | Ruud Heating & Cooling
2004 Honda Pilot hot & cold
Sounds like a blend door problem under the dash.
Jun 25, 2013 | Cars & Trucks
Vents blowing HOT air all the time!
check your vent doors in your dash it appen to my f 150 and closeing them helped from pulling heat from the motor
Apr 30, 2013 | 1997 Mercury Mountaineer
Ruud 90 plus will not blow hot air
My Ruud is a different model, so this may not work. Remove the cover to the burners. Look on the left side for a small rubber hose going to a metal cylinder. Remove the hose and blow through it to remove any moisture. Replace the hose and see if the burners start up.
Feb 23, 2013 | Ruud Rheem Rgfe09ezcms Gas Furnace
Air conditioner
Check whether the warm air isn't going in with the cold air .Coolant line that runs into the firewall on the passenger side of the engine which is toward the bottom half of the firewall on the passenger side. If there is warm air going into the vents with the cold air then it blows warm air. You may have to shut it manually because it gets stuck sometime. Check it out.
Jul 24, 2012 | 2005 Honda Accord
THE UNIT BLOWS COOL AIR OUT THE FRONT BUT HOT AIR OUT THE BACK THE MODEL IS aP076E .i DO NOT HAVE A MANUAL BUT IT DOES NOT SEEM TO BE REAL HARD TO RUN THANKS
Yes, that is the way a typical air conditioner works. The portable types need to have the hot discharge air direct outside via flexible hose and an adjustable window bracket. The window closes on the bracket to create a seal, and the hose connects between the air conditioner discharge and the opening in the bracket. This is called "venting". Most portable air conditioners include (or offer as an accessory) a "vent kit" or "window kit".
Some portable air conditioners do not provide a way to vent - fortunately yours appears to have a kit for this purpose. You may wish to check out this page on venting. It has plenty of ideas and suggestions for venting. This site has some very good pictures to document making a vent - and is worth a look, too.
If this was helpful, please rate it "4 thumbs up" - thanks!
Aug 02, 2011 | Amana Heating & Cooling
My outdoor AC unit is not coming on. Air is blowing out of my vents inside but the snowflake symbol on my thermostat is blinking and the air isn't cold. The fan on the unit isn't even running. Any...
check power to outside unit, check if it has a fused disconnect, if you have power and no blown fuses it could be a blown capicator that starts the fan and compressor...............
May 09, 2011 | Heating & Cooling
LG LW1200ER Air Conditioner Logo
747 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
