Question about Mitsubishi WS-55809 55" Rear Projection Television
WS-55809 with Universal Remote
I lost the original remote and is using a universal remote but then when it come to adjusting the color convergence, I can only adjust the center convergence and can't adjust the convergence at the corners.... any help beside buying a new remote?
  • andy_tan_oth Dec 22, 2008
    Thank you very much..
    Cheers
    Andy
    Sergeant:
  • 233 Answers
You will have to get a new mitsu remote in order to make the adjustment. Most universal remotes are made to just do basic functions, unless you start getting into nice sony touchscreen remotes but then they cost 100 by themselves.
the remote to a mitsubishi wd55513, wd65513 etc will also work on this set, I have done it before.
Here is one on ebay:
http://cgi.ebay.com/MITSUBISHI-TV-BIG-SCREEN-REMOTE-ORIGINAL_W0QQitemZ190275200565QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item190275200565&_trksid=p3286.c0.m14&_trkparms=72:1234|66:2|65:12|39:1|240:1318|301:0|293:1|294:50
Posted on Dec 21, 2008
I don't have the remote for a Samsung rear
Go looking for a used remote--I have one I hang onto for just convergence alignments on their sets--no universal will cut this.
The original remotes among other things had a data button to save the adjustments.
May 29, 2012 | Samsung Televison & Video
Can't adjust color, brightness, etc. w/universal remote
Use the MENU on the front panel display of the
TV
Jan 06, 2010 | Televison & Video
Red green color convergence issue. original remote control is broken. can't access menu screen with universal remote.
If you do not have menu button on front Press and hold at same time CH- & CH+ this should let menu come up then use Vol- VOl+ to adjust and CH- CH+ to move up and down menu
Dec 21, 2009 | Philips 43PP9202 43" Rear Projection...
Where are the covergence controls in ws55809 tv located
All convergence adjustments on this set are done with the original remote control--you will find the CONVERGENCE in the customer menu---if set will not adjust there you have a circuit problem.
I have fixed hundreds of these sets--if it will not adjust let me know and I can tell you what is needed to fix it.
SD TECH
Dec 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Color is off on my tv im seeing colored shadows how do i reset that without a remote
YOU need a Mitsubishi remote to do any convergence adjustments--if convergence is skewed or bad it is most likely it will not adjust back.
WS-55809 uses two of the STK-392-570 CONVERGENCE CHIPS--95% chance both will need to be replaced and the set adjusted with the remote.
If you can do this you can save a lot of money and the set---most shops are going to get at least 300 for this kind of repair---you can buy a pair of the chips on Ebay for under 13 dollars plus shipping.
I HAVE STEP BY STEP, START TO FINISH INSTRUCTIONS FOR DOING THIS REPAIR ON THIS MODEL--IF you think you or someone you know can do it let me know and I will post the instructions here for you.
This is a common problem on ALL projection sets--the chips have a metal back and are mounted on a large metal heat sink on the middle board--a white grease--heat sink compound is applied to the back of each chip to move heat quickly to the metal and after several years from the heat it has dried out and one of the chips goes instantly.
If the set is repaired it will not have this problem for 5-8 more years----lifespan on these chips.
If you need help let me know and if this information has helped you, rate this solution as I DO THIS HERE FOR FREE.
SD TECH
Nov 09, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Distorted picture
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Cant fix the color
Hi, first thing you need to do is re-post with the model number of your set, sounds like convergence has failed and if so you WILL NEED the original remote and a pair of convergence IC`s, post your model number and I will look up the part numbers for you,
video-tek
Feb 11, 2009 | Samsung Televison & Video
Mitsubishi WS-65809 PIP/POP operation without Remote
you can buy an orignal remote from mitsubishi. they are roughly $68.00 unless you can find a universal remote that will output the correct IR command.
Aug 30, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
174 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
