PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Toshiba Satellite P105-T2050 - DVD pla...
By daisydell_41 on Dec 21, 2008
Toshiba Satellite P105 T2050 laptop - the DVD player does not work at all, the computer does not even recognize the drive. The drive does have power, opens, closes, spins disk, but machine does not recognize the drive. Open to any and all suggestions - thanks in advance!
Comments:
Dec 23, 2008
- More clarification of the problem - when I check the 'Device Manager' the CD/DVD drive does not even show up as an installed item. Yet when you put in a disk, the little light on the drive goes on and off, you can hear the drive spinning the disk, so I know it is physically connected and has power. I hope that this gives more clarification - if not please let me know, and thnaks again for your help.
Clarification Request
Posted by buccswife on Dec 21, 2008
can i have some more info on what it is doing
Same Problem
Dec 21, 2008
-   I have a A75-S206 withthe same problem. The computer recognizes the hardware, I have installed a driver from the Toshiba download site but can't read from it.-   kathleen_oke
Solution #1
posted on Dec 21, 2008
Somewhat Helpful)
crichner
Rank: Wiz
Rating: 80%, 213 votes
You can check the BIOS to see if the drive is recognized and even attempt to boot from the drive using a bootable CD to verify it is functional (if using the Windows disc - just verify it reads - DO NOT REINSTALL)
If the drive works use the following to get the drive back in Windows:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Was this helpful?
Yes
No
Solution #2
posted on Aug 04, 2009
Not Rated)
rocketman2K
Rank: Wiz
Rating: 82%, 107 votes
Hi, check if hardware detection of drive in bios is ok, you may have to set detection to auto.
If that works, boot up properly, reinstall drivers.
It also may be that the power supply is working but the internal data-cable has become loose.
This means opening up the laptop, removing the drive and reattaching it to the mainboard
If You aren*'t a 100 percent sure what you're doing, refer to manual(paper or data) first, then proceed.
perhaps u can locate your laptop's manual here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
(the T2050 is pretty new, i don't know if toshiba already has downloadable content for it)
good luck
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
How to apply this layout on my account?
Answer
i want to bye the best performance laptop on the market, with the state of the art hardware, 15in... (More)
Answer
I press the power up button and the LCD wont light with windows screen. All battery and AC in and... (More)
Answer
Hello all, I'm trying to copy a wii image from my pc to a DVD. Can I do that with this computer?.... (More)
Answer
serial cable using irda code 43 receiving the above message & the remote control for my... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
