Need to disassemble the unit.
I am trying to remove the casing from ths product, but finding it difficult to do. It seems that the large tires also need to be removed, but with finesse. Once I remove these tires I can get at the screws on the lower part of the case. The TV fell of a dresser, and it seems that the power cord has been pulled out from its connection internal. This is why I'd like to skin the unit so I can inspect what's going on.
thanks for you help in advance.
Disney Cars TV\DVD Combo:
The lug nuts on the tires are plastics caps that hid three screws I was looking for to remove the tires. Once I removed the tires there were 2 screws on each side that I needed to undo and the chassis was gently nursed off.
Upon open the chassis I noticed that the plug wire had a harness on the "business end, it it was disconnected from the circuit board where it "plugged in". Once I plugged it in and then teste to see if the set would turn back on everything was working fine.
Posted on Dec 22, 2008
How to Disassembly Samsung SCX-4521FS Multifunctional Copier Scanner Unit?
Dear
to release the fusser assy. you need not to open scanner unit. open the right side cover where smps/mpba are do disconnect all connectors of the fusser assy., unscrew 4 screws (2 at left side and 2 at right side),pull toward you
Thanks and Happy new year 2015.
Dec 27, 2014 | Samsung Office Equipment & Supplies
Front tire won't come off
Sit on your but and kick the tire with both feet. The tire is stuck. Some tire repairmen use a large sludge hammer and hit the tire,don't hit the rim.
Sep 01, 2012 | 1992 Ford Festiva
Oil leak from transfer case. Waht is it and the location? is it a difficult repair?
Depends what's leaking. If it's a shaft seal, the shaft needs to be removed and the seal replaced. If it's the case gasket, the entire unit will have to be removed and disassembled.
Mar 13, 2011 | 1997 Dodge Grand Caravan
Harmonic thread
We are assuming that you are talking about take off the harmonic balancer, you need to know that probably allow 2 hours in case you run into any issues. The only special tool you're going to need is a crankshaft holding tool, usually parts stores like autozone have them available for rent, which will hold the crankshaft pulley so you can loosen the crankshaft bolt and remove the pulley (it's not really a balancer on a Honda)
There's a special tool that holds the crank pulley while loosening the bolt. I use a 3/4 inch impact gun which has more torque when I can't loosen it with the 1/2 inch impact gun. Another option is to use a 1/2 inch breaker bar with a pipe over the bar to act as a cheater, and if that doesn't work you can try setting it against the frame or ground while tapping the ignition. If doing so be sure to disable the coil so it won't start of course.
You first need to lift the car off the ground like your changing the tire(get it on a cherry picker if you can for easier access). Take the tire off, loosen the tensioner on the alternator, and get the belt off. Take a 11/16"ths shallow 1/2" socket and a 14" or larger steel pipe for torque because this bolt is very very tight and can easily break your tool. There are a few impact guns to take it off.
According to my manual you can push a large screw driver in a hole near where the speedo cable connects to the gear box to lock the flywheel. I found I had to remove a small bolt to get the hole large enough to fit the screw driver in. A small piece of casing broke and it became very easy to lock the flywheel. The bolt came undone with a socket and a 30 in bar. I don't think the missing casing is going to make any difference.
Fig. 10: On all engines except VTEC, the belt adjuster arm must be locked in place using one of the lower cover mounting bolts
Fig. 13: The balancer shaft must be held in position during timing belt installation
Good luck and hope this helps.
Feb 02, 2011 | 1992 Honda Accord
While shaving, I start into stubble and the sound (almost like the speed) ratchets up and doesn't seem to want to cut.It doesn't seem to want to get better until I approach very slowly with very light...
I would speculate that the oscillator on the swivel frame is broken making it difficult for the blade to move correctly. If tis is the case, you will need to replace it. You will find this part at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
For disassembly help, see link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
Jan 22, 2011 | Braun 8585 Electric Shaver
I posted a problem in which my monitor was cycling on and off. I have been told that it is apparently caused by blown capacitors, probably in the power/inverter board. But how do I get in to try to fix...
davagain, Just now saw your new post above. If you are intent on delving inside your unit, let me caution you to be very careful in doing the disassembly. Above all else, you must take care to not do more harm than good!! That said, you should try to find and view some video clips on youtube that will demonstrate LCD monitor tear-down. The ones that are >8 -12 min run time should be of help in your quest to "PART" the rear cover from the front BEZEL which holds the LCD panel. Right now you are at the most difficult and dangerous STEP!!! Use extreme caution in any further disassembly procedures. There should be no need to remove panel from the bezel. If digital camera is availiable use it to do your DOCUMENTATION of how things came apart so you can reassemble without having "LEFTOVER" parts. Good luck guy. Do you have a large magnifiying glass to inspect soldering of the printed circuit boards? get back to me with results of inspection. louie12fix or lmistyrel @aol.com Bye for now.
Sep 29, 2009 | Envision EN-7220 17" Flat Panel LCD...
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Lite-On LVW-1105HC won't record, often fails to read disc.
Judging from product reviews it seems that this is a fairly unreliable unit. About the only thing you can do to possibly improve performance is to clean the laser lense. There are commercially available cleaners for CD/DVD players. The best way to clean the lense is to disassemble the unit and use a cotton swab with alcohol. This may be difficult for someone who doesn't have experience disassembling electronic devices.
Dec 31, 2008 | Lite On LVW-1105HC DVD Recorder
Disassemble
This is very difficult to do and most electronics service centers will even recommend sending the unit to Pioneer. You'll not only have to remove the outer case from the hide away unit, but you'll need to take out the main circuit board as well. You may also be able to find someone selling just the hide away unit on ebay too.
Aug 10, 2008 | Pioneer AVIC-N1 Car DVD Player
Compaq Presario 12XL414
I've taken apart a few laptops and they are all very different and all very difficult to take apart. You would most likely need to completely disassemble almost every single component to remove the motherboard. Why do you need to remove the board? I want to warn you away from even trying unless absolutely necessary because if you need help getting started with this project, the chances of you removing the MB and ever having the laptop operate again are slim.
Jul 07, 2007 | Compaq Presario 12XL402 (470009-029) PC...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
