Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
I am trying to remove the Filter on RS265LABP but it wont come off
  • 69 Answers
Why wont briggs & stratton 173 cc Engine yard man walk behind mower wont start when hot
Try replacing filter element. May swell when hot causing loss of air.
Check with Partstree.com 877-970-2662. They may have an answer for you.
Jul 17, 2014 | Briggs & Stratton Garden
RS265LABP freezer works but fridge doesn't.
if the evap fan motor isn't running then most likely this is you rproblem
Nov 25, 2011 | Samsung RS265LABP Side by Side...
Where is the water filter located and how do i replace it.
The water filter is located in the fresh food or fridge side of the appliance, at the rear - in the upper right hand corner.
To change the filter, open the fridge door, clear the top shelf and grasp the filter. All that is needed is to turn the filter to the left about a 1/4 turn for it to drop down. A few drops of water may spill onto the shelf. To install a replacement, remove the protective cover (shown as a red cap above), and position under opening for filter. Gently push upward while turning the filter to the right. The filter will pop in, and as you turn about 1/4 of the way around, it will be drawn up a small amount until seated. At this point it will no longer turn any further.
More info about the filter is below (taken from the manual).
Please rate this reply - thanks!
The water "Filter Indicator" light
• "Filter Indicator" light lets you know when it is time to change your water filter cartridge. The light
will change from green to orange. This tells you that it is almost time to change the current cartridge.
It is recommended that you replace the cartridge when the light changes to red. (see "Install the water filter" section for more information)
• If you install water filter, throw away the first six glassfulls of water filter, or until water flows clearly to flush impurities in the water supply system.
Using the dispenser without the water filter
• You can not use the water and ice dispenser without a water filter cartridge because the water line
blocks at water supply.
Ordering replacement filters
• To order more water filter cartridges, call 1-800-SAMSUNG and ask for accessory Part # DA29-
00003A or contact your authorized Samsung dealer.
Jan 04, 2011 | Samsung RS265LABP Side by Side...
Inside of the refigerator keeps freezing up on the corals
Let me get you the manual because ion one page you have as your model number RS265LABP I will send you a copy and lets see if we can force defrost, Sea Breeze
Jan 04, 2010 | Samsung 26.0 Cu. Ft. Side-by-Side...
FILTER LEAKS!
go to the hardware store or even a home depot or lowes and get some plumbers pipe dope........a small tube will be plenty. remove the filter and dope up the areas where the two components hook together. it is magical.
May 20, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Freezer not working
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
May 12, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
The fridge wont cool down
check to see if the freezewr evaportor is frozen up. you have to take the panel off inside of the freezer to see that all of the ice is gone,. but be carefull becaquse theres stryofoam inside that acts like a air duct to channel thee air across the coil the right way.
Mar 19, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Ice Maker Not Dispensing
I have fought with ice makers before and I find it to be easier when considering the time and trouble dedicated to troubleshooting and frustration of not having ice when you want it, to just replace the unit. You can purchase a replacement Ice maker for your fridge on-line for $85.00 plus shipping and handling. At the most you will have to remove 3 screws and unplug one electrical connection (please remember to unplug your fridge before attempting replacement) and your ice troubles will be over.
Feb 22, 2009 | Samsung RS265LABP Side by Side...
Fridge evap freezing over
A friend had a similar problem; he found that the compressor was
getting overheated. He fixed an axial-fan inside the control box
to keep the compressor cool, and things worked out OK.
Nov 28, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Refrigerators Logo
44 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
