Question about Toshiba 36AF41 36" TV
No vertical deflection Toshiba model #CF27H40, need schematic
Horizontal line across middle of screen
  • 51 Answers
If this is a CRT television, replace all electrolytic capacitors in the vertical circuit - this fixes 90% of all vertical deflection problems. The capacitors most likely t0 fail are low-cap, high-volt such as 3.3 uF at 50 volts, etc. Quicker and cheaper to replace them all, rather than tracing it down to the one bad part. Total cost if you do it yourself is about $15 tops, and make sure you install them correctly - electros have a plus and minus lead, and must not be installed backwards or you'll have serious blow-upage of the new parts. Before replacing the caps, however, go over all solder joints in the vertical section, reheat them and add a touch of fresh solder. You may end up not needing to replace anything.
Posted on Jan 02, 2009
My screen has one line going across the middle.
The problem is a vertical deflection issue, caused by bad connections on the vertical deflection ic, or needs to be replaced and one or two bad capacitors.
Mar 17, 2011 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Line across middle of screen, rest of screen black
The problelm is a defective vertical deflection system. Could be the amplifier, vertical output driver or whole printed board that supports the vertical deflection activity. It is considered to be a serious failure.
The cost of repair will be around $200 to $300.
Aug 05, 2009 | Hitachi 50UX58B 50" Rear Projection...
How do you fix a white horizontal line across top of Orion TV?
Hello eatkinson,
This denotes a problem with the vertical deflection circuit. This is more then likely the result of the vertical coupling capacitor failing. You will need the schematic diagram of the TV to find the capacitor in question. it is located between the vertical output stage and the vertical deflection winding of the yoke transformer. In addition check the continuity of the vertical winding of the yoke transformer this can cause the same problem. In any event the problem is that the vertical deflection signal is not getting to the yoke transformer or the yoke transformer is malfunctioning.
I hope this helps,
Thank you,
Apr 08, 2009 | Orion1934 19" TV
Horizontal Light Only
If you have a straight horizontal line in the middle of the screen the vertical deflection has gone out. Itll need to be repaired, the vertical deflection IC is bad. Hope this helps.
Dec 12, 2008 | JVC AV-27020 TV
Toshiba 32A14 horizontal line
This symptom is characterized by a thin horizontal line in the middle of the screen. This symptom is caused by the absence of the deflection sawtooth current in the horizontal deflection coil.
The trouble is easily isolated by a continuity test and by checking the most likely defective components such as A)open vertical linearity compensation transformer, B) open capacitor and C) open horizontal deflection coil.
Be sure to decrease the brightness first before trouble-shooting if the line is very bright,as it burn the phosphor screen..
Hope this may help;
Aug 19, 2008 | Toshiba 32A33 32" TV
Toshiba 32A40 32" TV Problem
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
Jul 13, 2008 | Toshiba 32A40 32" TV
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
POP and noothiing
yes it can still be fixed! the pop sound you've heard maybe came from a blown capacitor in the vertical deflection circuits. this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 10, 2007 | RCA E13309 13-Inch Diagonal XL-100 Color...
Toshiba 36AF41 36" TV Logo
159 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
