Question about Sony Handycam DCR-TRV480 Digital Camcorder
Sony DCR- TRV480 camcorder
I am having a problem with the date/time. When I record, the date and time don't show up. I've set and reset the time and date a million times but it still won't show up on the touch panel or in the view finder. it's there for the first 5 sec when I turn the camera on. It's available on the screen in play/edit mode only. When I capture the video caught, the screen in Adobe Primere says it can't detect the scenes because the date and time were not recorded on the tape. I've been using Hi8 tapes. PLEASE, PLEASE HELP ME!!!!!!!!! Thanks.
  • 10594 Answers
SOURCE: Compatability issues with sony handycam DCR-TRV480
Click Sony Support and download Vista updates for DCR-TRV480 camcorder.
Posted on Mar 27, 2009
  • 2976 Answers
SOURCE: battery doesnot work
Charge it for a full 16 hours before using it. If it still doesn't work, get it replaced. If that doesn't fix the issue, you have either a charger or camera problem.
Posted on Apr 25, 2009
SOURCE: Time/Date stamp doesn't show up...
this camcorder has a built in rechargeable battery for the memory of the date and time, if you do not use it for more than three months, it will discharge all the way; to recharge, you need to plug camera with ac power for 24 hours and the camera turned off. this should charge the internal battery complete.
Posted on Oct 08, 2009
  • 4 Answers
SOURCE: I am having a problem with the date/time. When I
You have to set the camera up properly in the menu whilst in video mode. There is a setting in the record menu to enable time and date recording.
Posted on Nov 06, 2009
SOURCE: where i can get the usb driver DCR-TRV480 for
try this site
Posted on Apr 22, 2010
larry james
  • 286 Answers
SOURCE: pc does not recognize sony digital 8 DCR-TRV480
I always use ulead software otherwise you could have a digital interface problem . Is there a comp usa ,frys or similar place you can take your camcorder to to hook up and test it?
Posted on Apr 23, 2010
Testimonial: "good suggestions"
0 characters
1 Points
Time date stamp dcr trv140. I have this model. The date does not show in the view screen or on the audio output. Just wondered if any did on this model. Maybe I have a cheaper model.
From the 'Operating Instructions' manual:
"The recording date and time are not displayed while recording. however, they are recorded automatically onto the tape. To display the
recording date and time, press DATA CODE on the Remote Commander (remote control) during recording."
Jul 12, 2014 | Sony Handycam DCR-TRV140 Digital Camcorder
Sony picture package error 110
The above link describes the picture package update that may be available for your camcorder.
Jul 23, 2010 | Sony Handycam DCR-TRV480 Digital Camcorder
How do you put the date on recording
Page 25 of user manual - see link below - explains how to super impose the date and time on the image
Apr 07, 2010 | Sony Handycam DCR-TRV265E Digital...
Mar 27, 2009 | Sony Handycam DCR-TRV480 Digital Camcorder
Changing to correct date on camcorder
To change / reset date and time touch on lcd screen, HOME > SETTINGS > CLOCK / LANG > CLOCK SET and set the date and time.
Above said is mentioned in user manual of DCR-SR42 and you can download it from Sony Support.
Dec 03, 2008 | Sony Handycam DCR-SR42 Camcorder
My Sony Handycam DCR-TRV480 needs to be put in VCR Mode...
our camera is similar to yours, the switch you switch it on with also goes the other way, this is the vcr mode
Nov 17, 2008 | Sony Handycam DCR-TRV480 Digital Camcorder
Sony Handycam DCR-TRV18E
Firstly you need the remote control that came with your camera (RMT-814).
Switch on your camera to VCR mode. Then on the remote, press the Data Code button (and of course, point the remote towards your camera). This should display the date and time in the bottom left of the screen.
It should display the appropriate date and time for each bit of recorded video.
Hope this helps!
Jul 06, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
Need help on setting the date and time when you record it into dvd.
You need to add a data code. put your camera into play/edit. choose MENU>DATA CODE.
Jan 27, 2007 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony Handycam DCR-TRV480 Digital Camcorder Logo
57 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
