Question about Sony Playstation 3 (PS3) Console
My little brother inserted 3 cd's at the same time,hopefully i pressed the eject button and they came out,since that day after turning my console on and playing a game or watching a movie everything looks normal but when i try to put a second cd in i have to turn it off and then insert the cd in order for it to ready it,please helpme.i dont like the idea of turning off my console for it to read another cd
  • 490 Answers
SOURCE: does not read the games or movies
i'd recommend you buy a lens cleaner cd (bout 10 bucks) this should fix it
Posted on May 29, 2009
benwabnick
  • 2404 Answers
SOURCE: Ps3 disc drive not working.
You've done everything I would have done honestly. Take a can of air and blow it into the drive to make sure dirt or dust isn't on the laser which could affect if it sees discs or not.
The better thing to try if you are good at opening up your ps3 and then removing your drive and opening that is to take a damp q-tip with a bit of glass cleaner and clean your laser in the drive gently. Then put the drive back together and hook the cables back up to the ps3. You can leave the cover to the ps3 off for this step. Turn on the ps3 and try different blu-ray, dvd's, music cd's, game discs, etc. If it still doesn't read any of them then either the laser or the drive i bad. If it reads some discs and not others then its a weak laser and the laser would need to be replaced.
If you have to replace the laser or the drive, you can do a search on Ebay and usually find them fairly cheap.
Hope this helps and let me know if I can be of further assistance.
Posted on Jun 21, 2009
LythKross
  • 150 Answers
SOURCE: My PS3 Destroyed a DVD
The second you open that ps3, it will void the warranty completely, so I would put doing that off unless it's a last resort effort. Bringing it in MAY be your best choice.
Posted on Jul 05, 2009
benwabnick
  • 2404 Answers
SOURCE: when i turn console on it doesn't read disk, yet
Sounds like the laser or the drive itself is going bad. If you can get your hands on another new or known working drive, replace it and see if you get the same problem if you do then its gotta be a main board issue then at that point you would have to decide whether you can replace the main board without it costing alot.
You can also buy replacement lasers off of Ebay as well if it turns out to be a laser problem but you have to know what your doing to get the lasers replaced properly.
Posted on Aug 03, 2009
Veritas34
  • 58 Answers
SOURCE: My console doesn't recognize any games or movies
try getting a disc drive cleaner from any local Electronics retail store such as best buy, walmart . If that doesnt work you might have a broken optical lense and you will have to either take apart your console or call ps3 customer support and send your system to them.
Posted on Dec 15, 2009
Disc won't insert into console
Press and hold the eject button for around 15 seconds, this resets the cd drive and will fix your problems. Hope this helps
Correct? a vote and recommendation would be appreciated.
Nov 22, 2010 | Sony Playstation 3 (PS3) Console
The game cd cannot be ejected from the PS3. When the eject button is pressed the red light keeps blinking.
Try the following solution.
Turn the PS3 off with the main switch on the back.
Turn the PS3 back on into standby (red light on)
While holding the eject button press the power button on the front of the PS3. This should initialize a forced disc eject.
Hope this helps and thank you for using FixYa
Aug 19, 2010 | Sony Playstation 3 (PS3) Console
I have a 1996 ford explorer and the 6 disc cd changer is stuck and will not eject, I can hear it trying when I press eject button, any ideas???
good day. well if some kinda stuck you should open it manually. you can find a little hole on the cd changer just use a paperclip then insert it to the hole it will be open manually. and hope that it will not trip right after you put the cds again. hope this helps
Feb 04, 2010 | Car Audio & Video
2 cds in the cd/dvd slot
hello, is the drive now stuck won't eject with the button? if so try using paper clip in the tiny hole close to the eject button. take a paper clip and straighten it and then gently insert in tiny hole keeping straight and leveled, after is inserted in to drive about 3/4 of an inch you will feel little resistance and then gently press it to eject the drive manually.
I hope that what your question was, if not post back.
good luck
regards
Amar Sondhi
Dec 06, 2009 | Dell Studio 17 Laptop
Cd jamed will not eject
Force disk eject. Press and hold down the Eject button on the front of the PS3 for about 10 seconds to force the system's drive to eject. ...
hope this helps ^_^
Sep 13, 2009 | Sony Playstation 3 (PS3) Console
My PlayStation 3 does not eject the CD. Is there a manual way to eject the CD?
try this :Press and hold the eject button for more than 10 seconds. Sony included a trick in the program to force eject. Hope this helps, AJ
May 16, 2009 | Sony Playstation 3 (PS3) Console
Can't insert disc
shake it a little then to eject it put it on its side and press the eject button
Nov 30, 2008 | Nintendo Wii Console
DISC STUCK
Hi Ernie,
There should be a tiny little hole on the front of the CD drive, next to where you would usually press the button to eject it. Turn the laptop off (or at least wait until the CD stops spinning) and insert a straight paper clip into the hole. You will have to insert it perfectly straight and apply a little pressure. Doing this should manually pop the CD tray open.
Hope the helps!
David
Nov 19, 2008 | Computers & Internet
Wii console will not eject disk
I managed to eject a WII disc out manually very easily:
- Disconnect the drive
- You see the white plastic mechanism on your right side and the wheel connected to the motor
- turn the wheel towards the back side of the drive while pushing the half inch square plastic piece towards the left.
You will see the disc coming out while you are turning the wheel.
Nov 25, 2007 | Nintendo Wii Console
Cd stuck
Well, Recently the same thing happened to me, My bro dropped my WII on the floor and the eject button on it got stuck i was soo mad!!!
I tried loads of ways nothing really hard, just follow this and hope fully the WII will eject:
1.Make sure the WII is stood up properly.
2.Then switch on the WII (As i said early the WII won't eject the CD.
3.Now look near the eject button if it is stuck follow (A) or if not coming out follow (B).
(A1).Right if it is stuck and not coming out then the top bendy bit of the eject button put your nail through it and press it down it should eject but after a while it did not work any more for me :(.
(A2).Now, Disconnect all the Cable's in the WII not TV leave it for a while (and don't smash it again!), After a while approx 5 Min's plug 'em back in, switch on the WII then press eject hopefully that will work :D.
(B1).Now if it does not come out either look inside the drive or WII (I don't suggest that) or just do what i did with A2 hopefully that will work.
Hope your WII works by now and enjoy ejecting cd's from your WII but 1 more thing before you go (DON'T BREAK YOUR WII AGAIN OR YOU WILL HAVE TO DO THIS ALL OVER AGAIN :P AND IT MIGHT NOT EVEN WORK IF SMASH IT TO MANY TIMES!!! SO BE-CAREFUL!!!!
Sep 30, 2007 | Nintendo Wii Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
