Question about Brother XR-35
Needle holder fall off machine (Borther XR-46)
This is my wife's machine and she has been unable to use it because the needholder no longer stays attached to the machine.  I noticed that there is a "pin" that seems to provide the friction to attach the holder to a rod hanging down from the machine, but when I try to include it, the holder will not fit on the rod.  A couple of times I was able to get the holder and pin over the rod, but it fell off again after a second or two of use.  Looks like the "pin" may be a little bent and perhaps that is the problem.  I'm looking for either how to fix it myself, how to get another pin that is straight (if that is the problem), or where to take it.  Seems like someone that knows sewing machines (my grandfather was a tailor and spent 30 years on the machines in Brooklyn/Manhatta) would take a couple of seconds to fix it.  I'm all thumbs.
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Posted on Feb 21, 2009
SOURCE: brother sewing machine model XL-6562.needle holder came off rod.n
The needle holder has a screw right above the screw that holds the needle in place. It really doesn't look like a screw because it does not appear to have a slot for a screwdriver. However, with a small flat head screw driver you can tighten it up. There is also a curverd wire that must be inserted into a slot at the bottom of the holder. The screw tightens against the wire that tightens against the post. (It's a curved wire that curves around the front part).
Posted on Aug 20, 2009
e-Guru
  • 3917 Answers
SOURCE: I have a Brother XR-65.
Hi
That's the needle clamp that fell off. Slip it back into place (make sure you have the 'front' facing forward) and while holding it with your left hand, use the screwdriver in your right hand to tighten the needle clamp screw . To tighten, turn it clockwise. Do not apply strong force when loosening or tightening the needle clamp screw, otherwise certain parts of the sewing machine may be damaged. If you look carefully you should see a small allen head screw on the needle clamp assembly. There should be a J shaped part which goes into a hole on the bottom of the assembly. Reassemble everything, put the assembly back on the needle bar and tighten the screw with an allen wrench:-
Also check this link for more useful information:-
http://www.fixsewingmachines.com/How-to-Adjust-the-Needle-Bar-Height.html
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Posted on Sep 09, 2011
mewms_14904
  • 1027 Answers
SOURCE: MANUEL FOR BROTHER XR-46 SEWING MACHINE
Manual for Brother XR-46c
Posted on Apr 13, 2008
SOURCE: Need manuel for XR-46. I am in Kuwait
No, the problem is still not solved because I do not own a XR-65T. I own a XR-46 and all I need is a manual???
Posted on Apr 13, 2009
Broken needle stuck in needle holder stem.
At the very top of the needle, there is a screw that points horizontally to the right. Loosen that screw and the broken needle should fall out.
How To Change Your Sewing Machine Needle
Jan 16, 2016 | Singer Quantum XL-6000 Computerized Sewing...
Needle falls out of my brother se400
you may want to have the needle holder check to see if it needs
to be replaced.
Feb 01, 2013 | Brother SE400 Computerized Sewing Machine
Needle keeps falling
the best thing would be to take the machine to a sewing machine shop & have them check to see what's wrong with the needle holder, cause if there's a something broken it will have to be replaced
May 29, 2012 | Singer 7444 Mechanical Sewing Machine
HI I HAVE A BROTHER XL-5011, the clamp that holds needle in place fell off whilst sewing now it won;t stay on thnxs
needs a new needle clamp screw & possibly the needle clamp too
try sewingpartsonline.com
Jan 11, 2011 | Brother Sewing Machines
Needle holder falls off, won't stay on. It's done this before but stopped for a while. I don't even see what holds it on there. I am so irritated with it.
My husband used a 5/64 allen wrench to reattach my needle holder. There is a small black set screw directly above the screw that you tighten to hold the needle in place. I just looks like a small black hole, but there is a screw in there. Use the wrench to tighten it and you should be good to go.
Jun 22, 2009 | Brother XL-5340 Mechanical Sewing Machine
Apr 12, 2009 | Brother XR-65t Mechanical Sewing Machine
The hook thing falls down
look for the nut in the needle holder and tight it.
Sep 29, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
175 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
