Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ice cream not freezing but making ice - GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
  • 700 Answers
Try turning the temperature down on the freever side. Ice Cream freezes at -10 degrees and water freezes at 32 degrees.
Posted on Dec 21, 2008
  • Todd Born
    Todd Born Dec 21, 2008
    try turning the temperature down on the freever side. Ice Cream freezes at -10 degrees and water freezes at 32 degrees.
My ice cream maker spins but not making icecream
* Ice cream makers are small tub partial filled with cream, sugar, and flavor.
* This cream tub is placed inside a larger bucket containing ice and salt (usually rock salt). The salt makes the melted water almost as cold as the ice. (colder than regular unsalted water)
* Creme in contact with the metal tub gets frozen and creates a layer of frozen creme around the tub.
* The frozen creme is soft due to the fat in the creme preventing the liquid from freezing hard.
* Scraping away the semi frozen cream allows more liquid cream to freeze on the cleaned sides of the inner tub.
* with continuous scraping the cream will form a semi frozen "Milkshake" like thick liquid. It will not harden as the large ice bucket would have melted all the ice by then.
* Remove the semi-frozen cream. Serve immediately or pack in container to continue freezing cream. It should harden when left over nite in freezer.
* Using bucket; https://www.youtube.com/watch?v=o_IFfVdOE2g
* Using bowl; https://www.youtube.com/watch?v=t7aUHywPnog
* Using Ziplock; https://www.youtube.com/watch?v=y-69y9GsS_4
* Enjoy!
Aloha, ukeboy57
Aug 28, 2018 | Ice Cream Makers
How long to freeze bucket
Homemade Ice Cream Freezing Methods - RecipeTips.com
www.recipetips.com/...tips/.../homemade-ice-cream-freezing-methods.as...
Rating: 5 - ‎2 votes
Jump to Ice Cream Maker Using Ice - This type of freezing process is known as a "stir ... Place the covered ice cream can in the bucket, making sure it is ...
equipment - How long do I need to freeze the freezer bowl ...
cooking.stackexchange.com/.../how-long-do-i-need-to-freeze-the-freezer...
Dec 30, 2010 - Is a couple of hours in the freezer enough, or do I need to wait until tomorrow morning? ... This really depends on your freezer and your icecream bowl. Usually ... How to clean ice from ice cream maker bowl without thawing?
[PDF]Frozen Yogurt-Ice Cream & Sorbet Maker - Cuisinart
Jan 14, 2016 | Ice Cream Makers
Can you tell me how this ice cream machine works
The basic old style ice cream maker worked by putting the ice cream ingredients inside the center container and the motor device on top turns the spatulas inside to mix it up. Then you put ice and water and salt in the outer bucket. The ice and salt make it very cold so the ice cream freezes as it churns. Some newer devices, just have a mixer and you put the whole thing in your freezer to make it freeze.
Dec 11, 2014 | Ice Cream Makers
Don't have instruction manual. How do you make basic ice cream in this machine? How long do you freeze container in freezer? How long do you plug in?
Freeze the the container for at least 48 hours before using it. You can use whatever ice cream recipe you like in the unit. Basic vanilla - 3 cups whole milk - 1 teas vanilla - 1 cup heavy whipping cream - 1/2 cup sugar. Mix everything together in a pitcher and make sure the sugar is disolved. Taste it and make sure it is sweet enough for you. If not, add more sugar. If you use 2% your ice cream will not be very thick and it will take longer to set up and freeze.
Put the container in the ice cream maker. Turn it on (insert the plastic mixing blade if it has one) Pour the mixture into the ice cream maker if it has an open space to add mix through the top. If not - put the mix in before turning it on (my model is a little different than yours - sorry!)
when the ice cream is thick enough for you - then its done. It usually takes approx 15 - 20 for soft serve/milk shake consistency - and 30 - 45 for stiffer - ice cream. The ice cream does not get hard - at best its soft serve quality. There are other recipes that you cook which I hear will set up harder but I have not tried any yet.
You can make chocolate by using the same recipe above - and adding any liquid chocolate - or fudge. If you add strawberry preserves - it makes strawberry ice cream. sugar free drink mix added to the vanilla recipe above makes great flavors (crystal light drink power mixes ect)
Jul 13, 2011 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Ice cream machine was making ice cream and now the machine runs but will not freeze the mix it is like a milk shake
a.improper pressure switch setting . b. low refrigerant level. c. TQC needs adjusting. d. faulty solenoid. e.insufficient mix in freezing cylinder.
Sep 06, 2010 | Taylor 632-27 Ice Cream Maker
Wanting to make less than the 5 quarts that it holds, do I just reduce the recipe to the 2 quart instructions, will it freeze with that much less?
Why would you want to do all that work for LESS ICE CREAM???
In my experience, your ice cream maker will make any amount of ice cream up to its capacity. Remember, it is the salt that is the magic ingredient here ... that allows the ice water you are creating to get colder than 32 degrees F. Ice isnt really cold enough to freeze the mixture.
Sep 07, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
Why doesn't the ice cream freeze?
It depends upon which techniques you are using to make an ice cream.
If you are using a maker to make an ice cream then it will take hardly 30 to 45 minutes, not more then that.
For making a delicious ice cream right amount of ingredients should be added and should be mixed in a proper way, if it is not mixed in an appropriate manner then possibly you will not get the real taste that exactly you want.
Aug 14, 2009 | Ice Cream Makers
Ice cream is soupy & when I freeze it it becomes icy
Freeze the bowl for at least 24 hrs, rather than the 12 hrs the manual suggests - it will make all the difference in the world. For really thick ice cream, freeze the bowl for a day, and then put the ingredients in the freezer until the outer rim becomes frozen. Very delicious!
-Tha Mp3 Doctor
Dec 10, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Ice cream has ice crystals in it
Ice crystals are more prevalent in homemade ice cream because it takes longer to freeze the mix. When you can flash-freeze the ice cream to very low temperatures very quickly, there is less time for the molecules to melt and refreeze, which causes crystal formation.
Here are some of the useful tips:
1.) When the ice cream is done, transfer to the coldest part of the freezer as quickly as possible
2.) Pre-freeze the ice cream bowl before using, and pre-freeze the storage container before putting the ice cream in it and into the freezer
3.) Make sure the mix is very cold before using the machine. Maybe put the mix in the freezer for 15 minutes before starting the machine, so that it will finish faster
Hopefully this information helps a lot.
Jul 09, 2007 | Rival 8550-X 5 Quart Ice Cream Maker
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
