Question about Kenmore Elite HE4 Electric Dryer
My kenmore dryer does heat up all the time.
I have looked at several rouble shooting tips ie: there is a distinct click, there is a glow.
More times than not, the dryer willnot give off heat.
  • brautenberg Dec 21, 2008
    would this be the radiant sensor
    Novelist:
  • 161 Answers
After the glow plug starts glowing a sensor detects this bright glow and turns on the gas which will be ignited by the glow plug and you have flames.
So, it could be this sensor or in the gas valve solenoids. You will need an OHM meter to check this.
Posted on Dec 21, 2008
  • Ron Buice
    Ron Buice Dec 21, 2008
    Yes, located next to the glow plug.
My Kenmore gas dryer 110.97566210 works and heats when starting cold, after several cycles, the ignitor glows but the gas valve won't re-open. Is there a high limit sensor? i read a faulty ignitor can...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101=-=-
Aug 05, 2011 | Dryers
Hi, I have a Kenmore gas dryer model 417. I can't
Sounds like the coils on the gas valve are bad.
May 26, 2011 | Kenmore Dryers
Intermittant heating.It will begin to glow....sometimes the flames shoot out for a short time....but then go out. Then, it will continue to glow red without flames igniting,then goes dim....couple minutes...
This is usually caused by faulty coils on the heat valve. they can be purchased seperate from the gas valve and are relatively easy to install..
Oct 27, 2010 | Dryers
I have a LGR5636EQ3 Maytag dryer that will not heat up and the timer is not keeping correct time. Dryer will run but longer than preset time and no heat. No click noise when started. I had dryer set at 60...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 13, 2010 | Kenmore 73952 Gas Dryer
My dryer is no longer getting hot, I can only find a serial number, therefore having a hard time looking up my unit. Serial #MT0514392
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | Kenmore 65942 Electric Dryer
My kenmore elite electric dryer inconsistantly starts to heat and
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
No heat - Kenmore - model 75811
Correct - it is that simple. I just went through the same thing - not even 15 minutes ago. And, they are basically linear motor fields. The drive the cylinder (post they slip over) out, opening the valve, allowing gas flow.
http://fixitnow.com/2004/11/appliance-repair-revelation-burner.htm
May 05, 2008 | Kenmore 74112 Gas Dryer
Kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
Apr 10, 2008 | Dryers
Kenmore elite gas dry 6 years old - no heat
PUT YOUR DRYER ON AIR FLUFF AND TURN IT ON. THEN SELECT A HEAT SETTING. IF YOU HEAR A DISTINCTIVE CLICK WHEN YOU SELECT HEAT, THEN CHECK FOR A GLOWING IGNITOR. MOST KENMORE/WHIRLPOOL DRYERS HAVE A PEEP HOLE IN THE FRONT LEFT SIDE OF THE DRYER. REMOVE A PLASTIC COVER TO VIEW INSIDE.
IF THE IGNITOR GLOWS, AND THEN CLICKS OFF, YOU HAVE A BAD SOLENOID (COIL SETTING ON TOP OF THE VALVE). IF IT NEVER CLICKS OFF, YOU HAVE A BAD RADIANT SENSOR( LOCATED ON THE SIDE OF THE BURNER HOUSING). IF NO IGNITOR GLOWING, THE IGNITOR IS BAD.
IF WHEN YOU SELECT HEAT, THERE ISN'T ANY CLICK, THEN THE THERMAL FUSE LOCATED BEHIND THE BACK PANEL DOWN NEAR THE EXHAUST IS BAD. IT IS A SMALL WHITE ITEM WITH TWO THIN WIRES ATTACHED TO IT.
Apr 07, 2008 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
119 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
