Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
GE PFS22SISBSS Refrig compatment freezing
Items in my refrigerator compartment are freezing (water, eggs, etc)
I raised the temp until it read 46 degrees (any higher is off).
This refrig is incased in cabinet system... could this cause a problem???
  • 2 more comments
  • pnardi Dec 23, 2008
    steve, this is double door fridge with bottom freezer drawer, can you tell me where the internal door would be???
  • kent_sjolund Jan 16, 2009
    My model is the PSS25NGMA WV but same problem--Fridge side freezes everything
  • Anonymous Mar 09, 2009
    I have had this side by side for 8 years and have thrown away hundreds of dollars worth of food. I really just shop like a European today; going to the store almost daily for produce. Any help?
  • jazze98 Apr 09, 2009
    I have the same problem. Mine is a GE Artica Profile...freezer on one side, frig on the other. Freezer is keeping correct temp...Frig is staying at 24-27 degrees and freezing food.
  • 69 Answers
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Posted on Dec 21, 2008
  • Stephen Evans Dec 23, 2008
    Unfortunately there a 4 different styles of the model # you provided. It would be best to contact GE directly. Here is their link
    GE Appliances Home, kitchen appliances, refrigerator, water filter ...
    GE Appliances offers top refrigerators, air conditioners, water filters, water softeners, dishwashers, kitchen appliances, stoves, appliance parts, washers, ovens, stainless steel ...
    Also this is a link to a sight I thought you should see
    Consumer complaints about GE Refrigerators
    Consumer complaints about GE Refrigerators ... Quite a few things can go wrong with GE refrigerators and, as the complaints in this section show, getting problems fixed is anything ...
    • www.consumeraffairs.com/homeowners/ge_refrigerators.htm
    • · Cached page
    I really wish I could do more for you. I hope this helps solve your problem. Steve
I have a KitchenAid refr. mod. KSRL25FRSS00 it is turned down to the lowest setting and still freezes things in vegetable box. (new control board?)
Is your milk or eggs freezing? All the cooling in the refrig and freezer spaces is done in the freezer. Sometimes, the control labeled freezer temp controls a vent between the freezer and ref space, allowing air into the ref side. the other control determines run time. try turning thefrz setting up to raise the ref temp.
Nov 15, 2010 | KitchenAid Refrigerators
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
Whater dispensor is not working?
At the back of the fridge at the bottom there are solenoid valves. Unplug the fridge and measure the resistance. They should read a few hundred ohms. Most likely the solenoid for the water dispenser is burnt out so if you measure them all one should read open. Anyways you can't buy these solenoid individually. It comes as a set and cost over a hundred bucks. So I would measure the resistance first with a multimeter. Make sure the fridge is unplug!! when you measure.
Jun 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile side by side is not dispensing water, have removed the line at door and there is not water coming out. What do I do next.
At the bottom of the freezer door ( remove the kick plate , 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the door line is frozen , GE has a dispensor heater , pt # WR49X10173 , to help eliminate the freezing of the line .
Dec 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Oct 05, 2009 | GE Refrigerators
Icemaker is not working
Pour about 1/2 cup of water into icemaker . If it freezes and dumps , replace the water inlet valve . If it freezes and doesn't dump , replace the icemaker . Make sure the coils are clean of dust , lint , etc .. for refrig to be proper temp for icemaker to work (5 degrees) .
Aug 13, 2009 | GE Refrigerators
Our GE monogram refrig compartment is constantly below freezing.
2 possibilties most likely is a bad temp sensor it thinks its warmer in the refrig than it actually is. the next possibilty is a motherboard has gone bad in the unit.
Jan 21, 2009 | GE GSS20IEP Side by Side Refrigerator
I am not getting water to the dispencer the water goes to the
its possible that the water tank has frozen up inside your ref compartment. here is how to fix. remove teh lower veggie drawers and then look behind where the drawers were you will see either a water tank or a roll of plastic tubing. using a hair dryer heat the tank for a few minutes then try you water dispenser again. once you have it working just raise the temp of your refrig compartment to prevent future freezing of the tank. peyton
Jan 20, 2009 | Hotpoint HSS25GFP Side by Side...
Everything freezing in vegetable and Custom Cool compartment
you have a temp setting above those shelves left side has a porkshop and left side has a carrot i belive set to to the left side to vegies and see if it helps if still all freezes the you have a broken damper on top that letts air in when it does not needed
Sep 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
956 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
