Question about Whirlpool Duet GHW9150P Front Load Washer
Rotten egg smell
Every time the machine is used we get a rotten egg smell. IT is installed per the installation instructions, we are on city water, the machine is used reqularly for two people and we are using the correct detergent. If you run bleach through the machine with no clothes in it the smell goes away for a week, maybe two, but eventually returns. Help.
  • 2 more comments
  • Bruce Proctor Apr 07, 2007
    Thanks for responding!! Ya know, the smell appears to be coming from under the drum of the washer. When the washer is empty, if you rock it, phew....rotten eggs....and you can hear water moving. I'm thinking there's not supposed to be any water left under the drum when the washing cycles are done????!
  • Anonymous Dec 06, 2007
    I had same problem rotten egg smell, this problem was solve when we switch to "HE" high efficiency detergent for front load washers
  • nwmitch May 28, 2008
    My Duet also has the same rotten smell.  We use HE Liquid Detergent.  Running vinegar through it helps, but only for a day or two!  It's rancid!!
  • cheyenne6499 May 29, 2008
    I have the smelly rotten egg problem as well . We are on a well and I had assumed it was our water hmmmmmmm now rethinking the matter altogether .
  • 29 Answers
This is a common problem. There is a build up of grime in the hidden crevices of the machine. To help resolve this problem, put a cup and a half of good dishwashing power in the machine and then place it on HOT full capacity. Then place fill the fabric softener with bleach. Run the unit half of the wash cycle and then stop it and allow it to soak for 15 minutes. Then allow it to finish the cycle. Repeat this process once a week for 3 weeks. Also you may want to stop using fabric softener if you are using it. The softener acts like a surfactant and adheres to the upper crevices of the machine. After a while bacteria starts to build. The bacteria varies in composition; but a very little known bacteria thrive in these humid areas and gives off the odor you described. The bacteria is commonly known as SRB’s. Here is some more information on this subject. http://www.nesc.wvu.edu/ndwc/articles/QandA/OTsp00_Q_A.pdf
Best o Luck :?) DRRXR
Posted on Feb 13, 2009
    President:
  • 1,462 Answers
Are you using liquid detergent? if so this produces a smell like drains. if so put on a boil wash and revert to powder. otherwise check you connection to drains and ensure there is a water trap somewhere. there is nothing in a washer to smell
Posted on Apr 05, 2007
  • douglas smith Apr 08, 2007
    doubt it. the water left in the drum is not old and is clean.
  • Official Brand Answer
  • 30 Answers
Duets and other front load washes do not have water-filled balance rings. The water you hear sloshing around is in the bottom of tub and in the drain pump. This is normal. Bleach will kill mold but doesn't remove the residue from the inside of the outer tub. The worst buildup is always just above the normal waterline about 3 to 5 inches. If baking soda, vinegar or other cleaners don't work - Smelly Washer Cleaner will! Simply add a cap to an empty washer and allow a hot cycle to finish. If odor persists or returns add 1 cap to a full load of laundry. The added bulk of the laundry will raise the water level to include the splash area. Intermittently pause and restart for added soaking time for extreme odor.
Posted on Dec 21, 2012
Thank you for your suggestion to resolving our ongoing problem. I do keep the door wide open when not in use....I figured that out a long tima ago as the smell was really bad. Ya know, other friends who have the Duet also say there is an order, but their water drains in the basement. My husband is attempting to try to have our water drain in the crawl space instead of the sink next to the Duet. Really sad that such measures have to be taken with an expensive appliance. We paid top buck for this Duet and would never buy another one. Besides, the smell being a HUGE issue, the clothes don't even get cleaned. If I want my towels to look clean, I have to buy new ones.....discouraging!!
Posted on Apr 27, 2007
The water that you hear swooshing around is not water ,,it is balancing fluid within the tub Ring ,,this is normal....the gasket ( rubber around the door ) may be the problem ,,,,mold accumilates on this between the folds ...try cleaning the door Boot and see if that helps ..also keep the door open when not in use
The washer needs to be cleaned with the tablet that is made for it. I use the tablet every 2 week.
I dry the door and gaskets, and leave the door open. I use Tide no additives,etc. Check to make sure
you are using the correct amount of "HE" detergent.. I wipe out the dryer also.
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
The washing machine smells like rotten eggs on the rinse cycle. The clothes also smell afterwards as well. What can I do to resolve this?
Rotten egg stench is caused by sulphur content in the water or building up over time in your water heater. It can also build in a water system that is rarely run. Have you noticed this smell from other taps in your house? There are inline charcoal filters that can remove it from the water, or you can also try removing the water lines from the washer and running them awhile.
Is this new, or has it been happening for awhile?
Dec 04, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Jacuzzi jets smell like rotten eggs when turned on.
Need to run some cleaner through jets to clean out old water and mildew.
May 09, 2010 | Home
Any time you get a strong smell of rotten eggs it is due to a high concentration of sulfer in the water. Are you on well water? I would suggest using a cleaner like http://www.sani-bath.com/ to clean out your system.
Mar 17, 2010 | Home
I get a "rotten egg" smell when I run the water in my house. We have a Rinnai system and city water. Is this a common problem with a tankless system? Can it be corrected?
there is a anode inside most normal water heaters that will cause this problem when water has not been used for a few days
not sure if rinnai use's an anode did you install lime tamer or corrosion system
on incoming line to protect water heater
if oder is only on hot side this is a possible solution
Dec 07, 2009 | Cars & Trucks
Rotten egg smell / sink
Two different problems. Rotten egg smell is sulfer from the water supply, especially strong in heated water. Drain may need to be cabled out.
Mar 12, 2009 | Plumbing
The hot water smells like rotten eggs., only the hot water
its the mag rod in water heater-if your not using alot of hot water,and water is sitting in heater it will smell like rotten eggs-u can remove mag rod from water heater.it is in top of heater-
Jan 08, 2009 | General Electric GE SmartWater Household...
Rotten Egg Smell
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
Jan 21, 2007 | LG WM-1832C Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
9,319 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
