I disconnected my printer and connected my cannon powershot to the usb, downloaded my pictures, reconnected my printer but I cannot print anything. Any suggestions
    Problem Solver:
  • 15 Answers
just reconnect the cannon powershot and go to my computer then change the drive letter to something Else for the removable drive that belongs to cannon powershot. just try it
Posted on Dec 22, 2008
How can I fix printing hesitation on my lexmark x5495
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/hsBChY. Select your operating system, download and execute the file.
Feb 16, 2012 | Lexmark X5495 Printer
The compuer is not connected
  4. Reboot computer.
Feb 10, 2012 | Lexmark X5495 All-in-One &USB...
What should I do with my Lexmark printer x3430? It will not print an entire article. It will print only one page.
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/AbnM39. Select your operating system, download and execute the file. After the install process, try to print again.
Feb 08, 2012 | Lexmark X Office Equipment & Supplies
When i scan to computer it cannot download the application
  4. Reboot computer.
Jan 26, 2012 | Lexmark X5650 ALL-IN-ONE PRINTER
It want print anything!
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
Sep 12, 2011 | Lexmark C533DN InkJet Printer
My cannon i70 is not printing after i replaced it's ink cartiges
Hi seeniathao !
Probably a driver issue .
Disconnect your device .
Delete and reinstall driver/program . Don't have install cdrom ? download driver from :
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i70#DriversAndSoftware
Reboot .
Reconnect the scanner and wait for confirmation of successfull installation .
Best regards ,
fanaudi .
Feb 22, 2011 | Cannon i70 Printer
I have reconnected my HP PSC 1315 to my printer, however, I cannot get the printer to work. Can you please help me? The printer will not do anything. I have received a print test after I installed the...
Hi melovesjags:
Try these steps.
Does the product
print from the
computer?
Connect the parallel
cable or USB cable to the
product and the
computer. Use a wordprocessing
application to
send a print job to the
printer.
The cable is not
connected correctly.
Reconnect the cable.
An incorrect printer driver
is selected.
Select the correct printer driver.
Other devices are
connected to the parallel
or USB port.
Disconnect the other devices and try again
to print.
There is an LPT port
driver problem.
Reset the computer port settings. See your
computer user guide for instructions.
The formatter has failed. Replace the formatter.
Hope these help
Jul 06, 2009 | HP PSC 1315 All-In-One InkJet Printer
Will not print anything?
Check the cartridges first
Try doing this
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Jan 28, 2009 | HP Deskjet D4260 Printer
Connect macbook to cannon pixma mp620 printer
You need to delete and readd the printer with a bonjour connection.
Click on the apple in the top left and go to system preferences and then print and fax.
Click on the printer name (just one click to highlight) on the left and then on the minus sign. It will ask if you are sure you want to delete - you can click yes or delete.
Click on the plus sign and you should see the printer with a bonjour (macspeak for network) printer
Click on it to highlight it and then it will look for drivers and you can then click add to add to your list.
Close print and fax window and open a document and print away!!
Jan 14, 2009 | HP PSC 1315 All-In-One InkJet Printer
Cannot cancel copy process keeps on printing even when I press cancel button prints the same document over and over I want to print a picture from my computer can I download a picture from my camera...
Try doing this
Nov 18, 2008 | HP Office Equipment & Supplies
Computers & Internet Logo
37 people viewed this question
Alun Cox
David Payne
David Payne
