Question about Insignia PD10135 Portable DVD Player
Insignia PD10135 Portable DVD Player Battery won't work
Every time i plug my dvd player in to charge, the charging light comes on for about five minutes and then turns off. Also, i have been charging my dvd player every night and it still wont work unless it is plugged into the wall.
  • tracie40 Mar 28, 2008
    bought portable dvd player and it will not even charge, do you have to have the battery charged to even get it turned on , thanks
  • Anonymous Mar 26, 2014
    only holds charge for 35 mins
  • 67 Answers
I have the same unit, and had the same problem numerous times. I finally removed the battery and sprayed CRC electronic cleaner over the battery terminals as well as the units terminals. Put the battery back in hooked up the charger and it went green. It is playing as I write this.
Posted on Nov 27, 2011
    Guru:
  • 104 Answers
It sounds like your battery is dead. Maybe yuo should consider replacing the battery in a new one.
Posted on Apr 05, 2007
Insignia dvd travel theater (IS-PD040922) was
I am having maintaining power problems with my PD040922 when I try to use it the system clicks and goes back to LOADING option. I have tried to work through this problem by removing battery and just have mains power connection. Then I just use fully charged battery with the same problem occuring. Is there a solution, other than buying a new player?
Nov 27, 2009 | Insignia Televison & Video
Connecting a portable dvd player with only an av port to a tv
There is a special AV cord that connects to a TV ,
MINI PLUG TO 2 RCA , one is ( yellow) VIDEO & the other is AUDIO , get it at RADIO SHACK or WALMART , hope it helps , AJ
Nov 14, 2009 | Insignia PD10135 Portable DVD Player
Charging light not coming on
Good day sir, my guess is that your adapter is the culprit, if you have access to another charger please use it, if you may have the time, try to visit your dealer, and they be wiling to test your adapter. Other causes may be the charger DC port, or the battery, but let us stick first to the common adapter problem, hope this helps.
Jul 31, 2009 | Durabrand DUR7 Portable DVD Player
Insignia NS-PDVD10 Speaker Volume Control
The volume control is on the right side of the player, closest to the front. A copy owner's manual can be downloaded here; select the Support tab. I hope this helps!
Jul 19, 2009 | Insignia PD10135 Portable DVD Player
My prortable dvd player
Make sure the battery is installed in the correct direction, turn off the player, plug in the AC pack and look for the red charge light to illuminate on the front lip of the player. Give it a few hours to charge.
Apr 05, 2008 | Insignia IS-PDVD10 Portable DVD Player
Wont even turn on
All things being equal a possible cause is a faulty power supply or bad connection at the power jack. A volt meter will tell you if the power supply is faulty. If the jack in the player is bad/ poor solder connection you might be able to fix it by re-flowing the solder. If it's new doesn't it have a warranty?
Mar 29, 2008 | Insignia PD10135 Portable DVD Player
My Insignia 8" Portable dvd player does not detect dvd!
Try playing a regular CD first and take it out if it played. Then put the DVD and it will play fine because the player just realign its lense. Hope it will help
Jun 17, 2007 | Insignia PD10135 Portable DVD Player
Battery charge
the battery is dead. that happened to me and i had 3 choices: 1)buy a new dvd player 2)buy a new recharable battery or 3)keep the portable plugged to the wall while i watch movies. i chose number 3 because i usually just use it at places plugs are available. but yeah, the battery is dead.
Jan 27, 2007 | Insignia I-PD720 Portable DVD Player
Insignia IS-PD040922 portable dvd player
The batteries are not being charge,it might be bacuse you have the wrong ac adapter,you should get the original to start then let the batterys charge for at least 5 hours or until the red light stopr blinking.You can find more inf.here http://www.insignia-products.com/p-31-insignia-7-169-widescreen-portable-dvd-player.aspx
Sep 25, 2006 | Insignia IS-PDO40922 Portable DVD Player
Insignia PD10135 Portable DVD Player Logo
1,222 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
