Question about Toshiba Office Equipment & Supplies
Paper jam display
I have problem witth a Toshiba producct-BD 1710.. It is displaying "call technician" and paper jam at the input transportation part. What can I do?
    Problem Solver:
  • 7 Answers
Open machine look for an upright lever at the paper in side.... it is called a paper detection switch its function is to detect the position of the paper movement through the machine, if the paper does not trip the switch at the right time the machine will indicate a paper jam and shut down, most machines have this sort of detection system
Posted on Dec 22, 2008
  • Fonda Zenofon Sep 16, 2011
    Thanks for the above. And where the detection switch is located. I am about to go to the copier ands see if I can track down the switch.
    I will get back to you if I was successful.
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
Display is saying "13.2 paper jam open input trays
Check for any paper jam in the tray and restart the printer and put it caliberate mode
Oct 05, 2011 | HP LaserJet 4050n Printer
What is meant by e550 in toshiba E-studio 230?
Paper jam remaining in the copier when the power is turned on
Sep 21, 2011 | Toshiba e-Studio 232 Black and White...
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Misfeed in copier error E200
Hi how are you this is jack my personal ID
(jack_pak@hotmail.com)
Paper transport jam
[E200] Upper drawer transport jam (not reaching the registration sensor)
Open the jam access cover. Is there paper in front of the registration sensor?
YES Remove the paper.
NO
Is the registration sensor working? (Perform the input check:
NO 1. Check if the connector of the registration sensor is disconnected.
2. Check if the connector CN345 on the LGC board is disconnected.
3. Check if the connector pins are disconnected or the harnesses are open-circuited.
4. Check if the conductor pattern on the LGC board is short- or open-circuited.
5. Replace the registration sensor.
6. Replace the LGC board.
YES
Are the upper transport clutches (high/low speed) working?
NO 1. Check if the connectors of the upper transport clutches (high/low speed) are
disconnected.
2. Check if the connector CN362 on the LGC board is disconnected.
5. Replace the upper transport clutches (high/low speed).
YES
1. Check the condition of the feed roller, separation roller and pickup roller of each paper source, and
replace them if they are worn out.
2. Check the transport roller. Replace it if it is worn out.
Thanks
Best Regards,
Aug 05, 2010 | Toshiba E-Studio 3511 Color Copier
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
Display says rec.paper jam,slide platen left
in service mode manually recheck all paper transport sensors...
Mar 17, 2009 | Canon Office Equipment & Supplies
E3co e3eo toshiba 451c
E3C0 indicates LCF transport jam (not reaching the registration sensor).
YES-> Remove the paper.
NO->Is the registration sensor working? (Perform the input check: 03-[FAX]ON/[9]/[E])
If NO ,
1) Check if the connector of the registration sensor is disconnected.
2) Check if the connector CN338 on the LGC board is disconnected.
3) Check if the connector pins are disconnected or the harnesses are open
circuited.
4) Check if the conductor pattern on the LGC board is short circuited or open
circuited.
5) Replace the registration sensor.
6) Replace the LGC board.
If YES:
(Perform the output check: 03-439, 440)
Feb 10, 2009 | Toshiba E-Studio 3511 Color Copier
Paper Jam
Some basic non-tech questions:
  • Are you using paper that's been allowed to sit open for weeks? It might have absorbed water.
  • Are you in the habit of reusing paper that's double-fed? I used to, but it's more likely to jam
  • When was the last time the technician was in to do a preventive maintenance? The machine may need a basic clean-and-check.
  • Check your manual, and check what the machine is telling you (on the display, if it has one). The location of the jam may give you an idea of the reason for the jam (jamming at the fuser may indicate a cold fuser, jamming at the drum can be caused by broken separation fingers, etc.) If you have a technician, this will be useful information.
Nov 22, 2008 | Toshiba 2060 Copier
94 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
