Question about GE Washing Machines
Waont drain need to find out where drain filter is to clean after wife washed pillow, ans busted it
    Novelist:
  • 161 Answers
I would check the pump.
Follow the drain hose back to the pump, disconnect the outlet hose from the pump and disconnect the inlet hose from the pump. Look inside both hoses and the pump for pillow pieces.
The pump may have to be removed for cleaning, you should be able to turn the pump by hand, if not, replace the pump.
Inner tub.
Run some water in the washer with the inlet hose disconnected from the pump. You'll need a pan or bucket for the water to run into and look for pillow pieces.
Posted on Dec 21, 2008
Lg front load washer vibration
are you washing large pillow and bedsheet? any large material that hold great deal of water will cause the tumbler to wobble out of center rotation that in turn causes vibration. stop the machine and get as much water wrung out from the large bedsheet or pillow.i get this problem when my wife wash pillow and large bedsheet. the whole house shake violently if you live in two story home.
Mar 03, 2015 | LG Washing Machines
Tip
Fed up having to buy new filters for your vacuum?
Over the years I've lost count of how many companies stop selling replacement filters for their long deceased production vacuum models or that filter replacements are becoming increasingly difficult to source. There are usually universal "microfilter" replacements which are easy enough to find and cut to size, but if you can't be bothered to do that, there are ways around to renew your existing filter even if the manufacturer or the user manual states that the filter cannot be washed.
You see, any filter can actually be washed - if it is a single cloth filter - as opposed to a micro pleated section of many layers sewn together. If you have such a filter, a single cloth filter which the user manual says cannot be washed, this is a blatant lie. Remove the motor filter as normal (usually found at the bottom where the paper bag goes) if it is embedded with dirt and wash under a hot tap of water with either household washing up liquid or soap. Once the filter has been completely cleaned, place the filter into a pillow case and chuck into an electric dryer on a low heat. Instead of waiting 24 hours normally for a filter to dry to room temperature, you'll cut your waiting time by a day simply by allowing the gentle heat from the electric dryer to circulate around the pillow case which holds your vacuum cleaner filter. Once the filter is completely dry to the touch and does not feel damp in any way, install back into the vacuum cleaner.
I have also done this with HEPA paper filters which apparently are not washable according to the manual, and to stop the plastic cartridges from bouncing off the walls of your electric clothing dryer/tumble dryer put an extra towel or cloth into the pillow case to minimise damage. What is then revealed is a new, dry and clean filter which can be used again instead of spending lots of money trying to source a new one.
At the same time, if your vacuum cleaner has a soft bag, take it off and put it into the washing machine to give it a clean lease of life - but you won't need to put it into a pillow case to dry in the electric dryer - simply chuck the bag in to ensure it gets dried properly before putting it back onto your vacuum cleaner.
on Nov 16, 2007 | Sebo Automatic X1 Bagged Upright Vacuum
Duck Feather Pillow In Washer. Feathers everywhere. door will not unlock or drain water. help
Pull off the lower front panel and reach up on the right of the washer to the door lock assembly you will feel a tab hanging down pull it and the door will release. Clean out the drain filter and pump hoses etc. Rise it out and you may have to clean the filter a few times.
Nov 29, 2010 | Maytag MAH8700A Front Load Washer
E 04
sounds like your doing a good job, clean out your filter pump sump hose again.....it will take this action several times to fully cure ....Good luck..
Apr 12, 2010 | Bosch Nexxt 300 Series WFMC2201UC
My wife washed a pillow full of Styrofoam balls and it broke inside the washer. Now we have the little balls in every load, How do we clean it once and for all ?
The only thing you can do is to keep putting it through a rinse cycle.
If there is a filter you can check, do so after each rinse cycle, and eventually it will clear itself..
Mar 28, 2010 | KitchenAid Washing Machines
A feather pillow busted during the cycle - What do I need to do to prevent damage?
either you have overloaded the machine or else your spin speed was set on high, lower it down and it should not happen next time.Make sure there is nothing broken inside the tumble or the spinning area...
Jan 14, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Dec 06, 2008 | Roper RAS8445KQ Top Load Washer
I washed a feather pillow and it busted, now it wont pump water out.
There is a filter down in the bottom front of the washer (below the drum) that is probably clogged with feathers. It is a pain to get to, but once you get it cleaned out, the washer should spin and drain without problems.
Oct 25, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
53 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
