Question about GE Refrigerators
GE fridge TFX24FHB mfr'd 7/86 - system check display shows "de"
Our side by side is still working, sounds normal, yet the system check display is showing "de". That code says to keep the doors closed as much as possible and to call a repairman. We can NOT afford a repairman these days so can you please tell us how we can fix it ourselves? Thank you
  • 3 Answers
This may or may not be the fix, but I had a problem with my GE Profile TFX24PR sibe-by-side. Water was leaking from the ice maker water fill tube into the back of the freezer, onto the cooling coils. This would cause the freezer to go into extended defrost and the freezer and fridge would warm up. If you see ice inside the freezer, especially around the outside of the ice bin, or odd chunks of ice in the ice bin, turn off the ice maker and/or the source water supply and see if the problem clears up. If the ice buildup is especially heavy, you may need to remove your food, and unplug and manually defrost/thaw the freezer. You may want to remove the cooling coil cover, that is the back wall of the inside of the freezer. Mine had five screws holding a thin sheet of metal, three at the top and two near the bottom. Once this is off you can see the cooling coils. Be careful not to bump or scrape the coils. At this point I found about a quart of ice frozen on top of the coils in one big chunk, stuck to many wires. I carefully broke off what ice I could, and used a hair dryer to melt the rest.
If this is the problem, then you will need to replace the ice maker water fill tube. This is a time consuming job, you have to disassmble the fan compartment on the back wall of the freezer behind the ice maker to get to the fill tube connector. Once you get there it's easy to reach and it just pushes into the connector. In my case, I just reversed the ends and pushed it back in for a snug fit. You may want to consider using a sealer to prevent it from happening again any time soon.
Posted on Apr 03, 2009
Have a GE Profile PFCS1RKZA - with many random issues...
The dimming light indicates a power loss in the system.
Jul 10, 2015 | GE Refrigerators
My frost free fridge freezer is working but flashing de on the front. I'd like to know what it means
Error codes are brand (and often model) specific. "de" likely indicates something in the defrost process, especially on G.E. Check for ice build-up in the freezer cooling coil. The control board would be suspect, but must be checked to confirm the precise fault.
Oct 20, 2014 | Refrigerators
GE PFSS6PKW display shows "88" on freezer side and
my fridge had the same prob thank you very much this really works i pressed the energy and alarm for 10 seconds and works PERFECT
Nov 15, 2010 | GE Refrigerators
GE Arctica intermittant clicking sound, panel flashes "hrs"
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer o.k., Fridge barely cooling.
Expose the coil in the freezer and defrost it with a hair dryer.
Aug 01, 2009 | Refrigerators
I have an older side by side ge fridge with the panel display that shows pf - power failure de - cc etc well the de light has come on and I don't know what it means - I do not have the manual and I'm not...
The DE error comes up when the refrigerator has not detected adefrostcurrent within a certain amount of time. This is most often theresultof a burnt out defrost heater. The refrigeratorwill likelykeep working for a week or so until the frost builds up andblocks theair flow over the evaporator (the cooling coils behind theback wall ofthe freezer). The defrost heater is located at the bottomof saidevaporator.
You can try your zip code in http://www.geappliances.com/buy/ and look for a servicing dealer.
Good luck.Please rate my answer if accepted.Thank you.
Jan 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX24FHB system check shows problem code "de" but its still cold for now..
It sounds as though you may have an issue with the defrost system. If the system check shows an open circuit on the frost heater or an open circuit for the defrost thermostat when the temp in the freezer is at zero then you will get this problem.
I would keep an eye on it for a couple days and see if frost starts to accumulate on the rear wall of the freezer. If so you will manually have to defrost the freezer so the machine can maintain temperature. When you have the rear wall removed from the freezer you will need to check the resistance of the defrost heater.
Let me know how you make out and if you have anymore questions. Thanks,
Bill
Dec 21, 2008 | GE GSS22JFMWW Side by Side Refrigerator
GE Side By Side Stopped Working
Either a bad interface\display board or a bad main computer. I would try the main computer first.
Jun 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge stop working
You need a volt/ omh meter or call a repairman.. need to start at the control board and check power going out of the board. sounds like a board problem with out more info
Sep 03, 2007 | GE PSS26NGPBB Side by Side Refrigerator
Refrigerators Logo
364 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
