Question about Desa International GWP20T GLOWARM Wall Mounted Panel Heater
Yellow flame i have a comfort glo cbp30t and the flame is yellow also high on one side
  • Anonymous Dec 22, 2008
    I ahve a ready Heater 10,000 propane It shut off during the nigt I got it started the next nite it did so again now it will not lite at all nothing its 5 degrees here in Brussels/Hardin Illinois
  • 92 Answers
First guess is that you had some condensation in your fuel line and it froze. you need to disconnect it from your fuel source and heat the line to thaw it and blow out any water. I would also use a wire brush and clean the burner for good measure.
Posted on Feb 04, 2009
Gas fireplace manuals
There are two things that control flame height gas volume and air volume. Some fireplaces have a flame control knob on the gas valvd to adjust flame height. Air volume is controlled by an air shutter usually located where the main gas orifice enters the burner. There is usually a small cover that will need to be removed to access the shutter. Closing the shutter will cause the flames to become taller and more yellow colored. Closing the shutter too far will cause sooting problems so great care should be taken in adjusting this shutter.As a rule, L.P. gas fireplaces do not have as high of a flame as natural gas unit do.
Hope this helps
Dec 14, 2013 | Heating & Cooling
Dyna-glo wall heater seems to have mixture problem pilot shuts off after every heat cycle pilot is three inch long yellow flame
yellow flame ng and flame should just cover last third of thermocouple if so equipped. (to much pilot pres.)
Nov 15, 2012 | Dyna-Glo Heating & Cooling
I have a dyna glo ventless model fp 65 30,000 btu flame doesnt burn very high
It would be ideal to take it apart and blow it out but you could try vacuuming out the grates real good.
Nov 11, 2010 | Dyna-Glo D-E37 Wall Mounted Panel Heater
On Barbeque side burner it burns with a high yellow flame getting
Try using compressed air to blow out the burner and make sure the gas is turned off when you do it.
Apr 20, 2010 | Grilling
Dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Jan 13, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
My Dyna GLo kerosene heater has excessive smoke and yellow flame
I'm wondering the same
Should a duraheat, etc., cylindrical convetion heater's flame be bright yellow, blue , or what? With the old wick the flame was blue, with the catalytic converter glowing red hot. Now with the new wick, I can't even see the CC, because the flame burns a bright yellow. Also I have to really fine tune it now. A wee bit too high, I get smoke and soot. A wee bit too low, same...smoke and possibly flame out.
Feb 24, 2009 | Heating & Cooling
The pilot light won't stay lite
Flame is way too high on pilot . blocked injector or hole on injector is too big . Being sucked off by main burner .
Jul 04, 2017 | Dyna-Glo (PPH16-LP) Utility Heater
Dyna-Glo RMC-8001SS
Replace the regulator. We had three for three with the same problem.
Oct 30, 2007 | Dyna-Glo RMC-8001SS Heater
Desa International GWP20T GLOWARM  Wall Mounted Panel Heater Logo
98 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
