I want print borderless paper but the don't work this machine is borderless a not
SOURCE: Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
SOURCE: Cant print Xerox Docucolor 240 with Creo CX250
its the problem of connecting cable.and other error 212 is for internal circuit board error.you will have to contact xerox service center and get the resetter for this online.or if its board problem you will have to order the parts.
http://www.office.xerox.com/multifunction-printer/color-multifunction/docucolor-240-250/sprt-enus.html
click the link directly and check out your areas service center or the nearest to your area.
thanks.
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
SOURCE: xerox docucolor 1632 fault code: 004-341
Try reseating the waste toner then all 4 drums, see if the chips are mating.
Most likely either the machine software is corrupted and needs to be reloaded, or the MCU board has failed, could also be a bad laser, called the ROS.
