Question about GE JE1640WA/GA Microwave Oven
Oven runs but does not heat
The unit is approx 7 years old. The other day it stopped heating. It runs but does not make the same 'pitch' when turned on. It also makes a smell like electronic burning. Time for a new unit?
  • GE Master
  • 9,149 Answers
This is going to be either the high-voltage transformer, the magnetron, or the high-voltage diode. Magnetrons are the mosty common failure in these, and there is a campaign underway to replace "underperforming" magnetrons. To see if yours is one of these, visit: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf
Posted on Apr 05, 2007
Model NN-6603A unit won't heat
If the microwave oven is 7 years old or less, the cause is a bad magnetron, or the inverter board is malfunctioning, due to cost in parts and labour cheaper to replace.
Jun 29, 2012 | Panasonic Microwave Ovens
My whirpool oven model no akz 456 stop heating
The magnetron or the inverter board are the likely cause if microwave is less than 7 years old.
Jun 02, 2012 | Whirlpool Microwave Ovens
My microwave has stop heating
If the microwave oven is less than 7 years old there are too items that would be suspect, the magnetron, [heart of the unit] or the inverter board.
Jun 01, 2012 | LG Microwave Ovens
Sharp r-610dk microwave runs but don't heat up
The magnetron has failed, or the inverter board, "if 7 years old or less" there is also a possibility the keypad control board may be the problem.
Apr 21, 2012 | Sharp Microwave Oven Microwave Oven
Buzzing sound... Turntable stopped. food heats up but uneven. No microwave fan when heating.. no light inside expensive fix?? Unit is 10 years old
If the microwave oven is 10 years old then it is time to consider a new unit, by your description it is going into cascade failure where different parts have stopped working, the buzzing sound is the magnetron warning you, it is about to fail. The fans job is to keep the magnetron cool while it is running.
Mar 08, 2011 | GE JVM1850 1000 Watts Microwave Oven
Oven stopped heating; everything else seems to be working. i dont notice difference in sound when turned on model JVM1642BB 003 man date july 2000
The symptom that you have described sounds like the magnatron has failed, the microwave oven looks to be approx. over 9 years old, at that age and with a failed magnatron it is not cost effective to replace the part, it would be best to replace the microwave oven at this point. Good luck!
Nov 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440WH01 Will not heat, everything else works. This unit is 6 years old and just stopped heating. The carosel turns, fans work, the timer counts down and lights come on when you start cooking or open...
It could be a number of things, Burnt connections between the magnetron, Capacitor, Diode and transformer, Heater connections loose or burnt, Transformer, Capacitor Diode or Magnetron US. You need to strip it and find out if you are getting about 2000volts to the Mag, Are you getting approx 5volts across the heater terminals?? NOTE that the 2000 Volts can remain in the cap indefinitely and the voltage is LETHAL. IT WILL KILL YOU if you don`t take precautions. Ian
Aug 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My spacemaker GE 1440 do not heat it 2 years old
Hi tony,
The units magnetron(the device that generates the micro waves) is failed or failing, this can be DIY depending on how mechanically inclined you are.
anaanymous
Oct 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE JE1640WA/GA Microwave Oven Logo
170 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
