Question about Air Zound Horn
Mu?y airzound horn lose air from valve - Air Zound Horn
Try tightening the inner core of the refill valve. maybe a car mechanic has such a tool (looks like a tiny two prong fork)
Posted on Jan 12, 2009
Renault scenic cooling system
you must check you thermostart and have it replaced and check you heater relay it mu=ight be malfunctionng as well
Dec 18, 2013 | Cars & Trucks
Air horns
you can use the switch but you still need to wire the pump and what not.
Jun 23, 2008 | 2000 Dodge Ram 1500 Truck
Tire pressure monitor error on cadillace escalade 2005. Cannot reset as instructions. What could be wrong.
You may have a bad wheel sensor, try it one more time, scroll to tire pressure setting then go to driverside front wheel and you let air out until horn chrips then move to right front tire and let air out until horn chrips then go to rt rear and let air out until horn chrips then left rear and let the air out until horn chirps, then turn off ignition and set all four tire pressures, then start and tire a few feet they should all be set, take note when horn chrips telling you that its in tire pressure setting mode you have limited time so make sure you have all the valve caps off and something to release air, when letting the air out it may take up to a min to get the horn to sound for confirmation or the tire, but once the last tire is confirmed then key is turn off and you have time to set all tire but try to do it within 10 min, hope this helps,
Nov 08, 2010 | 2005 Cadillac Escalade
Tank noise
Check for air leak,it might be a pop off valve,or the check valve,or the relief valve for the head pressure.
Jun 13, 2010 | Ingersoll Rand - Rand Type - 30...
Loud noise coming from the idle air control valve inlet tube
I do not want to be wrong with my answer but it sounds like the idle control solenoid may be buzzing or the chamber it operates in needs to be cleaned with WD40. Sometimes when a solenoid routes vacuum to a part and sticks, the vacuum is going where it never was intended to go and makes noise. You might want to look at vacuum routing or things like the air horn or if the air cleaner is connected completely around its mount.
Aug 08, 2017 | 1993 Mercury Grand Marquis
My 99 ford expedition cuts off after driving for about 30 min
Here are two things to check.There is a type of antispin brake that smothers the air intake when it detects a difference in rear wheel speed. This is to prevent spinning in mud or ice. Thus the air HORN sound. There is a control sensor in the rear axle which may be bad.
Jun 14, 2009 | 1999 Ford Expedition
Airzound horn
you need to make sure the valve is fitted tight using one of these tools available from a good cycle store
Valve removal tool
if its tight then you most likely need a replacement schrader valve again from a good bike shop
looks like this:
Dec 21, 2008 | Air Zound Horn
Air Zound Horn Logo
229 people viewed this question
Top Air Zound Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you an Air Zound Cycling Expert? Answer questions, earn points and help others
