Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
What is A2 and A3 terminals on athermostat - Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
  • 700 Answers
That is for a load like lighting that can be brought on by the thermostat
Posted on Dec 31, 2008
No low beam head lights on 1999buick regal
Do you know how to do basic automotive electrical testing ?
Headlamps Inoperative - Low Beams
Disconnect the headlamp switch.
Turn the headlamp dimmer switch to the LOW position.
Using a test light, frontprobe between the headlamp switch harness connector terminal D to ground.
Does the test light illuminate? YES - NO ?
Using a test light, probe between the headlamp switch harness connector terminal D to ground.
YES - Go to Step 3
NO - Go to Step 4
Replace the headlamp switch. Refer to Headlamp Switch Replacement .
Has the repair been made?
Go to Headlight System Check
Repair a poor connection or an open in circuit 1750 between the headlamp switch and the harness connector terminal A and G201.
5
Reconnect the headlamp switch.
Using a test light, backprobe between connector C201 terminal A3 and ground.
Go to Step 6
Go to Step 7
6
Repair a poor connection or an open in circuit 10 between the harness connector C201 terminal A3 and S221.
7
Using a test light, backprobe between connector C201 terminal A2 and ground.
Go to Step 8
Go to Step 9
8
Replace the headlamp dimmer switch. Refer to Multifunction Turn Signal Lever Replacement - On Vehicle .
9
Using a test light, backprobe between the underhood accessory wiring junction block harness connector C2 terminal F10 to ground.
Go to Step 11
Go to Step 10
10
Replace the underhood accessory wiring junction block. Refer to Accessory Wiring Junction Block Replacement .
11
Repair a poor connection or an open in circuit 1201 between the underhood accessory wiring junction block harness connector C2 terminal F10 and connector C201 terminal A2.
Go to Headlight
Feb 18, 2017 | 1999 Buick Regal
Indesit IDC75 dryer need to know all the order in wiring on front panel timer,start,etcetera
The spade terminal wiring sequence for the timer is: White/Black to B5 // Pink/Black to A2 // Gray to A3 // Single Blue to B1 // Double Blue to B2 // Single Red to C5 // Single Black to C4.
Oct 18, 2014 | Dryers
How to create a formula for increase decrease percent in excel
If you have a number in Cell A2 (say 100), and you put the amount of percentage increase or decrease in Cell A3 (say -10%), then put this formula into Cell A4 to calculate the answer:
=A2*(1+A3) , which then shows as the answer (90).
Sep 05, 2014 | Microsoft Excel for PC
What are the formulas in grading the grades uisng microsoft excel
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
  1. All formulas begin with an equals sign (=).
  2. Some formulas use operands such as +,-, *,/ for addition, subtraction, multiplication or division.
    For example, the formula =A1+A2+A3 would add the contents of cells A1, A2 and A3.
  3. Other formulas refer to different functions such as SUM, AVERAGE and others.
    For example, the formula =SUM(A1:A3) would add the contents for the range A1 through A3.
  4. Formulas can be combined with operands.
    For example, the formula =10*SUM(A1:A3) would add the contents cells A1 through A3 and multiply them by 10.
  5. Functions can be nested within each other.
    For example, the formula =SQRT(10*SUM(A1:A3)) would take the square root of ten times the sum of cells A1 through A3. When functions are nested, it is important that the number of left parentheses match the number of right parentheses.
Aug 19, 2011 | Microsoft EXCEL 2004 for Mac
I want to write an Excel IF statement using only mathematical operators (in another application). The Excel formulation is: ...
Let say you have table like this
' A ' B
1 ' First ' 2
2 ' Second ' 1
3 ' Third ' 3
On Cell C1 or other cell you like, try to type this formula
=IF(B1<B2;IF(B2<B3;A1;IF(B1<B3;A1;A3));IF(B2<B3;A2;A3))
That's all, just IF and math operand
Apr 05, 2011 | Microsoft Excel for PC
Program to make fiboonic series.
I assume you mean Fibonnaci series.
Use Excel.
In cell A1, type 0 (that's zero)
In cell A2, type 1
In cell A3, type +a1+a2
Copy cell A3 down to as many "A" cells as you like.
Read the results.
Jul 02, 2009 | Computers & Internet
Formular to show number and cell references
The formula for A1 is: =SUM(B4,B5)
A2 is: =SUM(C4,C5)
A3 is: =SUM(A1:A2)
To test this, put 25 in cell B4, 25 in cell B5, then 30 in cell C4, and 30 in cell C5.....the result in cell A3 is 110.
Hope this helps.
Mar 07, 2008 | Microsoft Excel for PC
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
