Question about Watches
Bulova computron watch batteries drain rapidly when replaced need to find someone to repair it
  • vintagepassi Apr 28, 2009
    I have a similar problem with my bulova comp
  • 2,338 Answers
Here is all the details you need for repairing your watch:
www.bulova.com/service/inside.aspx - 4k - Cached - Similar pages
Posted on Dec 22, 2008
Battery size for bulova 98g48
If there is a dead battery in the watch, when it is opened, that is one way to identify the battery size.
A second way, if no battery left in it, is to go to a local jeweler or watch battery replacement kiosk at the shopping mall.
Third, contact Bulova at phone number shown:
https://www.bulova.com/pages/manuals-parts
Parts Manuals
Jun 15, 2018 | Bulova Watches
Wich battery number may i use in this watch bulova 96t63 ??thanks
cant see that model watch on the Bulova web site user manuals
http://www.manualslib.com/brand/bulova/watch.html
if unsure if it needs a battery go to a jeweler or watch or battery seller
some model Bulova Watched instructions
IF YOUR NEW WATCH IS A MECHANICAL WATCH
(no battery)
Mechanical watches differ from Quartz watches in several
respects:
1. No battery changes are needed - they are powered by a main-
spring, which is wound either by wrist movement; or in some
models by daily winding of the setting crown.
2. Because it is a mechanical device, it's accuracy is subject to
the effects of gravity and temperature. You can expect, on the
average, a daily variance of up to 10 to 20 seconds for
mechanical watches.
3. Just like automobiles, these watches require routine mainte-
nance. Due to their mechanical complexity, mechanical
watches require cleaning and new lubrication every 3 to 5
years to run at optimum efficiency.
FOR THE AUTOMATIC SELF-WINDING
MECHANICAL WATCH
it must be wound at least six or seven times before you wear it.
After that, your daily activity should wind the watch sufficiently
to keep it running at night when it is not being worn. If your
normal daily activity is not sufficient, occasional supplementary
manual winding may be necessary. It is suggested that your
mechanical watch be cleaned and oiled periodically to insure
optimum performance. As a mechanical watch, quartz watch
accuracy cannot be expected. References to the power cell do
not apply to Automatic watches
May 02, 2016 | Bulova 96T53 Watch for Women
Need to replace or repair a Bulova watch band C877668. One of the links broke. Stainless steel backing
I took mine to a watch repair shop but make sure your watch is worth repairing as it's not cheap.
Dec 31, 2015 | Bulova Watches
Bulova 96b34 watch is not working
Batteries do not last forever. They corrode contacts, loose power even while in storage. Go to a different shop and have the battery replaced.
Feb 21, 2014 | Bulova Watches
My Bulova wristwatch has had two batteries replaced in the last month and a half. The last one was installed this past Saturday- two days ago. The watch is no longer running.
Hi Maureen, The first thing i would have checked is the battery strap if there is one to make sure it is properly fitted over the battery. Other than that as long as the batteries were from a reputable jeweler, it seem as if you watch may need a movement cleaning and or repair it could possibly be the coil. Most of our watch cleanings run around $80.00 but we do all repairs by estimate. Thank you! Lisa
Oct 21, 2013 | Bulova 96R19 Wrist Watch
My watch is ticking two seconds instead of one
The battery in your watch needs to be changed, this a warning the Bulova Millennia 98A48 gives before battery is drained.
Dec 14, 2010 | Bulova Millennia With Vibra-Alarm 98A48...
Just replaced the battery on the Bulova Ladies bracelet watch. watch keeps stopping still.
If you have had your watch awhile, it probably needs a clean/oil/adjustment. FIne watches need regular mainentance just like a car. Take to a local watchmaker or send to following:
http://www.bulova.com/service/servicecenter.aspx#inside.aspx
Aug 19, 2010 | Bulova Crystal 96T63 Watch for Women
Second hand sticks
Be careful because some repair centers will charge you to be the middle man even though they know there will be no charge for the repair.
I recommend contacting Bulova directly because the problem you describe is a defect in the movement and yes it should be repaired. I would recommend replacing the movement rather than over hauling.
Bulova's standard warranty is 2 year limited. You should be covered.
Sep 11, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
NEED REPLACEMENT CRYSTAL WATCH
I'm afraid there will be no good reason to explain where to get the exact crystal for your watch as plenty of special skills and tools are needed to replace it.
The best solution is to find out your nearest watch repair shop and ask for replacement. Any decent watchmaker can do it.
If you want this job done by Bulova itself, visit this site:
www.bulova.com
Here you can contact them and find whatever you want, even your nearest Bulova service center.
Do not forget to rate, please.
Jan 10, 2009 | Watches
Watches Logo
1,007 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
