Question about Cuisinart Brew Central DCC-1200W, 12-Cup 12-Cup Coffee Maker
Clean light keeps blinking
Cleaned the unit, and the light still blinks
  • Anonymous May 03, 2009
    I'm having the same problem - I used a bottle of vinegar and still its blinking - what cleaning prblem did you use and has it happened again?
  • 85 Answers
Hello amerhtens,
This is a common problem with this unit.
I recently had this similar problem. If you still have your machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used an eyeglass screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 09, 2009
I had the same problem, cleaning light coming on, etc, lots of "steam" coming out the tip. The problem is constriction by lime deposits at the top of the tube leading to the "coffee chamber" We used "Better Brew", available from Environmental Care Products in Norwalk CT. With this product, the problem gradually disappeared. We had previously cleaned the system with vinegar, but this didn't work. Now we have nice coffee again!
Posted on Dec 22, 2008
The filter light keeps blinking. the filter isn't dirty. the filter is in the front and slides out either side. we keep it clean. so.. how do i get it to quit blinking? is there some regular...
Pam, be sure tat the filter is properly installed. Whenever you remove the filter for cleaning, be sure to turn the unit OFF, before removing it. And back ON after it is cleaned and reinstalled.
For the blinking problem. Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. Once the time has elapsed, plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the unit's electronics reset themselves and reverted back to the original factory settings. If so, the filter light should have stopped blinking, if the filter is installed properly.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Whirlpool ACQ122XK Air Conditioner
I'm using whirlpool mastermind chrome split ac.. clean filter light started blinking so i cleaned and replaced the filters but still CLEAN FILTER light is blinking. please give a solution
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Whirlpool ACC108PS Air Conditioner
My zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Jun 07, 2010 | Dehumidifiers
The dishwasher will not Start and the Clean Light keeps blinking
This blinking indicates the water did not heat up properly in the heated wash part of the cycle. I have put together some instructions on resetting the control so you can use the machine and some details on why it might have happened. Follow the link and if you have any trouble let me know.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 03, 2010 | KitchenAid 24 in. KUDP02CRBS Stainless...
How do i start washing the clean light keeps blinking
The clean light can be blinking for several reasons, here is link to some instructions I put together to explain this and how to reset the unit so you can use it. If the problem persists let me know.
Apr 30, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
Jun 28, 2009 | Oreck XL Professional Air Purifier
Blue lights are blinking
I have the small version Quatra our older unit finnally died so sharper image sent us this smaller version. This will be the 2nd or 3rd replacement with in a week of getting a repalcement everytime the light starts blinking before it can even get dirty.
Mar 20, 2008 | Sharper Image (V23145) Air Purifier
"Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Feb 07, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Cuisinart Brew Central  DCC-1200W, 12-Cup 12-Cup Coffee Maker Logo
226 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Marvin
Marvin
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
