Question about Maytag Neptune MAH6700A Front Load Washer
Leveling Maytag Neptune
I heard there is a brick on the inside of the washer that also may come out of balance-is this true? And how do I fix it?
    Novelist:
  • 161 Answers
Leveling a washer can be a pain sometimes.
1. You must have a solid foundation. The floor where it sets must be good.
2. Use a level. When adjusting the legs keep the washer as close to the floor as possible.
3. Problem inside the washer. Look inside for anything obvious i.e. loose springs, loose counter weight.
Posted on Dec 21, 2008
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
MY WASHER MOVES VIOLENTLY AND THEN GIVES A LR CODE
I would check the balance of machine by using a leveler and checking the bottom leg adjustment on all 4 legs then check the
suspension springs, counter weights, dampning straps etc.
Jun 10, 2015 | Maytag Neptune MAH6500A Front Load Washer
How to fix a errow ob on maytag washing machine
OB is an out of balance load error, try re-distributing the clothing and see if it helps, also make sure the machine is level, if this doesn't help there may be a fault with the out of balance switch or lever.
Mar 06, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Hi I have a Maytag Neptune model MAH5500BWW Serial B4585662GA. When I turn the drum, I can still hear water inside/behind the drum. Thank you
This is normal. There is a balance ring filled with water attached to the inner drum. The balance ring is sealed and is not supposed to be empty. When you turn the inner drum by hand, you're hearing the water settling down from the now upper chambers of the balance ring.
Oct 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag neptune model mdg3000aww, and the spin cycle is not working. I have replaced the control board, yes the r11 resitor was burnt, the wax motor, yes the door lock light comes on now, and...
Did you check the out of balance switch on the bottom.I FIXED ONE LAST WEEK. All I did was push it a couple of times real hard until I heard it click. You can activate the diagnostic mode & see if the out of balance switch is activated. That is what I did after I found out the out of balance switch was activated & stuck on, I pushed it twice & it deactivated & spun out fine.
Sep 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer is spinning and moving all over the floor. I think the counter balance system is out of wack. Is it worth getting fixed?
is the machine level and the leg jamb nuts tight against the bottom of the machine so they can't get out of whack?if these are not level the machine will crawl across the floor
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH3000AWA seems to be rubbing
I suspect that you have a leveling bracket come loose. Many of the Maytag washers also use a large concrete block fastened underneath to help balance things. Look to see if yours is this type. If so then the steel rod holding thinge that holds it in place may have come loose...should be easy to put back correctly but will require some muscle. Most of the Sears Kenmore units have springs that can come loos from their connections and require re hooking but I do not think you have this type of unit for a Maytag. Hope this helped.
Aug 21, 2009 | Maytag Washing Machines
Maytag Neptune MAH6700A Front Load Washer Logo
344 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
