Question about ASUS P5S800-VM Motherboard
I have not signal to de monitor
The monitor works, i change tho another pc and works perfectly
may be the onboard screenchip have problem?
Frst try to cmos bios that mean tuk batery from main board and live on side about 10 min befor u do al off that turn off u r pc after 10 min return batery and try then that is first options ,then in some case u can hear sound from two interval bep bep that can be problem with u r vga cards or main board agp or pc exspres slot and on the end just push brtter vga cards in slot but pc must be turn off from power take care see ya byeeeeeeeeeeeee
Posted on Dec 21, 2008
My desktop monitor doesn't show anything once i turn it on
Just plug in the monitor with no video signal. It should display something like No Signal. If it does, then the monitor is ok and you have a video card or OS problem
Apr 22, 2014 | Microsoft Windows Vista Home Basic Edition...
No signal going sleep
how old is your monitor? can you try to conect another monitor your pc has integrated videocard? does it turn on and beeps?, you should check the back pannel of your pc and try to conect it to onboard video first (if it has), if you get signal get into the bios and change video output from onboard to a external card. if this thing dont work, then vga cord may be damaged or the card is not installed right or not working.
Jun 05, 2013 | Fujitsu Siemens Computers & Internet
Black Monitor, (NO SIGNAL FOUND)
Start your computer with monitor attached to the onboard graphics poart,
go to bios,
search for graphics setting and change it to PCIE.
Exit while saving changes connect your cable to graphics card port.
This will solve ur problem.
Nov 25, 2012 | MSI N210-MD1G/D3
I just changed my monitor and my new monitor is not coming on, it works with other pcs but when i insert it in my pc which has an Nvidia pcx 5750 graphic card de monitor gets a signal but the screen is...
Have you checked the bios to see if onboard graphics have been disabled.
You may also have your resolution/refresh rate set to high for the new monitor.
Boot into safe mode (F8 on boot)
This will boot with minimal drivers, your monitor should now come on, if it does then go to you display settings and lower the resolution and refresh rates.
If it does not come on in safe mode, try hook up the old monitor, or another monitor to reduce the resolution
Sep 21, 2010 | MSI PCX5750-TD128, PCX5750, 602-8969-010,...
Monitor shows "no signal" and will not start to windows. I've tried unplugging and replugging it. I've switched dvi and vga cables. The monitor turns on, but keeps on displaying "no signal" and then shuts...
the problum is with the PC, test monitor with a good pc,,
Unplugig all cards and ram chips and re try if it works then puging them back in ..Sounds like the pc has a bad ram chip or card some times they just get bad connection,
Mar 30, 2010 | Gateway 24" Widescreen Flat Panel TFT LCD...
Monitor (no signal) after replacing mother board and CPU
try only connect Monitor and keyboard, and check for booting (disconnect all the rest (HDD, CD DRIVE, Sound Card, Network Card, ....) then try connect one by one and always off to change hardware config.
If dont work with monitor and keyboard, try reset bios(jumper),check again, then replace memory modules (must be compatible to new motherboard), evan dont work, send back the motherboard for defective motherboard.
Jan 14, 2010 | Gateway Intel (El Paso 2) Motherboard P4...
I have hooked everything up and the monitor shows " no signal".
are you using the onboard? video... or a seperate vid card? if it was working and then suddenly quit? the onboard vid chip is out! cant replace that either try adding a seperate vid card and reboot
Jan 13, 2010 | E-Machines eMachines Desktop PC
Desktop has no signal
That means that the input from the monitor has no read able signal
Either the monitor is bad or the onboard or video card
Take the monitor and hook it up to a different PC to see if it works or hook a different monitor into that PC, that will ID which problem you have
Dec 29, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
No Video Signal
Try resetting the bios. On the motherboard there is a battery that looks like a watch battery. Remove the battery, then replace it again. (make sure the computer is unplugged from the wall socket when you do this)
Does this work?
Oct 24, 2008 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
No Video Signal
reboot in safe mode, safe mode will put the pc in vga mode and use whatever video it can find.
If no good U may have a problem with the MB.
May 23, 2008 | Gateway GT5228 PC Desktop
ASUS P5S800-VM Motherboard Logo
67 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
