Question about Acer AL1912B 19" LCD Monitor
Bottom Quarter of Screen Stretched and Distorted
I couldn't find anyone else with this problem on the forum which is surprising since I am having this identical issue with not one, but two ACER AL1912 monitors. This problem has occurred when the monitor was accidentally left on for a length of time (5 days or more). The bottom quarter of the screen becomes distorted and extremely stretched downwards, making it impossible to use anything in that space (thus making it impossible to use the display, really). I have a two monitor set-up. This had occurred on one of the monitors in the past a couple times after accidentally leaving it on as above. I switched monitors and did enough tests to determine that the problem indeed originated from the Acer and not my computer, cables, or video card. As mysteriously as the problem occurs, a solution in the past was to leave the monitor off for a week or more (I travel a lot so this is feasible). Most of the time after it's been off for a couple weeks the monitor displays normally. The last time this happened I just made sure that I switched the monitor off so there was no future problem ... until now. Recently I was out of town for a month and a colleague used my computer set-up. You guessed it: he left both monitors on after switching off the computer and they were on for over a week. Now, upon returning, both monitors are distorted and stretched in the bottom corner. Leaving them off for an extended time is now not an option as I have a project due in a couple weeks. And with both monitors afflicted I can't just use a 'good' one. Help! If it makes any difference, I'm running these off a Macintosh G4 in a dual monitor set-up. Thanks in advance.
  • 1 more comment
  • Michael Donaldson Apr 05, 2007
    A couple additions that may help:
    - I've posted a photo of the problem at this link:http://www.eight-tracks.com/P1010736.JPG
    - As I work in music production, there are medium-sized studio speakers about 5 inches away from each monitor. But the fact that the problem disappears and comes back (the speakers and monitors haven't moved) makes me think this may not be a factor ... ?
    Another addition: I just plugged in a co-worker's Dell monitor into my set-up (same cables and output I'm using for the left side Acer). His monitor does not exhibit this problem.
    Update: The problem has been solved via an identical post of this question to Ask Metafilter http://ask.metafilter.com/59990/Dismayed...
    It seems 'cycling the power' (actually unplugging the monitors and leaving them powerless for a couple minutes) solves this affliction.
    Sergeant:
    Champion:
  • 333 Answers
Sounds as though you have a faulty monitor. Give Acer a call and see if they will change it. They usually offer a 3 year warranty with their screens.
Posted on Apr 04, 2008
  • boff1 Apr 04, 2008
    Further to the above, it does seem a bit of a coincidence that two should exhibit the same fault. Have you tried changing the video card or trying the monitor on other PC's?
SOURCE:
ASUS P4SP-MX detect the new LCD monitor VH197D as an CRT. picture is stretched; circle's becoming a ellipse. Can you help me!?
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Feb 21, 2012 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
I came across a Sylvania 6620LE 20 in. HDTV and owner said it had some display problem. Said I could have it if I wanted it. Took it home, plugged it in and it has picture and sound. After about a second...
Yes,this problems it is 90% is the problems and the causes by the T-CON decoders board.10% could be the LCD screen panel itself it is shorted and dead also causes this problems.Tries websites like Shopjimmy.com,Ebay.com also have and sell these refurbish T-CON decoders board too.Tries it u have 90% of sucessfull rate.
Dec 04, 2010 | Sylvania 6620LE 20 in. HD-Ready LCD...
Black color screen
Change your screen resolution to the highest setting first, in control panel, appearance/ themes. Next Push smart button on bottom right of monitor. Cinema mode should be highlighted hit autoset on monitor. Next hit the FUN button and highlight the 4:3 screen setting. This will expand your image to fit the screen without giving it that stretched and distorted appearance.
Jul 18, 2010 | LG W1953TPF 19" Monitor
I'm using this as an additional monitor for a HP 10" netbook and the picture is stretched & distorted & doesn't fill screen. The vertical adjustment just moves the whole thing up and remains...
Solution goes this way, to maintain the aspect ratio of the monitor, take note of this. Your HP 10inch notebook have different resolution compare to your additional monitor, But I'm sure you selected the dual view mode or the duplicate mode that is why you have distorted display on your additional monitor, to let the additional monitor decide and maximize its resolution, try using the extended view option, you can change the resolution of your additional monitor without affecting the resolution of your 10 inch laptop.
Oct 21, 2009 | Acer X183HB Monitor
The screen is stretched there is nothing distorted
What kind of monitor? They can all be adjusted for width and height by using the buttons along the bottom of the screen. Often it can be confusing and a bit of a pain but look under the monitor menu for 2 sets of icons that look like 2 boxes on top of each other both horizontal and vertical. That is how you adjust it.
May 29, 2009 | Acer AL2216WBD LCD Monitor
Distorted screen
right click on the desktop, choose "Appearance and Personalization", "Display settings", and doublecheck that the resolution is set properly for your display.
You can choose the 'advanced' button and try 'list all modes'. It will display all supported modes for your hardware.
Jun 03, 2008 | Acer Aspire 5610-4648 Notebook
Distorted Screen
It sounds like the the power supply or the horizontal circuit is faulty, it is very likely you must take your TV to a professional repairer.
Mar 13, 2008 | Sony KV-27V55 27" TV
Faulty Lens?
Dear Swetnam
This is a internal circuit problem/defect and cannot be done on our own, so u should take it to SONY service centre. Avoid keeping the camera near hot temperatures zone. Sony is not tolerant to many physical factors.
Feb 07, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Nov 17, 2007 | Sony BRAVIA KDL-40V3000 Television
Acer AL1912B 19" LCD Monitor Logo
135 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
