Question about Creative Labs Extigy External Sound System
Blown input channel
Dear fixya
model sb audigy 2
all inputs distort down right channel when plugged into i/o module.
have i blown the module inputs or the card .help!
regards
matt
  • 167 Answers
Impedance could be an issue, have you tried new drivers? downloaded from creative labs. and try other input sources,other than the one you are using. tape,mp3 player,ect. and make sure the levels are set(play around until you get the desired level.also try new cables if you still have trouble. hope this helps.good luck! glen
Posted on Feb 19, 2009
Additional detail about my AUREX STEREO AMP MODEL SB 130. I have change the rexridiwe / power diode but to no avail. This same result. The fuse rated 3.15 blown up 2 times. I wonder will is the cul
A module or an amp is doing a short cicuit. It's time to check if all transistors are valid. Be careful, bipolar and FET transistors behave differently. It can help to compare one by one each transistor from the RIGHT and LEFT amps. Good luck.
Mar 07, 2014 | Audio Players & Recorders
HDMI
Prior to disassembly, unplug the power plug from the AC outlet without fail. (Turn the power "off".) Short the SB connector [1] pin and [2] pin of the DIGITAL INPUT MODULE PWB. (At the time of assembling) Before the rear cover is inserted into the cabinet,release the short-circuit between the SB connector [1]pin and [2]pin of the DIGITAL INPUT MODULE PWB. After releasing the short-circuit between the SB connectors, do not turn the power on until the rear cover is inserted into the cabinet. Negligence in carrying out the above steps may cause the inactivation of the TV.
Sep 30, 2007 | JVC AV-32S575 32" TV
Technics su z2
HI
2 things can do this
1.input selector is dirty and needs to be cleaned.
2.the power module is damaged.
Hope this helps
Dec 28, 2013 | Technics Audio Players & Recorders
I want sb0220 sound driver
http://download.cnet.com/creative-labs-sound-blaster/3000-2120_4-10022925.html
This is the latest driver update for the Sound Blaster Live! series of audio cards only for users running Windows 95 and 98. This release includes updated version of Surround Mixer 1.0 and AudioHQ, 1024-voice software MIDI synth for Sound Blaster Live! (Option to select up to 1024 software voices), and improved support for Occlusion and Obstruction effects in EAX2.0
http://download.cnet.com/creative-labs-sound-blaster/3000-2120_4-10005159.html
If you're using Windows 95/98, you can download this file and update your Sound Blaster 16, Sound Blaster 32, and Sound Blaster AWE drivers. Please refer to the readme file for installation instructions. This new version solves the audio distortion problem that occurred when the Sound Blaster 16Xpress chip was left running overnight.
http://download.cnet.com/sound-blaster-pci128-drivers/3000-2120_4-10038063.html This is an updated driver release for Creative Sound Blaster PCI128 for Windows NT only
http://download.cnet.com/sound-blaster-audigy-driverpack/3000-2120_4-10198813.html The driver contains optimized support for Windows 2000/XP operating systems and is designed for use with all current models of Sound Blaster Audigy audio cards (all existing Sound Blaster Audigy Card to SB023x models). Features includes: drivers are WHQL Certified; provides Dolby Digital decoding from external SPDIF Input; speaker settings in Creative Audio Mixer are synchronized with Windows Multimedia setting; new presets and effects added.
http://download.cnet.com/creative-sound-blaster-audigy/3000-2120_4-10198811.htmln This update is for all Audigy 2 and Audigy 2 ZS series audio cards, which include the Platinum, Platinum eX, Platinum Pro, Digital Audio and Gamer versions. This update is not meant for original Audigy series audio cards. This update contains additional features and fixes to improve the performance of your Creative Sound Blaster Audigy 2 or Audigy 2 ZS series audio card.
on cnet download.com you can find these drivers hope one of these will help
Jun 12, 2011 | Creative Labs Creative Sound Blaster Live...
I am trying to find the output power, watts?
bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
Jun 08, 2010 | Audio Players & Recorders
Akai am-u01 righthand channel sounds distorted/blown please can you tell me what components on the board to check/replace the left channels fine i have allready re-wited most of the board but cant single...
You can try swapping the speakers over to see if the fault goes to the other channel. Remove the speaker leads from the input on the right channel and put them into the left channel input after removing the leads from those terminals, and if the fault goes there as well, then the problem is in your right channel speaker
Apr 13, 2010 | Audio Players & Recorders
My sound blaster audigy wont work in windows 7, i want to know if there is installer for windows 7
If this is an Audigy 2 ZS as the heading says, you can download the Win7 driver at:
Audigy 2 ZS Drivers
If it is not an Audigy 2 ZS you can select the exact model at:
Creative Labs Product Selection
Click Audigy and then select your model #, then click Next.
Thanks fro using Fixya.
Dec 03, 2009 | Creative Labs Sound Blaster Audigy 2 ZS...
Having problems getting audio from my creative speakers
What sound card do you have? What model is the computer?
Oct 25, 2009 | Creative Labs sb audigy 2 2zplatn 2 zs...
Creative Labs Extigy External Sound System Logo
95 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
