Question about LaCie Electron 19" CRT Monitor
Lacie electron 19 blue won't work- power light is flashing yellow
The light is flashing like a heartbeat going from yellow to green....
3 Suggested Answers
SOURCE: electron 19 blue 3 outer screen
Download this monitor test [url]http://www.iiyama.com/Download/documents/ice_pages_documents/21/MonTest_2_1.exe[/url] and click on 'convergence' Now manually change the convergence setting of your monitor with the onscreen buttons to align the red/green/blue lines
Posted on Jun 05, 2008
  • 489 Answers
SOURCE: Lacie Electron 19 Blue IV went dead after a power surge,
yes its in power unit.
if you think the fuse is gone and you have ability you can change.
Posted on Jun 02, 2009
I have Omega EHE 100S ducted heating when I switch it on there is no response at all. Can you help me out?
If your green light flashes a normal 1 second flash continuously, it means your furnace has a normal heartbeat. If your green lite flashes so many times then stops and then flashes that many times again, then stops again, and repeats again, count the number of flashes, write down that number, then remove the fan door the schematic will tell you the trouble. If your furnace has a normal heartbeat, the thermostat or wiring from the thermostat to the furnace is opoen or faulty.
Nov 04, 2014 | Heating & Cooling
There's a flashing green and red light when my car is on and the sub attached to the amp is making a heartbeat like noise when the light goes green and then the light goes red right away. everything is...
Check the wires for short circuiting at the car body or speaker wires. Triple check really everything.
Make sure the connectors are 100% connected to the wires. There maybe some resitance if the amp isn't getting enough power from the battery.
Aug 19, 2011 | Jensen JXP680 Car Audio Amplifier
A continuous green flashing light
Usually states normal operation if it is about the speed of a heartbeat. On the panels located near the control board that the light is on should be a legend that can help explain the flashes. Also, Unit brand, model, and serial number could help me better diagnose your problem.
Jul 27, 2011 | Heating & Cooling
What is the green light that blinks on the left side of the printer just below the usb port?
Heartbeat LED
The heartbeat LED indicates that the formatter is functioning correctly. while the printer is initializing after you turn it on, the LED blinks rapidly, and then turns off. When the printer has finished the
initialization sequence, the heartbeat LED pulses on and off.
Oct 19, 2009 | HP LaserJet 4700 Printer
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Flashing green and yellow lights
You need to count the number of flashes to diagnose the error. Then go here and type error lights in the search box. You';; be able to follow the appropriate code to a solution.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2009 | Canon iP100 Portable Printer
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
My "Power Acoustik OV2-420" has a problem. Some advice please!!!
It appears that the output transistors have failed. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 04, 2008 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
LaCie Electron 19" CRT Monitor Logo
152 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
