Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Having trouble fitting receiver in canopy
Hi... i just purchased a hampton bay 52" ceiling fan with transmitter... and had to purchase a 1/2 inch electrical box.. to attach to joist... having trouble connecting c anopy to bracket with receiver... any suggestions? i'd appreciate it... typically i think with a regular electric box you just pretty much shove the wires inside that box.. but this box is way thinner...
  • 239 Answers
If your receiver is separated from fan place it inside sheetrock !
Posted on Jan 04, 2009
Lost my remote can i buy a new one for my ceiling fan
If you have the receiver in the canopy, then yes. You probably have to replace the receiver & transmitter .
Nov 23, 2013 | Hampton Bay 52 In. White Redington...
Installing a Hampton Bay Trieste ceiling fan, and I don't know where to locate the remote receiver. It doesn't seem to fit in the canopy or the fan base. It is rectangle shaped about the size
If it's a thin rectangular receiver (probably has UC7067 printed on it) It "slides" into the mounting bracket up by the electrical box. If this doesn't help you can call toll free 1-866-600-3267 at and ask for Jack Jr
Oct 15, 2012 | Hampton Bay Ceiling Fan. Trieste 52 in....
Model 740 154 Hampton bay Mediterranean ceiling fan
Make sure the switches in the remote and the receiver board inside the fan canopy are set to 3
Sep 06, 2009 | Hampton Bay 52 In. 5-Blade Ceiling Fan,...
Hampton bay ceiling fan (7030T) remote does not work.
This symptom is usually caused by either a bad receiver or bad transmitter. Install a new remote system (receiver & transmitter).
Apr 20, 2009 | Hampton Bay 52 In. White Redington...
Hampton Bay 60" Brookedale fan remote not working
The Remote (TRANSMITTER) control AND the RECEIVER must both be set to the same CODE in order for the REMOTE to operate the fan.
The RECEIVER is located in the CANOPY, the part of the fan assembly next to the ceiling which is also called the Hanger Bracket.
At the bottom of the Canopy you will see what looks like a large flat washer. Rotate the washer counter-clock wise to release it.
Then rotate the Canopy counter-clock wise to release and lower it. You will see the RECEIVER, which will have a short antenna at one end, tucked in among the electrical wire and bracket. Simply pull the RECEIVER out and you will see the CODE switches. Remember to set both devices to the same CODE.
Good luck. :)
Apr 19, 2009 | Hampton Bay 04379 Madison Avenue Ceiling...
Wall switches do not control fan
Some fans will not operate without the remote, however, I'm not sure if the Hampton Bay brand is one of these or not. Below is how you will bypass the remote if the fan will operate without the remote.
You can try disconnecting the receiver in the canopy of the van (the cover that fits snug to the ceiling) once you have shut off the power source remove the canopy and find the remote receiver.
Most likely it will be a rectangular box with white, black, and blue or red wires attached. Disconnect all wires from the receiver and lay it to the side.
Now reconnect the wires directly to the fan, white to white, black to black, if you have a red wire (or a second black wire) in the ceiling box connect it to the blue wire from the fan.
If you do not have a red wire (or second black wire) in the ceiling box, connect the black and blue wire from the fan to the single black wire in the ceiling box. This method will require you to pull the chain to operate the fan separately.
Dec 12, 2008 | Hampton Bay 52 In. White Redington...
I have a solution for you. Call 1-866-600-FANS(3267) and give them the numbers on the side of the receiver. Example: 7067FM-22 (6+5) Variations of this receiver are used by many different manufacturers including Hampton Bay,Emerson,Minka Aire, etc... There is a web site that shows a few examples of this receiver available.
P.S. It helps to know if your Ceiling Fan has a 2nd light above the fan or reverses direction from the transmitter.
Aug 19, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Windworld III has mind of its own -- light comes on any time it likes fan changes speed
This sounds like one of the most common problems with Hampton Bay's remote-contolled fans...either the transmitter (remote control) or the receiver (mounted in the fan, typically inside the ceiling canopy) has gone haywire. A circuit has blown or something is short-circuited, and it has a mind of it's own. The only fix is to replace the receiver and transmitter, which are relatively cheap and sold as a pair at your local Home Depot and Lowes.
Hope that helps! If you ave any other questions, feel free to ask!
Jun 14, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay Ceiling Fan - Clarington 503837 52"
It slides in above right above the ball, in the mounting bracket where the canopy is. You may have to kind of encourage it to go in there, and you will need to push wiring off to the sides and out of the way to help it have clearance to get in there.
Mar 10, 2008 | Hampton Bay AC414-LRU 52'' Kemper...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
88 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
