Question about HP DeskJet 697c InkJet Printer
Printer error messages
Hewlett Packard Deskjet 697C printer. Error messages of "printer is not ready" or "must load paper". This started after replacing ink cartridges. Tried disconnecting, turning computer off, back on, & reconnecting cable. Help! I need to do resumes!
    Problem Solver:
  • 5 Answers
* use the replace cartridge maintenance of your printer. try to remove again and re-insert the cartridge, make sure you properly follow the procedures and the cartridge is place on right. * look for jam paper also inside the printer. push the feed button. * if your using Windows XP, go to your Control Panel, then Printer and Faxes, and look for your printer device name. right-click on it and check Set as Default Printer if is not. and right-lick again look and click for Use Printer Online if you see one. uncheck also if you see Paused Printing checked. You can also tweak the Printing Preferences... menu. I'll gladly help in any way I can
Posted on Apr 05, 2007
Hp 9050n paper jam 13.32
check the censor 1, pick up 2,in fixing these should the spring tentioned
Feb 18, 2013 | HEWLETT-PACKARD HEWLETT PACKARD : HP 8-bin...
Tip
What is a Scanner Error 5 Hewlett Packard M1522nf
"Scanner Error 5 or Error 8"
Hewlett Packard Laserjet M1522
The Copier Scanner is failing to initialize or find home position. The printer will have to have the Scanner replaced by an Authorized Hewlett Packard repair facility. The printer may at times "freeze" or "hang".
Contact Hewlett Packard for possible Warranty repair. See Link Below
http://welcome.hp.com/country/ca/en/contact/phone_assist.html
Parts Required as follows:
Formatter CC396-60001 M1522N Printer
Formatter CC368-60001 M1522NF Printer
Scanner/Flatbed CB534-67903
on Feb 04, 2011 | HEWLETT-PACKARD Hewlett Packard 53A...
Hi I have a paper jam on my HP f2480 deskjet printer and can't seem to resolve it. Help please !!!
try to pull the paper slowly and gently to avoid the cut or you can used twissor to pull out some small sheet of paper left inside
May 24, 2011 | HEWLETT-PACKARD Hewlett Packard Deskjet...
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
Printer is loaded with paper but get message
Although you really haven't given me enough information, I will posit and response for you.
A "Load Paper Error can be caused by the application telling you to change the "TYPE or SIZE" of paper that is in your paper tray.
For example, The application thinks you want the page printed on "Letterhead" paper, but it know that you have plain bond paper installed.
So you are sent a change paper type message.
The fix is to hit go and skip around that error.
The actual fix is to make sure that your printer driver, application and the printer are all set to the same size paper and type paper.
Don
Nov 05, 2009 | HP Hewlett Packard LaserJet P1005 Printer
My HP Deskjet 5550 printer prints only a quarter of the page then stops and gives an error message stating 'there was an error printing this document'. It happens with documents from all applications on my...
I called Hewlett Packard and a technician worked very patiently with me to resolve the problem. I needed to download and install new drivers as the drivers on my installation CD had an error on them.
Dec 10, 2008 | HP DeskJet 5550 InkJet Printer
HP DeskJet 697c InkJet Printer Logo
97 people viewed this question
Clive
Clive
