Question about Dell Inspiron 6400 Notebook
Laptop problem my laptop hav got 2 vertical lines on the middle its Dell 6400 how can i remove them
  • 3,940 Answers
Reseat the video cable connection under the keyboard, and see if the lines go away. If not, connect an external monitor, see if the lines show there. If the lines do not appear on the external monitor, then replace the LCD. If they do appear on the external monitor, replace the motherboard
Posted on Jan 04, 2009
My dell lcd screen some lines vertical problem
We might be having issues with the video card or the LCD
For us to isolate where the problem is coming from
1. Tried accessing the BIOS see if the vertical lines are present
2. If there are vertical lines on BIOS definitely the problem is LCD and we to replace it
3. So if we see vertical lines inside Windows we might have issues with Video Card itself or Video Card driver
4. Try uninstalling the video driver and install a fresh copy of video driver. Else we need to replace the video card
5. Usually laptops have integrated video. So we need to replace Motherboard
Jun 02, 2011 | Dell Inspiron 6400 Notebook
One narrow vertical red line constantly on screen of Inspiron 6400 running Windows 7.
Check on another external monitor, if the picture is ok there, eliminate a faulty graphics chip
If picture is still poor, Graphics chip is faulty
You are now left with the issue of it being the VGA cable from the mobo to the screen, or a faulty screen. It may be that you just need to have the connections checked, but also may point to a replacement screen or Cable being needed
Jan 14, 2011 | Dell Inspiron 6400 Notebook
A thin vertical blue line has appeared across the screen of my Dell Inspiron 6400 laptop. How do I clear it?
A simple way to check also is to hook it up to an external monitor and see.
plaese tell me after chacking.
Sep 10, 2010 | Dell Inspiron 6400 Notebook
White lines in my laptop's screen
its your screen problem of your laptop pls change it,
Apr 15, 2010 | Dell Inspiron 6400 Notebook
Vertical lines on my lcd laptop screen
It's the connector problems.
If you know what to do, I can guide you:
First, remove the screw all over the LCD case, then you can see the connector, and flexible cables.
Second, remove the keyboard unit(by removing all screw on the unit), after removed, find the edge of the LCD cables, then you can see the connector.
The solution:
1.Try clean this two connector with soft brushes ( paint brush is good ), by removing the cable first,then clean the flexible connector using wet tissue ( use the alcohol ).
2. If still exist, you need to replace the flexible with new ones.
Feb 26, 2010 | Dell Inspiron 6400 Notebook
Dell Inspiron 1501 Laptop-6'' Red Vertical Line
The color red and especially red colored lines or a pinkish hue are indicative of an impending screen failure. The only other possibility is that the data cable on the left backside of the lcd panel may be loose at the socket or on the motherboard. 9 times out of 10 though, it is the lcd panel that it failing.
Jan 17, 2010 | Computers & Internet
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
Vertical lines in my laptop screen
There can be 3 possible reasons for this
1)Screen connector cable is loose. You can try to re-seat it and see if works.
2)display card problem. Connect your laptop to an external monitor and see if the problem persists. If it does not then
3)You will need to get a replacement LCD screen.
Hope this helps!
May 04, 2008 | Dell Inspiron 6400 Notebook
Vertical Lines on Dell Insprion 6400
Monitor Help Vertical Linearity - Sets the width of the vertical lines. Moire - Removes or reduces the Moire effect, if any.
Pipe Also known as a vertical bar, the pipe is a computer keyboard key ( | ) that is two vertical lines above one another and commonly looks like a full vertical.
Good Luck, Please dont for get to Vote/Thank You.
Dec 20, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
187 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
