Question about Kenmore 22422 Top Load Washer
Water runs out onto the floor
Tub won't fill; it runs out from bottom of washer onto the floor
    Problem Solver:
  • 17 Answers
The drain hose is off the pipe or other hoses from the pump to the wash tub. old hoses have a split in it. could be more than just hoses.
not easy but fixable you will need to unplug the unit and take the back off and have a look see. good luck and have fun.
Posted on Dec 21, 2008
I have a Kenmore 500 top load washer that doesn't hold water. As it is filling for the wash cycle all the water runs down the drain
The drain hose outlet must be higher than the 'full' water level in the tub or the water will syphon out until the tub water equals the hose height. If the drain system you are using for the washer is floor level, then you need to install a vertical pipe (1-1/2" minimum) to place the hose end into at the top and it should eject the water through a 90 degree elbow onto the floor at the bottom. There are more elegant solutions, but this will stop the tub from self-draining. Good luck!
Aug 05, 2010 | Kenmore 22422 Top Load Washer
Gcxrpo9odoww GE washer .. On fill up, it over flows onto floor?
Fill switch could be bad, or fill tube could be plugged making water not stop and it keeps filling. The fill tube goes from fill load selector switch to bottom of tub. Remove from top and blow it out. If this doesnt work replace water load size selector switch.
Jan 17, 2010 | GE WBSR3140DW Top Load Washer
Water running out
Is it from the water valve assembly or coming from under the machine? if it's from under the machine you may have a bad fill hose or a bad tub gasket, But I need some more info to help you.
Aug 07, 2009 | Frigidaire Washing Machines
The water will stay inside washer tub
Hi, What is the make/model# for this machine?
Did the water come out onto your floor?
I want to help.
Vic
Jun 20, 2009 | Washing Machines
WHEN I TURN WASHER ON WATER STARTS POURING OUT OF THE BOTTOM OF THE MACHINE AND ONTO THE FLOOR. WATER IS COMING FROM THE BOTTOM LEFT SIDE.
The drum seal is bad. The seal allows the center to come up through the tub and the tub to rotate around it, It usually has a rubber membrane that flexes so the tub can rock around. The rubber tears and the water runs right out. If you can, disassemble the washer and change the seal, otherwise the washer is toast. Sorry! You can verify this by pouring water in from a bucket. If this water doesn't run through then it is the hose from the fill valve to the water outlet under the lid.
Jun 08, 2009 | Washing Machines
Washing Machine Emptying
Sure sounds like a hole or crack in the tub.  Unplug power, shut off water, and disconnect the hoses.  Tilt the washer onto its front and look underneath.  Use a light to inspect the tub bottom and sides for a hole or crack. If it is small enough you might be able to plug it with silicone sealant.
May 27, 2009 | Washing Machines
While the washer was filling the tub. water began running on the floor. I shut off the washer and when I lifted up the washer the small clear hose was detached and was emptying the water onto the floor. ...
It is a pressure hose that shuts off the water valve when you reach the preselected level. It attaches to the pressure switch in the control panel, and the other end attaches to an air dome on the side of the tub near the bottom. Make sure this hose attaches firmly. If not, cut off a 1/4" with scissors.
May 04, 2009 | Washing Machines
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
GE top load washer leaks on floor
Check your hoses mostly the small hose going from the side of the tub to the water switch these come off a lot. you need to look and see if the seal is leaking from the center of the tub you do this by putting water in the tub and just looking around the bottom of the tub and transmission
Dec 29, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
90 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
