Question about Emerson SpongeBob SquarePants TV
No sound When you turn on the television you see the picture but there is no volume. Is there a way to correct this?
There is a manufacturer's reset.  Unplug the TV for a minimum  4 hours (I've left it unplugged for 24 hours or more) and this resets the tv to factory settings.  This has worked twice now for me and the info. came from a TV repair shop.
Posted on Oct 20, 2007
  • 3 Answers
Check for amplifier section. a deffective IC or deffective speaker may cause this symptom.
How do i fix volume problem , i have samsung 46 inch lcd , picture working fine but no sound?
Hi is your television running through a foxtel box or something else that has volume control, If so you might have one or the other turned all the way down, turn both volumes up and control every thing through one remote control.....
Mar 15, 2016 | Samsung LN46B550 46 in. LCD HDTV
Have great picture no sound. The buttons turn volume up and down but I can not get sound
If you are using HDMI cable make sure it can transmit audio as well, as some cables don't do this I believe. Other wise, replace it.
Jun 30, 2014 | ViewSonic N4285p 42 in. LCD TV
My t.v. turns on for 20 seconds then it just cuts the picture off but i can still hear the sound
The way to test whether or not the television needs to be repaired is to do some things to it after it has cut off the picture. Making sure you can still hear the sound but no longer see the picture turn the volume up and down. If you can hear the volume increasing and decreasing, but you cannot see the volume indicator itself on the screen then you'll know that possibly the inverter(s) is/are loose or that the inverter board needs to be replaced. If you can see the volume indicator moving back and forth across your television screen then you might have a problem with your signal source i.e. your set top box (cable box/satellite tv box), your connecting cables or the connections themselves.
Apr 21, 2011 | Memorex MLT1921 19 in. LCD TV
Have picture no sound did a reset nothing
The reason you have pictures and no sound might be as a result of a sound IC or that the volume is too low or on mute.
First check the volume to see if it is okay or on mute then correct that but if it is not, then it is a faulty sound IC that is causing it, so try to dismantle the television and replace the sound IC.
Then the television would be in good conditions once again.
Take care
Oct 11, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
Hi Def picture is pink and no volume. push sub menu on remote!
Hold down your power button on the unit and you should find it returns to it's factory defaults thus correcting the problem.
Mar 05, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
No sound dell 32in tv
These are the answers straight from the dell manual. Ensure that the audio cables are firmly connected to both the audio input connectors on your LCD TV and audio output connectors on your PC or Video player. If on certain TV channels you receive a picture but no sound, this means that you do not have the correct TV system. Modify the SYSTEM setting. Check if TV volume is turn off of muted Connect the audio cable securely Audio cable is connected incorrectly Verify that the audio source is selected correctly in the OSD
Jul 31, 2007 | Dell W1700 17 in. HD-Ready LCD Television
P61927 troubleshooting white noise
a similar problem was discussed here a while ago, ill quote from there: "This problem may occur when some TV's are connected to a volume control converter. To correct this, decrease the TV's volume until the buzz disappears. Now use the decoder/converter volume control and increase the sound to a comfortable listening level." hope it will help.
Jan 13, 2006 | RCA P61927 61" Rear Projection Television
Emerson SpongeBob SquarePants TV Logo
50 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
