Question about Hoover Refrigerators
Hoover Fridge Problem
Hoover HCS46 Fridge freezer with chilled pure water filter (normally chilled). motor did seem to be making a bit more noise than usual and basically now the fridge, freezer and chilled water dont work at all. Fridge still powers on, water filter dispenses water but at normal temp and motor sounds like it is getting power but nothing gets cold. None of the pipes coming in/out the motor seem to be cold. Motor is marked with electrolux HYK12AA (R600A). Pretty sure motor is the problem just looking for confirmation. Are these seviceable as it looks like solder connections. approx cost for replacement part +labour.CheersPete
  • kieran carroll Apr 23, 2012
    I am having the exact same problem, did you fix your fridge that time? I know it was years ago but I would appreciate it if you could let me know. Whats a water solenoid valve and is it serviceable?
  • 19 Answers
SOURCE: fridge has stopped working/getting cold
check the relay, the clicking noise is your overload tripping out on overload, the run winding of the compressor are not coming on line, if your relay is good, the ohm out your compressor.
Posted on Feb 21, 2009
catriver
  • 878 Answers
SOURCE: Fridge and Freezer working intermittently; not getting cold and making a vibrating sound
Dave, what you are hearing is the overload kicking out on the compressor. It's one of two things, either the compressor is failing or PTC (overload, relay) is going bad. I haven't seen too many PTC's fail on Frigidaire, but I have seen a lot of compressors failing. Your refrigerator will have a 5 year warranty, parts and labor if the compressor is at fault. You would have to do some tests on the compressor to determine which one is at fault. If you have a clamp on ammeter you can see how many amps the compressor is drawing during start and run. The compressor should have a label on it with the amperage information. You could just replace the PTC, part number 218721119 and see if the problem goes away but you could be throwing away money here if the compressor is the problem. With out being there, my guess would be the compressor itself. Catriver...post back.
Posted on Dec 09, 2006
roadbird383
  • 40 Answers
SOURCE: Fridge Makes Cubes But No Water
Sounds like a bad water solinoid valve.
Posted on Dec 09, 2007
SOURCE: Fridge not making usual humming sound
I had a same problem, However the fan in the freezer seems stop and the freezer compartment is melting. Its a double door LG with 270 ltrs.
Posted on Apr 05, 2010
SOURCE: Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Posted on Jul 22, 2010
Electrolux Pure advantage water filter
Open and shut the water valve quickly to verify the water supply, it could be a bad water supply valve. Bench test the filters for flow or obstruction.
Aug 01, 2017 | Electrolux Icon Freezers
Water from dispenser is not cold
Did you let water run through dispenser long enough for air to get out of lines and for reservoir to completely fill?
Oct 27, 2017 | Fisher and Paykel E522BRXFDU (176 cu ft)...
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
The freezer is making a rattling noise and the fridge isnt as cold as it should be, also a bit of water leaking out of bottom
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 19, 2010 | Hoover Refrigerators
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Hotpiont ffm90 fridge not chilling
hi if the freezer appears to work and the fridge if warm,the problem is that the freezer is over frozen and blocking the vents which send cold air into the fridge when required,and the noise is the fan hitting the the ice build up,defrost (switch off)your applinace for at least 36 hours then switch back on,you will then find after the freezer reaches -12 the fridge will then start to go cold.
Mar 09, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
Water Filter Not working
Hi Nicky,
We just had the same problem; and we've solved it.
Press the MENU button (4 times) until the Pure Water LED is flashing; then press and hold the SET button down until the screen goes back to the main menu.
SORTED!
Catherine & Matthew
Jan 02, 2009 | Hoover HCA390FFK Bottom Freezer...
Refrigerators Logo
322 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
