Question about Compaq iPAQ H3955 Pocket PC
How do I do a Hard Reset on my iPAQ H3955?
I was told to do a hard reset because a program (Thompson Clinical Xpert) update did not completly remove it's previous version and won't allow more updates. "HELP" doesn't describe reset nor does the "Getting Started Manual" and there is no other manual. Soft reset did not fix the problem. The device works fine.
I did do a backup on a storage card but am not sure what do once a "Hard Reset is done either.
Can you give me some guidance? Be gentle I'm somewhat a novice. I do have my original disk,etc.
Thanks,
SM
  • mcleods3 Dec 21, 2008
    Ginko,
    Thanks for trying. The unit just did a soft reset when I held the 1st,3rd &powerbuttons while pushing the reset and holding for 5 sec after reboot. I tried doing it with power on and off. but no difference. is there a another way to do a hard rest for model H3995?
    Thanks
  • Compaq Master
  • 19,396 Answers
  • Ginko
    Ginko Dec 22, 2008
    No, that is called the factory reset, the real hard reset is done simply by removing the battery. If that does not work, go to a local repair shop and have the software image reinstaled.
    If still no luck, then the Ipaq is faulty.
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
How do i do a hard reset on HP ipaq X11-21204?
u have given a wrong Model number this is not a model number infact a part number pls try to find the correct model number from HP site thru photo identification if u dont find ur model other wise i am providing u detail below to try the hard reset on various series of HP IPAQS kindly be sure that ur ALL DATA WILL BE ERASED pls rate me FIXYA if i fixed ur problem
How to Perform a Hard Reset on an HP iPAQ
Performing a hard reset on an HP iPAQ is relatively easy, but is a dramatic step in the management of your handheld organizer. A hard reset will completely clear the memory of your device and restore it to the state you received it in from the factory. A soft reset, on the other hand, simply closes running programs and restarts your pocket PC.
Instructions
Difficulty: Moderately Easy
Step1
Read the owner’s manual. If you don’t have to do a hard reset, you shouldn’t, and you definitely don’t want to do one by accident. So familiarize yourself with the hard reset protocol offered in the manual.
Step2
Make sure you want to clear all personal settings, saved data and personal files from your PDA. If there are files you wish to retain, save them to a removable disk, or send them to your computer’s hard drive to be retrieved at a later date before performing a hard reset.
Step3
For the HP iPAQ h1900 series, hold down the power button while you use your stylus to hold down the reset button (on the left side of the iPAQ). Hold these buttons for a few seconds until the screen fades to black.
Step4
For the HP iPAQ h2000 Series, press down on the far left and right buttons (calendar and iTask, respectively). While you do this, press and hold the reset button on the back of the iPAQ until the screen fades.
Step5
For the HP iPAQ h5000 Series and H3800 Series, the procedure is the same as the h2000 Series with the only difference being on some models the Today button is used instead of the iTask button.
Step6
For the hw6500 Mobile Messenger Series and hx2000 Series the procedure for the hard reset is precisely the same as for the devices in step 4.
Step7
For the rx3115 and rx3715 models, hold down the Mobile Media button (on the far left) and the iTask button. Then press down the reset button with the styles for a few seconds until the screen goes dark.
Step8
For the rz1710 and rz1715, follow the same procedure as the devices in step 7, with the difference of pressing the Today button (on the far right) instead of the iTask button.
Step9
To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Tips & Warnings
* If you’re iPAQ is simply slowing down or having problems, try a soft reset (reboot) before resorting to a hard reset.
* Read your iPAQ’s instruction manual to familiarize yourself with how to do a hard reset, and the effects of performing one.
* Do not perform a hard reset unless you are okay with or intend to erase all non-factory installed data and settings from your HP iPAQ.
Mar 17, 2009 | HP Computers & Internet
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
loaded are stored.
functionality.
Oct 16, 2008 | Computers & Internet
Full Reset
You need to press buttons 1 + 4 + Reset until the screen turn off, after that wait for 60 seconds and press the reset button again. remember that hard reset erase everything from your ipaq like personal information, programs that you installed, etc.
Xracer
Dec 05, 2007 | Compaq iPAQ H3955 Pocket PC
Hard reset does not wok in my ipaq H3955
The touchscreen may be broken, try hardreset again if it doesn't help contact your dealer or HP for possible repairs.
Sep 14, 2006 | Compaq iPAQ H3955 Pocket PC
Ipaq h3835 froze
Try a soft reset first to allow programs to terminate, then try to delete programs, if that fails to work give the hard reset another try http://www.fixya.com/support/p389721-hp_ipaq_h3835_pocket_pc HP iPAQ H3835 Pocket PC Troubleshooting, Support, Repair & Service
Sep 19, 2005 | HP iPAQ H3835 Pocket PC
Compaq iPAQ H3955 Pocket PC Logo
336 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
