Question about Black & Decker BL1900R Blender
How to fully disassemble B&D BL1900 blender - Black & Decker BL1900R Blender
4 Suggested Answers
SOURCE: Black & Decker BL1900
I had to call Black and Decker directly 800-231-9786 to order the part (called the "collar"). It was $14.95 w/ shipping and handling!! Seems pretty steep for a piece of plastic.
Posted on May 29, 2008
carlsbiz
  • 1124 Answers
SOURCE: I need to order a new jar for my Black and Decker
You should find it here ---
http://www.partstore.com/default.aspx?BrandName=Black+and+Decker&s=google&gclid=CNWhg5rJxpsCFRdGxwodMiIVAw
Posted on Jul 08, 2009
SOURCE: my black and decker blender BL1900 won't spin.
90-8=
Posted on Jan 11, 2010
Burnt smell on oster blender
If you have eelctric knowledge, disassemble the case and look for some corroded contact or cable.
You can follow some of these youtube tutorials or look for additional info by doing a Google search using terms
Youtube disassemble blender
iFixit Blendtec Total Blender Disassembly
How to open and repair Braun Hand Blender Part1
KitchenAid Blender Coupler Repair KSB5 Model
OSTER Blender Repair How to fix an broken driver
If you are not familiar with disassembling a blender but you feel you have the knowledge to do it, take a photo of each step so when you have repaired the problem, you should have no problem to reassemble it again
Sep 04, 2013 | Blenders
How to disassemble blender drive clutch gear
The hex wrench only fits in one position, there is a groove in the lip in the top housing and you need to turn the coupling until the hex screw head lines up. The groove is normally plugged with a dob of white silicone. The hex screw is not tightened fully tight on reassembly, the coupling needs a bit of slop.
Apr 16, 2013 | Vitamix Blender Driver Clutch Gear Super...
I turn the blender on and a blue light turns on, blender isnt functioning, is it burnt out, is there a reset button besides unpluging it for a few minutes?
Unplug the blender. Use a baking soda and vinegar solution to clean the metal contacts on the bottom of the metal blender blade. (You will see a small circular inverted washer looking thing). Use the solution on the main blender unit also. (You will see a small circular metal piece in the center) Scrub them both with the solution and wipe. These seem to be some type of sensors. I then replugged the blender back in and it worked for me!! Good luck!
Aug 08, 2012 | Black & Decker BL1900 5-Speed Blender
My glass jar leaks from the bottom
remove the screw on blade holder, and make sure the gasket is in place ,, check the seal on it,, if its defective replace it,, check along the threads to make sure that the canister isn't cracked
Aug 28, 2011 | Black & Decker BL1900 5-Speed Blender
The plastic base the blades are fitted in ,cracked need to order replacement
the part is Black and Decker Blender Base Collar Ring BL5000-11
However these are prone to cracking. I ordered a second after my first cracked, and the second one cracked after just a couple uses.
Jun 09, 2010 | Black & Decker BL1900R Blender
I have a BL1900 and the black plastic wheel on the base cracked and broke into a million pieces. It is the part that the glass liquidizer sits on - the collar from the liquidizer 'locks' onto the this...
You can order this part Black and Decker Blender Base Collar Ring BL5000-11
I also had the ring crack and ordered another one. It cracked after just a couple uses. So, even though you can get the replacement part, I'd suggest tossing the whole thing in the garbage and buying a different brand.
May 26, 2009 | Black & Decker BL1900R Blender
May 04, 2008 | Black & Decker BL5900 ProBlend Work Top...
Black & Decker BL1900R Blender Logo
167 people viewed this question
Top Black & Decker Blenders Experts
Marvin
Marvin
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
