Question about RCA HDLP50W151 50" Rear Projection HDTV
Humming sound i recently bought an AKAI dlp tv from a friend and its making this humming sound while the tv is on. it wasnt making this sound at his house,after i brought it to my house then i turned it on and it started making the sound. i was told it was the colour wheel, could it just be knocked off???, and if so how do i put it back on. i was also told that it could just be an electric problem with my other componets.
  • masterson81k Mar 16, 2009
    I have the same problem where do you find the directions and parts to be able to fix it? Please email me at masterson81k9@yahoo.com thanks so much
The old color wheel on models pre 06 have bearings. The new replacement dosn't. The noise you here is the bad bearing. Mine got so loud I couldn't take it anymore. Just replace and noise is gone! I did mine myself. Not that hard.
Posted on Dec 22, 2008
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Have a 61" dlp samsung tv, making a humming sound
Bad Color Wheel.will cause this and it is a common problem for DLP Samsungs.
Part number is BP96-01103A
Samsung Parts 1-800-627-4368
Jun 24, 2011 | Samsung HLR6178W 61" HDTV
My set started humming recently. Not real loud,
Hi, sounds like a bad color wheel, a technical repair that should be done be a trained repairman, cost around $250-275 installed
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 17, 2009 | Samsung HL-S5087W DLP TV
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
Good sound no picture
I have the same TV. On the back of the TV there is a square panel. Unscrew the six screws (the panel is on the opposite side of the inputs, I used needle nose plyers) after you take the panel off (make sure the tv is unplugged) you will see a black "housing" with two stainless steel screws. Unsrew those two screws and pull out the housing. there will be 4 screws to take off (uses a special tool called a T-8 TROX screwdriver and replace bulb. BE CAREFUL for this TV there is 2 different bulbs. If your serial number ends in a J you need a different bulb then if it ends in a Z (serial number is on the back of the tv in the middle) I recommend shopping www.nextdaydlp.com as they clearly label there bulbs, plus they are cheap!
May 28, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
Akai 32" flat pannel making a humming sound?
replace the a/v RCA cables to start with and then if you still have a problem, you have loose connecitions on the a/v board
good luck
caypianan@yahoo.com
Dec 29, 2008 | Akai PDP4225M 42 in. Plasma Television
I have a viore monitor ipt46dl30 which just went black but we can still hear the voice.. help?
I'm in the process of ordering a replacement bulb for a friends set right now. The information below is exactly what's needed to get the correct bulb for this DLP television.
TV Make: Viore
TV Model: IPT46DL30 (Confirmed to be on TV label)
Bulb/Lamp Model: SHP70 (This number is right at the top of the bulb/lamp, where the wires connect)
Housing Model: 140-1027 (This is also known as the Ballast which houses the bulb/lamp)
Now, I've managed to locate the bulb/lamp from a few different sites. Unfortunately, there doesn't appear to be a reputable manufacturer making aftermarket bulbs for this DLP model. The original bulb type is all we have to look forward to. The cheapest price that I've found so far is $120.00. I have also found these particular bulbs for as high as $295.00. Needless to say, I'm going with the former.
http://www.replacementlightbulbs.com/lampshp70.html - $120.00 (Buying)
http://purelandsupply.com/140-1027-Bulb-Akai-DLP-TV-Lamps.html - $277.90 (Too much)
http://www.encompassparts.com/products/?140-1027 - $295.00 (Too much & very skeptical)
Mar 31, 2008 | Televison & Video
32inch Akai tv
contact your friend and ask for the code! if not, look in the manual and try to fix it. =]
Nov 15, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
RCA HDLP50W151 50" Rear Projection HDTV Logo
186 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
