Question about IOGear MiniView GCS612A 2-port KVM Switch
Key combination have lost istruction guide & cannot remember the key combination to switch between pc's help
  • Tire Man Feb 04, 2009
    I have a Microsoft wireless optical mouse, 2.0. This switch states for PS-2. Are they compatible? Thanks, Mike
    President:
  • 2,923 Answers
Quickly press Scroll Lock twice and you should be able to toggle.
Posted on Apr 14, 2009
  • 944 Answers
Here is the link to the instructions; http://www.iogear.com/support/manual/106%20GCS612%20manual.pdf Page 14 - press and release "scroll lock" twice. Hope this helps :)
Posted on Apr 05, 2007
I have a ce electronic system safe for which I have two keys. I dont remember how to use the combination battery operated code any more as I have lost the instructions. Can I download these instructions...
I have a ce electronic system safe for which I have two keys. I dont remember how to use the combination battery operated code any more as I have lost the instructions. Can I download these instructions from the internet anywhere? The keys have 128 written on them but I cannot find any further I.D numbers anywhere. Thankyou very much for your assistance
May 21, 2011 | Safe International Digital Electronic Safe...
When conneting Acer Aspire 5810TG to a Samsung LCD LE32M6. The Samsung LCD shows 'no signal'.
On most laptops, you need to turn on the external monitor connector from a function key on the keyboard. It doesn't automatically sense you've hooked up the other monitor. On your model, hold down the Fn key and press F5 to switch the external connector on. Here's the page from the user guide with the key combinations you might find helpful:
Dec 17, 2010 | Acer Aspire TimelineX 5820T-5951 Notebook
I forgot combo'
If you have lost the combination, and the safe is closed, you will need to contact Sentry to get an emergencey access code. Sentry charges $12 to release emergency access code.
Here is the unloack page.
If the safe is open, then you can also try istructions here:Lost combination or keys WARNING
Jun 26, 2009 | Sentry Fireproof Safe
Switch on wireless connection
possiblr solution could be to hold down the FN key, while pressing the f11 key, you may have to do this a few times
Apr 23, 2009 | Advent 4211c Notebook
Wireless connection switch on
The combination key should be fn and f10 although our new laptop can not find any networks wirelessly even with this turned on so help on this would be appreciated
Apr 23, 2009 | Computers & Internet
Forgot the code for my sentry 3110 safe
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
If this still does not open the safe, refer to the following page for additional different types of safes:
http://www.sentrysafeshop.com/kb_results.asp?ID=15
If you need to retreive your lost combination, you can get it at this link:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Jan 09, 2009 | Sentry Fireproof Safe
How do you turn on the wireless function on the esprimo v5535?
hai
According to the laptop's quick guide this is how you enable and disable your wireless:
Radio components: Wireless LAN/ Bluetooth/UMTS
The installation of a wireless LAN module not approved by Fujitsu
Siemens Computers GmbH voids the permits issued for this device
(see chapter "Technical data", Page 22).
Depending on the device variant, wireless LAN, Bluetooth and/or UMTS may be integrated in your notebook.
On delivery, WLAN components are switched on, Bluetooth components off.
Switching the radio components on and off
Start the WirelessSelector using the key combination Fn + F1 .
The WirelessSelector enables you to switch the radio components activated in
BIOS Setup on and off individually.
BUWlMuireTtlSeososthLAN
Press the key combination Fn + F1 to start the WirelessSelector.
The radio component indicator will be illuminated when one or more
radio components is switched on.
If you switch off the radio components, the Bluetooth module, UMTS and wireless LAN transmission unit (antenna) will also be switched off.
You can enable or disable the radio components individually.
BIOS Setup allows you to specify which radio components can be switched on
and off using the key combination Fn + F1 .
Only those components that have been activated in BIOS Setup can be switched on and off using the key combination Fn + F1 .
Conversely, components that are deactivated in BIOS setup cannot be controlled using the key combination.
You can also activate and deactivate the radio components individually in the BIOS Setup. You must have assigned the supervisor password in order for this function to be available.
Pay attention to the additional safety notes for devices with radio
components provided in the "Safety" manual.
Details on using Wireless LAN can be found in the online help system
included in the Wireless LAN software.
You can find more information on how to use Bluetooth on the CD you
received with your Bluetooth software.
Sep 06, 2008 | Siemens Computers & Internet
Instruction Manual
vivirarcam35 user guide side send it
Nov 22, 2007 | Cameras
IOGear MiniView GCS612A 2-port KVM Switch Logo
652 people viewed this question
Top IOGear Computers & Internet Experts
Damen Wong
Damen Wong
Jose Velazquez
Jose Velazquez
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
