Question about Tower Aloha Breeze Fan
Need new fan
Some one gave me the fan. when i put it together it make a noise, so taking it apart, find that the black fan inside, some of the blades were broken at one end of blades, so after glueing them, it now works fine, but would like to know where i could order that part.
    Novelist:
  • 140 Answers
Yes your best source is Aloha Housewares 800-295-4448. Good luck.
Posted on Feb 09, 2009
How do I take apart fan
Hi, if you look inside the grill from the back side, you will see there are small snaps inside near the edge of the cover. The snaps go around the entire cover and are about 3-4" apart.
I used a flat tip screwdriver to get push the tab up from the back and the inside of the grill. When you push up the tab a bit, then slide a small flat tip screwdriver on the outside lip of the front grill. You will have to do this all the way around until the cover snaps off. Putting it back on is a breeze because it just snaps together.
***AS ALWAYS SAFETY FIRST !! NEVER WORK ON ANY APPLIANCE When it is plugged in !! ***
Hope this helps.... =)
May 25, 2014 | Lakewood 2210 Fan
I took the blades off my table fan to clean them and once i put the fan back together and turned the fan back own the blade spins and everything but no air is blowing out
I think that you may have put the blade on backwards. try taking the fan apart and reversing the blade around and reassembling the fan.
Dec 10, 2012 | Hampton Bay 24002 Ceiling Fan
I have an HP dv9500 Intel laptop. The fan is making some pretty bad noises. I took the laptop apart according to the HP Maintenance Guide. I found tons of animal hair (I have two cats and a dog) and...
If there is nothing hitting the fan blades and the fan makes a grinding noise then the fan bearing is faulty. You may be able to place a drop of oil on the bearing under the label in the center of the fan and if this does not work then you need to replace the fan.
Apr 23, 2011 | Computers & Internet
Fan does not come on
This will take some work, and some elbow grease, but what happened is the motor bushings most likely seized. Try turning the blades with your hand. If they are stiff, the bushings are seized. What you will have to do is take the fan apart. First by removing the blades, then by taking the motor off of the frame. Then depending on the type of bolts/ screws that hold the motor together, remove them. Then split the motor apart by taking a flat blade screwdriver and sliping it between the two pieces of the motor and turning it so they slip apart. then once the motor is apart, shine up and clean the motor's shaft so it is clcan and shiny. then do the same for the bushing/ beringholes in the motor's casing. then drip some oil in the berings, and on the motor shaft, and put the motor back together. then put it back on the frame, and plug the fan in. turn it on. the shaft should just spin without any help. if this does spin, put the blades back on, and put the guard back on. Then you sucessfully rebuilt the motor and the fan!
Aug 12, 2010 | Lakewood High-Velocity Fan
Filter
If this one is like mine (and it looks just like it except my Lasko doesn't have the wood grain on the front) there is no filter inside. It is just a fan inside a plastic case.
If you want to clean it, you can try blowing it out with compressed air if you have a powerful enough compressor. If you really want to clean it, you will have to take it apart and that isn't as simple as it sounds if your unit is just like mine.
There are a bunch of screws on the back, which isn't too bad except one of them is a triangle headed "security screw" that is probably there to keep you from taking it apart. I looked at several stores and couldn't find a screwdriver to fit the stupid thing. So what I did was that I took out the rest of the screws, pried the case open as far as I could with my hands and cut the support that the last screw was attached to from inside with a strong pair of wire cutters.
I figured that when I put it back together, I wouldn't miss that one screw and I wouldn't want to deal with a triangle head screw every time I took it apart in the future anyway.
Once the case is apart, I found the best way to clean the blades is to remove the whole blade assembly and just wash the thing out in the tub and let it dry thoroughly before putting it back in. There's a metal brace (Held on by two screws) at the top the top spindle goes into and there's a single screw on the shaft of the motor that hold the bottom spindle in. It probably sounds more complicated than it is. It's pretty simple when you see it.
If you put it back together right, you almost can't do anything wrong. You might want to take a damp cloth and wipe down the interior of the case and the shrouds that surround the blades as well. If you've had it a while, they'll be dirty. You'll see/feel the dirt wherever it is. This thing is a pretty simple machine and is easy to clean once you figure it out. I put a few drops of oil on the top spindle when I put mine back together.
May 21, 2010 | Lasko 2554 WIND CURVE Fan
Grinding of fan
There should be a black round nut in front of the blades in the very center. It will have ribs on it so you can grab it. Turn it Counter clockwise, and it should unscrew.
Then you can remove the blade assembly and get to the back cage to tighen the screws.
This should take care of the problem.
Re assemble in reverse order.
Let me know if you have any more questions or if this doesnt work.
Good luck.
Mac
Aug 19, 2008 | Holmes Products HASF1516 Stand (Pedestal)...
GE Microwave vent fan replacement
(I'm assuming you're talking about the hood / vent / exhaust fan instead of the internal magnetron cooling fan).
The part # SMV-260UA-C will not be enough to go on, as there at least 3 variations on that number shown at Samsung parts.
These microwaves are made by Samsung, but you'd need the GE part number to replace the whole thing. They don't sell the blades separately.
The part # for the "ventilation motor" is WB26X10042 and you can find it for $97.11 here, which is about fifty dollars less than direct from GE.
I may have available a replacement flan blade off a used unit. If you'll send me the dimensions, I'll check. I need the length of the fan blade, the diameter, and the inside diameter / shaft size, and whether the shaft is round or "D" shaped.
Please feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchen aid dry motor noise
Try taking it apart again and try to turn the motor by hand. It should spin freely. If it does you've probably got a bad motor. If it is stiff or doesn't turn at all, then you might have missed something putting it back together. I wouldn't think you can overtighten the blower, it is probably something else, and with it apart it should be easy to see.
Jul 21, 2008 | KitchenAid Dryers
Aloha breeze industrial floor fan
I assume this is the very popular 18-inch High Velocity sold at Wal-Mart. If you cannot return it to your local store contact Aloha Housewares at: 1-800-295-4448. Good Luck!
Jul 06, 2008 | Tower Aloha Breeze Fan
GE ADORA DSS25KSRDSS FREEZER FAN NOISE
Unplug your unit and check the fan blade by manually rotating it with your finger, check if the blade is not touching the fan blade frame. Check if the screws are not loose, align the fan blade and re tight the fan blade screws.
Jan 08, 2008 | Refrigerators
Tower Aloha Breeze Fan Logo
149 people viewed this question
Top Tower Dryers Experts
Jay Finke
Jay Finke
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Tower Dryer Expert? Answer questions, earn points and help others
