Question about Zenith IQZ60Z97D 60 in. Rear Projection Television
Blank screen with convergence lines
The screen has blue ,green and red lines coming from the top right corner,where they are tight together and they swoop down across the screen and separate and end at the top left corner where they are about 2 to 3 inches apart with red on top green in middle and blue at the bottom. The center majority of the screen is a bluish grey colour and the bottom has a bow from corner to corner rising in the middle to about 9" it is black under the bow. theconvergence chips were replaced a few months ago and the set worked until now, I just replaced the stk 392-110 chips with a pair of 150's and had NO change these were good factory chips(sony)-is there any other ideas on what is effecting the set there is no picture and no menues will show on the screen Help Please.
2 Suggested Answers
techman
  • 3130 Answers
SOURCE: no picture have sound
sounds like your IC's took a dive again. Did you change them or a shop? You have to also make sure that when you change the IC's that you put plenty of heat sink compound on the back of the IC's and do not use the cheapy IC's that you can get for 20 bucks or less as I have found they do not last. This convergence board should be available as a complete board. Good Luck
Posted on Mar 29, 2007
Panasonic hd projection with conver. problems
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 24, 2009 | Panasonic PT-56HX41 56" Rear Projection...
Convergence issue on Curtis Mathes CM19033S TV
try this will help u when my tv shows the problem i refer to this site onlyhttp://www.answers.com/topic/television-...
Nov 26, 2007 | Curtis CM19033S 19" TV
Bowed flickering green screen, black on bottom
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 25, 2009 | JVC AV-48WP30 48" Rear Projection...
Red is out of alignment
when i go to convergence and align the white cross with the blue its ok ,but when i try the red it doesnt line up and if l get it close enough it get misaligned only with the red ,green and blue fine
Nov 15, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Red and Green Arch
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jul 07, 2008 | Philips 60PP9363 60" Rear Projection...
No blue auto convergence when performed by menu buttons
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 31, 2008 | RCA HD52W59 HDTV Projection Television
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Hitachi television repair
how do i access the convergence on my big screen
Oct 16, 2007 | Hitachi 61SWX10B 61" Rear Projection...
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
