Question about Microsoft Office Excel 2003 for PC
How to connect one sheet to another sheet
Connect
  • arbs Jan 28, 2009
    how to copy datas and formulas from a sheet to other sheet
  • Danny Durbin
    Danny Durbin Jul 01, 2014
    You can either do as what is described in solution #2 or you can go to cell you want to copy, copy the contents in the cell and then go to the sheet you want the data and formulas copied and do a paste function.
How i connect one excel sheet to another excel
Posted on Feb 02, 2009
  • 67 Answers
If you have a cell need to get a value from another sheet this is the formula. Like, if you have a cell in the sheet1 one and it need to be equal to the cell in the sheet 2 and the source cell number is D4, this what you put in the cell.
=Sheet2!D4
Posted on Feb 20, 2009
How to connect one sheet to anothr sheet in microsoft excel?
Posted on Jan 13, 2009
Just what are you wishing to do, when you say connect one sheet to another
Posted on Dec 21, 2008
No headlights or taillights on my 84chevy c 10 I
Check the body ground cable connection. I don't know exactly where it is on your model, but it's usually a wire from the battery ground cable harness with a ring connector on the end, bolted with a sheet metal screw to the radiator mounting panel at the front of the engine compartment. (Sometimes it is attached to a fender well at the side of the engine compartment near a fuse or relay box.) If it is necessary to remove rust from the sheet metal under the connection, coat the screw, terminal and surrounding sheet metal with sensor-safe silicone rubber after assembly. Also, cover the end of the screw on the other side of the sheet metal.
Sep 21, 2014 | Cars & Trucks
Red and green light turn after first run
Its common problem in T Series Plotters:
Cause of malfunction: These plotters having separate sheet path as well as roll path for print media. After initializing plotter its verify the available media(sheet or roll). If sheet path is occupied by the media it wont allow the roll media, means first priority is for sheet.If sheet path paper sensor dusty or malfunction, printer will say "remove paper from sheet path" even no paper in sheet path..
How to shoot this problem:
You need to clean sheet path sensor located at sheet loading area.(black 'U' shaped part) Applying the pressured air at sensor is the best method to clean.. If problem remain you need to remove the sensor & clean or replace it.
Follow the snaps:
Need to open roll feed right side portion
dadb8b23-32b2-4d8a-952b-038117715d5b.jpg f7392b92-295a-4144-8387-b83355c6889e.jpg 6f066468-8698-4d24-94d4-af1703c40407.jpg 6ed46665-db38-4ccc-8522-c52ae9c50dbf.jpg 37e6b4f2-cc2e-438b-849e-9911bd553c7e.jpg
Clean the IR sensor...
Fix it back..
Note: Technical knowledge required to understand the remedy..
Jan 26, 2014 | HEWLETT-PACKARD CP1025 Laser Printer
VGA Data Sheet
Hello ... has solved the problem? I am also interested to know the connection because to me it does not work the monitor. I leave my email to communicate: ing.rdemarco @ alice.it. Thank you.
Mar 27, 2013 | Computers & Internet
What is bad duplexer connection?
duplexer is the bit that turns the sheet of paper over to enable it to be printed on its other side. Its usually a tray that the sheet is fed into after its been printed on its 1st side, then out of again to effect the flip and print on the sheet's other side. Its probably a 'bolt-on' option to the printer and may not be seated quite right, so not all its connections are making good contact. Careful, though
as there are high voltages present inside the printer....switch it off and disconnect the mains lead before you go investigating the internals!
Regards
nicam49
Dec 22, 2010 | HP LaserJet 5000gn Printer
I need a manual to operate the remote control for the Archos DVR Station for 604, 504& 404. Thank you.
user manual:
http://www.archos.com/support/download/manuals/user_manual_dvr_station_imt_v1.pdf
connection sheet (USA):
http://www.archos.com/support/download/manuals/connection_guide_usa_dvr_station_imt_v1.pdf
connection sheet (Europe):
http://www.archos.com/support/download/manuals/connection_guide_euro_dvr_station_imt_v1.pdf
Aug 18, 2010 | Archos DVR Station MP3 Player
Seeking the CWL1420P wiring and assembly instruction sheet
The sell sheet for this product shows this is a NEMA-14 Twist lock plug rated for 120V - 240V wiring.
To wire the plug:
G is for ground W is for Neutral
The hot wires connect to X and Y
This is simple for 240V ... your red and black wires connect to X and Y, the ground to G, and the white neutral to W
For 120V circuit, the G ground and W white neutral remain the same. I think the black hot wire is X.
A simple tester in the receptacle can confirm this before plugging in the twist-lock
Jul 08, 2010 | Cooper Wiring Devices ACE6001V-K "ACE"...
Canon CLC 1140 transfer issue on heavy or extra heavy stock
you must chose the bypass try to copy the heavy paper
Mar 24, 2010 | Canon CLC 1140 Copier
Auto sheet feeder does not work
Dear;
There might be several reasons:
1- the ADF sensor that detects presence of sheets is defective/broken
2- The ADF itself is not connected/not working
3- you might be inserting the sheets in a way that they are not detected by the sensor: try to move them around.
good luck.
May 07, 2009 | Canon PC-980 Color Copier
How can I avoid printing a cover sheet every time we print on a 265 st xerox document center
You have to enter the customer settings, access button then 11111. Scroll around until you find the location to turn OFF the cover sheets.
You also MUST have cover sheets disables on ALL conputers connected to the machine. Somehow if someone on the network has the cover sheet turned on, it will sometimes enable it on the machine also.
It is called BANNER sheet in the memory.
Jul 15, 2008 | Xerox Document Centre 265ST Printer
Dell 3100cn printer
SOLUTION1.gif!!!!
I just took my printer apart. The connector was broke where the sheet feeder connects. It was the electrical connector on the printer and not the sheet feeder.
I took the connector on the bottom of the sheet feeder (to be used for additional sheet feeders) and swapped it with the one on my printer. Put it back together and it is up and running.
Hard to explain, hope this helps.
Nov 07, 2007 | Office Equipment & Supplies
Microsoft Office Excel 2003 for PC Logo
414 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
